Old Feb 09, 2015, 12:52 PM
blade strike is online now
Find More Posts by blade strike
DJI SUPPORT / TESTING
blade strike's Avatar
United States, CA, Big Bear
Joined Jan 2006
Mini-Review
New ** 6s1p Dinogy 22,000mAh**
I do the same for ALL my battery test. I bring it to a hover throw it in GPS mode and relax.)
Mark over at dinogylipos.com contacted me. He wanted me to put his brand to the test. When I first received the pack it almost looked identical to the Tattu 22,000mAh pack. After some closer review I was able to tell these were different cells. The pack is a little larger than the Tattu pack, 2700g versus 2500. Something you wouldn't really notice on an s1000 or larger bird.
I wanted to break this battery in correctly and watch the IR stabilize. I started by running the pack through the usual 10 break-in cycles taking it down to 50-60% each time.. I noticed by these first flights that the battery was not sagging and cells seemed to be perfectly matched. The only other packs I have seen like this was the Tattu.
Below is the dataset of my 12th flight on this pack, this flight I took it down right to the 80% mark. Got over 17mins of flight time on a fully loaded s1000 with GH4 HD Gimbal and Lightbridge. I put back 17663mah in the pack, so at these flight times you will not be damaging this pack. The pack was 78F in 61F ambient, so this pack wasn't even stressing this setup or times.
What I noticed was the tight voltage curve on each cell over the flight. The only other pack I have seen this type of discharge curve was the Tattu 22,000. You will notice that it's a very tight curve and cells look to be closely matched. You will also notice how little sag there is, these are premium cells! IR has settled right at 6ohms which is very low!! The pack weighs 2735g (6lb), so even though these are top of the line cells, they still have an outstanding power to weight ratio as well. This battery is the first pack that I have tested to beat the Tattu brand, really surprising! Now over the next few months we will see how they hold up. I really don't have much doubt with cells like this, we might have just found the new Lipo leader for heavy lift setups.
If you're looking for more options on larger packs, this would be a great choice. These packs are pro level and the cells do show this. Mark is even having an Introductory special, Enter "Grand10" in the coupon section upon checkout @ http://www.dinogylipos.com .
Pack dimensions & weight :
Length (mm) 200
Width (mm) 91
Height (mm) 72
Weight 2735g
For more information please contact:
DinogyLipos
Tel 949-525-1644
Email marknosedive@aol.com
blade strike is online now Find More Posts by blade strike
Site Sponsor
Old Feb 09, 2015, 09:57 PM
c/f is offline
c/f
Find More Posts by c/f
c/f
Joined Jan 2004
Ever try gens ace? I have and find the dinogy quite nice
c/f is offline Find More Posts by c/f
Old Jul 11, 2015, 04:32 PM
Jinkslynx is online now
Find More Posts by Jinkslynx
Norway
So, how is the pack holding up? I am assuming that I.R measurement is 6mOhm/pack or 1mOhm/cell.
Jinkslynx is online now Find More Posts by Jinkslynx
For Sale Dinogy LiPos: 3S 1300mAh 65C and 30C (NEW) foobarbazqux Aircraft - Electric - Multirotor (FS/W) 0 Dec 29, 2014 11:40 PM
Discussion Compass 7HV testing the new dinogy lipos MarkF Large Electric Helis 10 Aug 01, 2013 12:55 AM
Sold 4ea 6s 22.2v turnigy lipo's 5,000mah 30-40c rcgalore Aircraft - Electric - Batteries & Chargers (FS/W) 2 Feb 10, 2011 10:23 AM
