Old Jun 05, 2015, 01:39 PM
UBWHEREIIS is offline
Find More Posts by UBWHEREIIS
United States, SC, Goose Creek
Joined Jan 2015
Beaver
What do we need to set the throws to on a Specktrum DX7? I am not good at setting them by measurements.
UBWHEREIIS is offline Find More Posts by UBWHEREIIS
Old Jun 05, 2015, 02:24 PM
Charlie P (NY) is offline
Find More Posts by Charlie P (NY)
Gravity is weak but persistant
Charlie P (NY)'s Avatar
United States, NY, Port Crane
Joined Aug 2009
Not sure I understand. Are you speaking of the control surface of the model? I just set the model on a table and use a ruler. Yardstick for the bigger models.
You can get a device that attaches to the wing or empennage and measures deflection in inches or degrees.
Or a throw gauge that clips to the control surface itself.
But none of these are dependent on the transmitter.
Charlie P (NY) is offline Find More Posts by Charlie P (NY)
Old Jun 05, 2015, 03:40 PM
Joined Jan 2015
I didn't know they made such a device. I was speaking about on what setting to use. I am going to try and find these tools to purchase. These would come in handy.
Old Jun 05, 2015, 08:24 PM
Joined Aug 2009
I'm not familiar with the DX7 (one one of the DX6i) but they should be similar.
You want to be in Sub Trim to set the neutral or center positon of the surfaces and then Travel Adjust to change the endpoints of where they go at full stick movement. Best policy is always to manually adjust center position by changing the linkages - if possible.
Sold PNP Eflit Beaver dlewton Aircraft - Electric - Airplanes (FS/W) 4 May 07, 2015 05:26 PM
Sold Flyzone DCH-2 Beaver Wheel Set Flyboy81 Aircraft - General - Miscellaneous (FS/W) 6 May 04, 2015 12:15 AM
Sold Modelfly Beaver on floats clandestoy Aircraft - Fuel - Airplanes (FS/W) 0 May 02, 2015 08:58 PM
For Sale E-Flight Beaver 25E RTF w/ Floats jakeg1999 Aircraft - Electric - Airplanes (FS/W) 0 Apr 26, 2015 12:07 PM
