Letchworth, Great Britain (UK)
Joined Jul 2004
Your charger certainly should be able to get better balance than that. Even if the battery's not the best, the charger should at least get the cells balanced to 4.20v each. If the battery's old, it may take a bit longer for the charger to get there, but the end result should be 4.2v per cell.
I was very tentative when I first converted from glow to electric, but after a short while things became clearer. The most important lesson is that power output depends entirely on how many volts the supply is, and how big the prop is. Bigger prop will make the motor draw more amps, and if the prop's too big it will demand more amps than the motor, ESC, and/or battery can cope with, resulting in smoke somewhere. There's "stickies" at the top of several of these forums. One thread that might help you get your head around some of the electrickery is this one http://www.rcgroups.com/forums/showthread.php?t=739069 If you're into scale, as your avatar suggests, electric sure makes it easier to get the motor in without spoiling scale detail. |
| Thread Tools | |
| Discussion Help - RC Boat Info Needed by Newbie! | locolizard | Dock Talk | 1 | Jan 30, 2013 06:03 PM |
| Newbie needing info on EVERYTHING! | Teapot | Foamies (Kits) | 2 | Oct 06, 2003 04:12 PM |
| Newbie needs heli info | Zimmer16 | Electric Heli Talk | 12 | Jul 11, 2003 12:48 PM |
| Newbie Need Info | bankitguy | Electric Ducted Fan Jet Talk | 6 | Nov 29, 2002 09:04 AM |
