Old Aug 23, 2013, 04:10 PM
karltrek is offline
Find More Posts by karltrek
Santa Cruz, CA
karltrek's Avatar
United States, CA, Santa Cruz
Joined Sep 2011
New Product
New FMS Edge 540-Blue Edge
FMS Edge 540-Blue Edge! No info other than the YouTube video. Looks great!
FMS Edge 540-Blue Edge (1 min 26 sec)
3948-760KV motor
60amp ESC
17 gram metal gear servos
karltrek is offline Find More Posts by karltrek
Old Aug 27, 2013, 11:26 AM
UNABLE2SURF is offline
Find More Posts by UNABLE2SURF
Jet's are cool!
UNABLE2SURF's Avatar
United States, KS, Wichita
Joined Nov 2011
Looks great.
Sure is pretty!
UNABLE2SURF is offline Find More Posts by UNABLE2SURF
Old Aug 28, 2013, 05:30 PM
karltrek is offline
Santa Cruz, CA
karltrek's Avatar
Joined Sep 2011
Full info is now posted on the FMS website. I like it!
http://www.fmsmodel.com/products_det...775248433.html
Edge 540
Wingspan: 1320mm (52in)
Overall Length: 1270mm (50in)
Flying Weight: Around 1680g (3.7lb)
Motor Size: 3948-KV760 Powerful Out runner Brushless Motor
CG (center of gravity): 80mm (From Leading Edge)
Prop Size: 13X5 3Blade Propeller With Spinner
Recommended Battery: Li-Po 14.8V 2,600mAh 25C
Old Sep 04, 2013, 03:29 PM
out of stock is offline
Find More Posts by out of stock
DONT PANIC! :)
out of stock's Avatar
United States, FL, Lehigh Acres
Joined Jan 2012
no data on release date?
out of stock is offline Find More Posts by out of stock
Old Sep 04, 2013, 08:35 PM
dkrhardy is offline
Find More Posts by dkrhardy
United States, FL, The Villages
Joined Oct 2010
That big of a plane and it rides on wire gear legs? Hmmmm
Don
dkrhardy is offline Find More Posts by dkrhardy
Old Oct 13, 2013, 10:13 PM
extraedge is offline
Find More Posts by extraedge
Joined Jan 2006
Sounds under-powered. It'll have aerobatic power, but 3D pullout will be iffy. 3-blade prop? FMS does make me scratch my head at times.
extraedge is offline Find More Posts by extraedge
Old Oct 14, 2013, 04:08 PM
black6088 is offline
Find More Posts by black6088
United States, WA, Ferndale
Joined May 2012
Don
I own the FMS SBach, and I can tell you (from personal experience) that the LG wire legs and plastic mount are a problem unless you NEVER EVER have to make a hard landing. I'm tempted to try the new Edge 540 but it looks like they have the same LG setup as the other planes in this FMS series. But you're absolutely right, it's too bad they decided to go with such a wimpy LG--- again.
Tom
black6088 is offline Find More Posts by black6088
Old Oct 14, 2013, 06:41 PM
KE Spin is offline
Find More Posts by KE Spin
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
Actually similar size and weight to a 3dhs 51" Slick. I fly mine on a very similar setup and have PLENTY of 3d power.
Specs say motor is capable of delivering 750 watts divided by 3.7 pounds = 202 watts per pound.
KE Spin is offline Find More Posts by KE Spin
Old Oct 14, 2013, 11:25 PM
krexken is offline
Find More Posts by krexken
smoke is my wattmeter
Longview, Tx
Joined May 2008
It looks great. One of the best things about foam is that it's easily molded into practically any shape versus making it as scale as possible with balsa.
krexken is offline Find More Posts by krexken
Old Oct 16, 2013, 04:58 PM
Joined Jan 2006
The down side of foam is it's much softer, so the moves are not as sharp. And I am not convinced you can get 750W out of the stock motor. Maybe it will, but I will believe it when I see it. Usually stock motors are junk, and certainly not suitable for aerobatics.
Old Oct 16, 2013, 04:59 PM
Joined Jan 2006
And the FMS props I have seen are nowhere near as efficient as an APC.
Old Oct 16, 2013, 05:25 PM
Phonic450 is offline
Find More Posts by Phonic450
Your mother.
Phonic450's Avatar
USA, VA, Abingdon
Joined Jan 2011
it's burshless!!
Phonic450 is offline Find More Posts by Phonic450
Old Oct 16, 2013, 06:37 PM
KE Spin is offline
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
Props are only a few dollars and let's say that the motor only delivers 600 watts, that's still over 160 watts per pound.
Old Nov 03, 2013, 09:56 AM
karltrek is offline
Santa Cruz, CA
karltrek's Avatar
Joined Sep 2011
It's in stock at MotionRC
http://www.motionrc.com/fms-edge-540...-wingspan-pnp/
Old Nov 04, 2013, 04:02 PM
Tom.MotionRC is offline
Find More Posts by Tom.MotionRC
United States, IL, Lake Barrington
Joined Dec 2012
You may take this with a grain of salt but I can honestly say we have over 100 flights on this plane and it is not under powered nor is the landing gear fragile. I've had a few hard landings without issue. It is modeled after the Edge 540 V3 which is a much better looking (IMO) version of the Edge 540. All the servos are 17g digial metal gear. We've tested these servos extensively and disassembled/reassembled all of them multiple times to check the wear, gears, etc. I can honestly say this is the highest quality servo I've ever seen in a foam plane in this price range. My 2 cents.
Tom.MotionRC is offline Find More Posts by Tom.MotionRC
Site Sponsor
Discussion 50cc AW Edge 540 V.S EF Edge 540 Feliperc Fuel Plane Talk 5 Nov 23, 2013 10:18 PM
Sold Pilot 24% edge 540 red white blue dle 30cc LPO scott1980 Aircraft - Fuel - Airplanes (FS/W) 0 Aug 12, 2013 10:19 AM
Sold Edge 540 25 45'' Electric RC Airplane ARF Blue Chubbum Aircraft - Electric - Airplanes (FS/W) 1 Mar 08, 2013 04:55 PM
Sold 3dhs edge 540 41" silver/blue RickC2009 Aircraft - Electric - Airplanes (FS/W) 3 Jan 07, 2013 09:25 PM
Sold 3dhs edge 540 48" blue RickC2009 Aircraft - Electric - Airplanes (FS/W) 3 Jan 07, 2013 08:32 PM
