Old Jul 03, 2013, 11:22 AM
Phoenex is offline
Find More Posts by Phoenex
Phoenex's Avatar
USA, IL, Champaign
Joined Jul 2005
New Product
E-Flite Mystique RES 2.9m ARF
I happen to see the new E-Flite Mystique RES 2.9m ARF listed at Horizon's website today and thought I would share. I love it!
Posted at E-Flite's website more info at this link>>> Mystique RES 2.9m ARF
Horizon Hobby website listing link>>>> Mystique RES 2.9m ARF
Edit added more pictures and specs adding overview
Product Description
Key Features
Rudder, elevator and spoiler sailplane control
Options included for electric motor power or pure sailplane flight
Genuine Hangar 9® UltraCote® and UltraCote Lite film covering
All wood, plug-in wings with fully hinged spoilers
Streamlined fiberglass fuselage with built-in vertical fin
Large canopy provides easy access to equipment and batteries
Heavy-duty carbon fiber wing and stabilizer joiners
Two-piece, full-flying stabilizer
Overview
The E-flite® Mystique™ RES 2.9 m ARF sailplane is inspired by the popular full-house Mystique 2.9 m except it has been specially modified to provide exquisite performance with only rudder, elevator and spoiler guidance controls.
Its large wingspan is built with just the right amount of polyhedral to provide gentle flight characteristics yet still have the authority to turn abruptly into a thermal the instant it’s sensed. The Selig S3021 airfoil used provides excellent handling over a wide speed range, plus the all-wood open-wing construction keeps weight to a minimum so you can take advantage of even the smallest amount of lift. Built-in spoilers offer the ability to dump lift without a gain in airspeed so you have control to escape a thermal and perform spot landings with greater precision. The contour of the molded fiberglass fuselage is sleek yet provides ample room for its pushrods to run internally and still have room for a powerful Li-Po motor battery.
Specs
Wingspan: 114 in (2.90 m)
Overall Length: 58.5 in (1.48 m)
Wing Area: 1030 sq. in. (66.5 sq. dm.)
Flying Weight: 4.85-5.00 lb (2.20-2.25 kg)
Motor Size: Power 25
Radio: 4+ channel full-range radio system
Servos: (2) micro servos, (2) thin wing servos
Recommended Receiver Battery: 700-1300mAh 4.8-6.0V receiver pack
Trim Scheme Colors: UltraCote White (U870), Transparent Yellow (U967)
CG (Center of Gravity): 7.68-8.27 in (195-210mm) back from leading edge
Wing Loading: 9.5–10.5 oz/sq ft (29.0–32.0 g/sq dm)
Airfoil Shape: Selig S3021
Prop Size: 14 x 8 folding
Spinner Size: 40mm with folding hub
Speed Control: 60-amp brushless
Recommended Motor Battery: 3200mAh 3S 11.1V Li-Po
Control Throw (Elevator): 23mm up, 20mm down
Control Throw (Rudder): 50mm up/down
Main Wing Tube Length: 400mm
Main Wing Tube OD: 11mm
Is Assembly Required: Yes
Assembly Time: 1-3 Hours
Plane Type: Sailplane
Experience Level: Intermediate
Power Plant Size: 25-52 Electric
Recommended Environment: Outdoor
Fuel Type: Electric
**A new video has been posted** Click Here
**Yak replacement motor option** Click Here
Phoenex is offline Find More Posts by Phoenex
Old Jul 03, 2013, 02:32 PM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
Looks nice. Specs are a little messed up but I am sure they will fix 'em.
aeajr is offline Find More Posts by aeajr
Old Jul 03, 2013, 06:01 PM
TeamHorizon is online now
Find More Posts by TeamHorizon
Joined Jan 2007
Yep, specs messed up. Basically 2oz lighter than the normal Mystique
TeamHorizon is online now Find More Posts by TeamHorizon
Site Sponsor
Old Jul 03, 2013, 06:06 PM
tkallev is offline
Find More Posts by tkallev
LSF303 / AMA Life Member
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
Looks really nice, Pete!
tkallev is offline Find More Posts by tkallev
Old Jul 04, 2013, 08:49 AM
ckankel is offline
Find More Posts by ckankel
United States, AL, Smiths Station
Joined Apr 2010
Can I fit the wings onto my full house Mystique?
ckankel is offline Find More Posts by ckankel
Old Jul 04, 2013, 11:16 AM
Craig Greening is online now
Find More Posts by Craig Greening
Horizon Hobby Employee
United States, IL, Mahomet
Joined Jun 2006
Yes, but the rudder on the RES model is larger.
Craig Greening is online now Find More Posts by Craig Greening
Old Jul 04, 2013, 11:34 AM
WallsRoofing71 is offline
Find More Posts by WallsRoofing71
United States, NC, Raleigh
Joined May 2010
Could be my next bird. Full house is ok but I like a RES or REF type gliders to me they just fly so much better
WallsRoofing71 is offline Find More Posts by WallsRoofing71
Old Jul 04, 2013, 11:35 AM
Joined May 2010
When will this be released
Will there be other colors to pick from
Old Jul 04, 2013, 12:28 PM
Joined Jun 2006
Second week of August is the current schedule. No other colors.
Old Jul 05, 2013, 12:27 AM
Phoenex is offline
Phoenex's Avatar
USA, IL, Champaign
Joined Jul 2005
I really like the Rudder Elevator Spoiler design along with the great looking airframe with good size.
The Horizon web page completion kit it shows a 1250kv motor EFLM4025C. I cannot find the EFLM4025C in searching. I found a 1250kv EFLM4025B pylon motor. A 1250kv motor on 3s with the big folding 14x8 prop seems it could be too much for the motor. Horizon does sell a EFLM4025H heli motor that has a 1000kv. The manual shows a EFLM4025C 1000kv motor. Could you clear up the motor confusion please?
The Mystique 2.9m ARF completion kit lists the EFLM4025A 870KV with the same prop.
Old Jul 05, 2013, 07:10 AM
Joined May 2010
I use the Eflight 25 in gliders of this size with a 60amp ESC. have put a 12-6 13-6 prop on them and it works well will climb fast.
This from above top post
Old Jul 05, 2013, 07:17 AM
AMA69405 is offline
Find More Posts by AMA69405
Gary L
Dexter, Kansas
Joined Oct 2009
Yeah... that's gotta be a typo. A 52 equivalent (if there is such a thing ) would be ridiculously serious overkill on a 5 lb sailplane. As has been pointed out elsewhere, the specs are totally messed up.
AMA69405 is offline Find More Posts by AMA69405
Old Jul 05, 2013, 07:56 AM
gquiring is offline
Find More Posts by gquiring
Sailplane Mafia
gquiring's Avatar
United States, SC, Summerville
Joined Jun 2001
The most funny part about this sailplane is the manual. It tells you where to set the CG behind the fuel tank I was speechless the first time I saw it.
gquiring is offline Find More Posts by gquiring
Old Jul 05, 2013, 08:29 AM
Joined Jun 2006
It's not a typo. The site categorizes motor sizes into ranges, 25-52 being one such range. If you look higher in the specs the motor size is listed as Power 25. A couple of specs are off, they're not 'totally messed up'. Yes we offer a Power 52.
On which page did you see the fuel tank reference?
Old Jul 05, 2013, 08:33 AM
gquiring is offline
Sailplane Mafia
gquiring's Avatar
Joined Jun 2001
I just noticed this is for the REF version. The other Mystique has the fuel tank reference. I don't own the ARF, a club member brought his out for final setup and when I was going through his manual I saw the mistake. It was pretty funny.
New Product E-Flite Mystique 2.9m ARF Grazer Electric Sailplanes 3783 Aug 30, 2015 04:06 PM
New Product E-flite Mystique 2.9m ARF molenjin Serbia 2 Nov 15, 2013 08:54 PM
Sold New!! E-Flite Mystique Sailplane with Servos/motor/spinner/prop johnnyrocco123 Aircraft - Sailplanes (FS/W) 5 May 30, 2013 05:09 PM
Sold New!! E-Flite Mystique Sailplane with Servos/motor/spinner/prop johnnyrocco123 Aircraft - Electric - Airplanes (FS/W) 3 May 29, 2013 10:11 AM
Discussion Mystique 2.9m ARF by E-flite (EFL4905) JBGROS Sailplane Talk 3 Oct 15, 2012 08:10 AM
