Old Jun 03, 2015, 04:21 PM
XtremeWingRC is offline
Find More Posts by XtremeWingRC
Fast? I got something 4 ya!
XtremeWingRC's Avatar
United States, WI, Oak Creek
Joined Oct 2007
Big Glider motor option for 136" wingspan
If i had a 136" glider and have to swing a 18-20" folding prop which outrunner kv choice should i choose for 4s 3300?
Should it be around 700kv?
Im not gonna use a gearbox like a hacker b50 with 5:2:1
Im using direct drive. Going the cheaper route.
I just wanna throw in a 100amp esc a motor and 4s
Theres gotta be a direct drive option instead of a gearbox option
XtremeWingRC is offline Find More Posts by XtremeWingRC
Old Jun 04, 2015, 06:43 AM
scirocco is online now
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
Kv of 700 will be way too high for 4S and 18", let alone 20".
Assuming around 90-100A, rough ballpark is up to Kv of around 440 for a nominal 20x14 and 520 for an 18x12 - these estimates are based on Scorpion 4025.
That's a big prop and a lot of power for 136" - what's the model?
scirocco is online now Find More Posts by scirocco
Old Jun 04, 2015, 06:52 AM
Leadchucker is offline
Find More Posts by Leadchucker
AMA7224 LSF1832
Leadchucker's Avatar
Joined Sep 2008
This would be tons of power for a 136" sailplane in the 50 oz. or so weight class
http://www.espritmodel.com/mvvs-40-4...ess-motor.aspx
I used this in a 3.6 metre (141") Pulsar. 136" isn't really big anyhow, more like middlin size.
Leadchucker is offline Find More Posts by Leadchucker
Old Jun 04, 2015, 08:03 AM
gquiring is offline
Find More Posts by gquiring
Sailplane Mafia
gquiring's Avatar
United States, SC, Summerville
Joined Jun 2001
I have a DragonFly Strong I just built which is 137 inches. I did a GliderDrive from HobbyKing 3858 4.6 1120kv. I used a 4s 3000 pack and it hauls the glider up with no issues. I used a 11x6 Graupner prop with a YEP 80 ESC. I also did a 3 meter Albatros from Top Model with the same setup and the Albatros goes vertical on that setup.
http://hobbyking.com/hobbyking/store...dProduct=71400
http://hobbyking.com/hobbyking/store...dProduct=36919
DragonFly thread:
http://www.rcgroups.com/forums/showt...ight=dragonfly
Albatros thread:
http://www.rcgroups.com/forums/showt...light=albatros
gquiring is offline Find More Posts by gquiring
Old Jun 04, 2015, 09:59 AM
rev.iain is offline
Find More Posts by rev.iain
Mesa AZ, it's a dry heat!
USA, AZ, Mesa
The Kv question is not the first item in the decision list.
First determine the approx. all up weight and from there calculate the Watts/lb for the performance you would like.
Check out my blog for more information on motor selection.
Iain
rev.iain is offline Find More Posts by rev.iain
Old Jun 04, 2015, 11:11 AM
Joined Oct 2007
Iain
Thats true watt for pound
Id have to see what the model weighs with electronics in her.
Old Jun 04, 2015, 11:21 AM
Joined Oct 2007
Fvk graphite.
Yeah i figured 700 would be too much. 500ish would be the ticket for a big prop.
Maybe ill take the dragonflys setup and run it from there
Old Jun 04, 2015, 11:37 AM
gquiring is offline
Sailplane Mafia
gquiring's Avatar
Joined Jun 2001
Is there a reason for such a large prop? My DragonFly goes great on a smaller prop. My DragonFly weighs 4.48 without battery, with a 4S3000 it weighs 5.26lbs.
I have GliderDrives in many of my newer sailplanes with zero issues. The model I use also comes in a lower kv. Here is the 840kv version:
http://hobbyking.com/hobbyking/store...dProduct=48054
Old Jun 04, 2015, 11:47 AM
Joined Oct 2007
Ehh well...the manufacturer fvk calls for a large prop via website. I know yours haul butt up to the moon.
I may do that with a smaller prop. Who knows we will see. Ive checked HK and the 840kv gliderdrive motor looks good!!
Old Jun 04, 2015, 12:14 PM
JimNM is offline
Find More Posts by JimNM
WAA-08 THANK FRANK!
JimNM's Avatar
Las Cruces, New Mexico, United States
Joined Jun 2002
I run that motor (glider drive 850) on my Mystique, 2.9m plane. 148 prop and 4s. A little over 800 watts. Climbs to ALES height in 18-20 seconds. For a 35 dollars motor... I am 100% happy with its performance.
JimNM is offline Find More Posts by JimNM
Old Jun 04, 2015, 12:20 PM
Joined Oct 2007
Thats what i ran on my mystique. It was all stock except for a 4s lipo.
She climbed good.
Old Jun 05, 2015, 02:06 AM
Joined Oct 2007
Ok clear the chalkboard.
Heres some parts ive found in the garage to make this 136" bird fly
Older 100amp esc german made
18x10 cam carbon prop not pictured
15x16 rfm slim
12x8 cam carbon
Just trying to get parts. Whatcha guys think on battery or that HK glider drive motor?
Maybe 4s 840kv and 15x16 RFM. <----might be way too much amps, 3s 3300 maybe
Old Jun 13, 2015, 12:34 PM
Joined Oct 2007
I think im gonna use this 840kv motor (MVVS 40 4.6/840)
It has ducted cooling fins and just is a great piece of art and craftsmanship
Old Jun 13, 2015, 12:46 PM
JimNM is offline
WAA-08 THANK FRANK!
JimNM's Avatar
Joined Jun 2002
I would like to heat from you about the difference between the Glider Drive and the MVVS motors if they are comparable in size and prop.
Old Jun 13, 2015, 01:54 PM
gquiring is offline
Sailplane Mafia
gquiring's Avatar
Joined Jun 2001
You really do not need the cooling fins. This is a glider, not a powered plane, you are going to run the motor for about 30 seconds or so. Cooling is not necessary. You could buy 3 GliderDrives for 1 MVVS motor.
Build Log Big slow "micro" rc glider! funwithplanes Scratchbuilt Indoor and Micro Models 1 May 26, 2015 08:00 PM
Discussion like big scale looks but what about weight? Lighter options? Dr.JJ Large Electric Helis 8 Jan 03, 2014 08:12 PM
For Sale Hanger 9 cap 232 big 33% with sale options. Shipping Needtoysjr Aircraft - Fuel - Airplanes (FS/W) 5 Oct 22, 2013 02:39 PM
Discussion Easy glider motor options mark_ Sailplane Talk 1 Nov 10, 2008 07:18 PM
