Old Jun 07, 2015, 08:55 PM
gainey is offline
Find More Posts by gainey
Joined Oct 2013
phantom fx-61 cg help please
Hi everyone
I have the fx-61, I am using the arkbird auto pilot, gopro on the nose with board camera, 4500mah battery.
for some reason I just cannot get the cg right, when I fly in gyro mode I have to constantly hold up elevator, in low flight I have to do the same, I just cant seem to get it spot on.
How do I set a wing, should the elevators be level with the main body?
I have attached a picture with two black lines above the main spar to show my cg points (the cg is right on the spar I believe)
can any help please
gainey is offline Find More Posts by gainey
Old Jun 09, 2015, 05:56 AM
giteart is offline
Find More Posts by giteart
giteart's Avatar
Greece, Attica, Ellinikon
Joined Jan 2014
C.G. should be at the spar or 3~5mm front of the spar. Don't go behind the spar.
Elevons level.
For more help visit this thread here
http://www.rcgroups.com/forums/showt...25904&page=423
giteart is offline Find More Posts by giteart
Old Jun 11, 2015, 06:11 PM
elewon is offline
Find More Posts by elewon
elewon's Avatar
United States, CA, Sacramento
Joined Feb 2013
All wings tend to be nose heavy and require some "reflex" or elevator up trim for level flight. Here's how I trim my wings:
1. Balance the plane such that it is slightly nose heavy when held at the spar - just slight, not a whole lot or you will have problems trimming the plane
2. On ground adjust elevator such that with stick at neutral elevons are deflected ~3/16" upwards. It is crucial to have exact same amount of deflection in both elevons or it will create roll on the plane during flight.
3. During flight up/down trim elevator for level flight at cruise throttle setting
elewon is offline Find More Posts by elewon
Old Jun 18, 2015, 06:59 AM
gainey is offline
Joined Oct 2013
thanks I will try it
Old Jul 03, 2015, 07:47 AM
Genetics101 is offline
Find More Posts by Genetics101
We were all NOOBS once!
Genetics101's Avatar
United States, WA, Seattle
Joined Sep 2011
Mine is set for the spar "exactly"! I actually hang mine by a string when everything is inside & RTF, then I rest the cover do its in its general position.
This is how I fly it & it's one of the best platforms EVER, especially using the vector FC
You can see I had to add a half ounce of weight on each side & I'm using the suggested 3s 4500 mah & a cobra motor due to the stock motor giving a ton of vibration
Genetics101 is offline Find More Posts by Genetics101
Discussion Phantom FX-61 - FPV Flight teddonald FPV Aircraft 1 Apr 26, 2015 08:31 AM
Discussion fx-61 phantom cg help gainey Flying Wings 3 Dec 19, 2014 04:30 PM
Discussion Phantom FX-61 Jedivoll1 Flying Wings 4 Jul 31, 2013 11:48 AM
