Old Apr 15, 2014, 08:49 PM
Veni, Vidi, Feci
patmat2350's Avatar
Motor City
Joined Dec 2004
Sometimes the truth hurts.
Sometimes a soft focus is a good thing.
But here is the hurtful truth in sharp focus-- 3D printed parts are rough!
Here is some of my 3DP anchor chain under the microscope. The parts are as-delivered from Shapeways (plus a little of my lint). They've been washed but not real well; parts should be washed again to remove the last of the support wax before being painted.
But you can see the jaggies and layering... and these parts are made at Shapeways' best resolution in their "frosted ultra detail" acrylic.
But really, with the naked eye, you see none of this. It does cause me some extra work, as those jaggies can stick to one another in my smallest chain, and I have to work EACH link by hand to ensure they're free.
The smaller chain here is printed with 0.5mm (0.020") "wire diameter"... smaller than the wire in most sewing pins!
patmat2350 is offline Find More Posts by patmat2350
Old Apr 16, 2014, 07:09 AM
Jerome Morris's Avatar
Union, Maine
Joined Jul 2006
Ooooo. Those look horrible.
More work cleaning them up than I realized.
Jerome Morris is offline Find More Posts by Jerome Morris
Old Apr 16, 2014, 07:40 AM
United States, ID, Rexburg
Joined Sep 2008
just to ask a question what would happen if you put them in a tumbler full of fine sand (like people use for polishing brass shell cases.....
Foo
fooman2008 is offline Find More Posts by fooman2008
Old Apr 16, 2014, 08:24 AM
Veni, Vidi, Feci
patmat2350's Avatar
Motor City
Joined Dec 2004
But as shown above Jerome, this is at a level you can't even see without a magnification. A baby's behind would look pretty gnarly too under a microscope.
Foo- tumbling has been used for larger robust parts... but I'm tempted to find a suitable medium for this delicate stuff and try it out. I have a rock tumbler just waiting for the experiment...
But again, this may be a solution for a non-existent problem... the chain looks fine to the naked eye!
Old Apr 16, 2014, 11:03 AM
Plowin Dirt
deckert's Avatar
USA, WA, Benton City
Joined Oct 2007
I'd try a vibratory tumbler with walnut shell media as the abrasive. My parts from Shapeways aren't real smooth either. I should have them printed with an Objet Printer but then the costs go way up. Big difference between .2mm & .003mm. The $250 setup fee for high res prints stopped me..
Dan
deckert is offline Find More Posts by deckert
Latest blog entry: Transmissions for planes
Old Apr 16, 2014, 12:12 PM
Joined Sep 2008
I would think that if you could find a fine enough abrasive it would do pretty well even for the very fine imperfections you are talking about. Walnut, or even black magic (carborundum) is probably way too coarse and aggressive for taking the little stuff off your chains.
Foo
Old Apr 16, 2014, 12:54 PM
Veni, Vidi, Feci
patmat2350's Avatar
Motor City
Joined Dec 2004
I believe these parts are printed on a 3D Systems Projet 3500 HD. The specs on the machine’s high def mode (used with Frosted Ultra Detail) appear to align with what I see under the microscope:
XY (plan view) precision: 375 dots per inch, or 0.068 mm per dot = 68 microns per dot… or ~ 7 “dots” across my 1/2mm chain “wire”.
Z (vertical) precision: 790 DPI = 0.032mm per dot = 32 micron layer thickness, or 16 layers for my 1/2mm chain wire.
Now, we were all amazed when HP came out with 300 DPI print capability in the Laserjet 4… you simply could no longer see the “jaggies” in printed line art. So even though these parts look rough under a microscope, they’re actually pretty darn good!
Old Apr 16, 2014, 01:36 PM
Cheif Bottlewasher
more coffee's Avatar
Canada, NS, Sydney Mines
Joined Sep 2005
Holy Crap Pat!!
Its a little jaggy .
Do you think maybe running the chain through a Casing Polisher for a few minutes would clean it up a little.
more coffee is online now Find More Posts by more coffee
Latest blog entry: Hi!
Old Apr 16, 2014, 01:37 PM
Veni, Vidi, Feci
patmat2350's Avatar
Motor City
Joined Dec 2004
a. Read above.
b. Read above.
I wonder how clay kitty litter work, since I don't have any walnut shells on hand? (Not all of us are set up for reloading work...).
I have to use a tumbler, but I bet one of those vibratory cleaners would be work better on long lengths of chain.
One fellow was using baking soda in a Paasche air eraser (mini blaster)... I couldn't get it to work...
Old Apr 16, 2014, 02:29 PM
Cheif Bottlewasher
Joined Sep 2005
Coal dust
Highly combustible and abrasive..
but may work?
Old Apr 16, 2014, 02:40 PM
Veni, Vidi, Feci
patmat2350's Avatar
Motor City
Joined Dec 2004
Highly combustible? Say no more!
Old Apr 17, 2014, 11:01 AM
Veni, Vidi, Feci
patmat2350's Avatar
Motor City
Joined Dec 2004
Here you go, 10 minutes in a rock tumbler with rice. I'll try something smaller now to knock off the last of that wax... maybe salt?
In the second view, you can see some "flash" between parts... this can cause me some grief when it "welds" adjacent parts together, and I have to break the links loose individually, oy.
Old Apr 17, 2014, 04:59 PM
Joined Sep 2008
I would think that salt might work, and would in fact be better as it is made finer and finer by use.
Foo
Old Apr 18, 2014, 07:17 AM
Union, Maine
Joined Jul 2006
Would pumice powder or rotten stone work?
Old Apr 18, 2014, 07:53 AM
Veni, Vidi, Feci
patmat2350's Avatar
Motor City
Joined Dec 2004
Many things can work, but you want to match the media to your parts. I need tiny stuff, but not too aggressive for the plastic.
