Old Jul 25, 2013, 07:56 AM
flypaper 2 is online now
Find More Posts by flypaper 2
Canadian Bacon
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Beautifull workmanship. Something you don't see too much of today.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Jul 25, 2013, 08:46 AM
PGR is online now
PGR
Find More Posts by PGR
PGR
Low AltiDude
PGR's Avatar
United States, CA, Costa Mesa
Joined Jun 2004
Here are some photos of a GWS Formosa that I covered in Solite back in 2005. I prepped the foam with "light" latex spackle and just ironed the Solite down on the foam. The Solite is shiny & reflective like a new car which made it hard to take good photos of.
Pete
PGR is online now Find More Posts by PGR
Old Jul 26, 2013, 03:52 PM
warhead_71 is offline
Find More Posts by warhead_71
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
Newspaper and wood glue method -- and it's waterproof:
http://www.rcgroups.com/forums/showt...575675&page=10
http://www.rcgroups.com/forums/attac...mentid=4938593
warhead_71 is offline Find More Posts by warhead_71
Old Jul 26, 2013, 05:30 PM
BobRCnut is offline
Find More Posts by BobRCnut
AMA 754
BobRCnut's Avatar
Phoenix area
Joined Apr 2004
Go with the Solite....
http://www.rcgroups.com/forums/showt...t#post10394010
BobRCnut is offline Find More Posts by BobRCnut
Old Jul 27, 2013, 05:40 AM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
I still think a Tiger Moth would be strange in shiny film finish ?
Nigel
solentlife is online now Find More Posts by solentlife
Old Jul 27, 2013, 11:09 AM
spencer6891 is offline
Find More Posts by spencer6891
spencer6891's Avatar
NC
Joined Aug 2004
It could probably be dulled with a light spray of flat clear.
I looked up some examples and while some guys have gotten some great results with film, there still seems to be a foam bead texture showing through on EPS models that have been covered with film. Additionally, you run the risk of swelling the beads with heat application.
I'm going to try Japanese tissue or silkspan with WBPU. This seems to be the best way to cover the foam texture without adding too much weight. I'll experiment and report back here.
Check out this Ultrafly P-51 build thread to see what is achievable:
http://www.rcgroups.com/forums/showt...=536128&page=8
For referrence, here is a close up of the Ultrafly EPS foam texture:
http://www.rcuniverse.com/magazine/r.../finals/12.jpg
Matt Halton seems to have completely eliminated that texture!
spencer6891 is offline Find More Posts by spencer6891
Old Jul 27, 2013, 12:00 PM
solentlife's Avatar
Joined Jan 2010
I still suggest a Tex covering ... such as Solartex ....
Nigel
Old Jul 27, 2013, 03:37 PM
NC
Joined Aug 2004
Nigel, you got any pics of your Solartex covered models? Does it completely hide the foam texture (assuming you covered EPS-type foam with it)?
Old Jul 30, 2013, 09:57 AM
solentlife's Avatar
Joined Jan 2010
My Big 61 powered Biplane has foam used in the wing to complete repairs ... ribs and sheeting. She was smashed in a vertical into tarmac after elevator failed in an inverted fly-by !!
For me - bipes like this and the Tiger Moth are fabric covered machines and deserve similar in model form.
The real beauty of Tex is it's fabric finish and it's ability to accept any paint ...
Nigel
Old Jul 30, 2013, 10:30 AM
DustBen is offline
Find More Posts by DustBen
DustBen's Avatar
United States, AL, Gardendale
Joined Dec 2011
Originally Posted by Glacier Girl View Post
May sound a little silly but you should sand foam with WET sandpaper. Lot less of the fuzzies some seem to get, also if you dry sand too long in one place it will cause the foam to swell, and you will be sanding forever trying to remove a high spot.
Another method if you aren't looking for strength, is paper. Where light glass cloth will conform to the foam, a good thing for bonding/strength, paper tends to bridge over the foam. Will hide a lot more of anything you missed in sanding.
I glassed the bottom of the wing and inside fuse on my E-Flite SuperAirliner. Outside of the fuse was done with newspaper, wing with of all things Christmas wrapping paper.
Coat of WBPU, lay down the paper, nother coat of poly, squeegee off the excess.
Light sanding, coat of primer, sand, paint.
Check out the reflections in the paint. SMOOOTH!
Stunningly beautiful model.
I use a technique similar to your bonding process except I use white glue thinned with 3 parts water to one part Elmers using "silkspan" (not silk).
It takes a couple days to dry completely but it sands well and "takes" color coats well.
I'll have to investigate the water based polys and find what seems applicable.
A guy in our club did a Balsa USA SE-5 using WBPU as the base coats over "Tex" material and then shot that with two thinned coats of regular household interior latex.
It's one of the best finished planes I have ever seen.
It's a heavier process than what's being discussed here, but I was impressed how well it "flowed. Not a seam or overlap could be detected.
DustBen is offline Find More Posts by DustBen
Old Jul 30, 2013, 10:35 AM
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
If you want to simulate a fabric finish using the newspaper and wood glue method, brush the glue on in the horizontal direction on the first pass, then in the vertical direction on a second pass. The criss-crossed brushstrokes will look just like fabric. You want to glue to be fairly viscous -- not too watery -- so it leaves the brush stokes. ModPodge also works great.
Old Jul 30, 2013, 11:30 AM
PiperRon is offline
Find More Posts by PiperRon
PiperRon's Avatar
Joined Feb 2013
Here's my Super Cub in light weight duct tape and masking tape.
PiperRon is offline Find More Posts by PiperRon
Help! what should I use to cover a foam wing for a 60" plank? Mike_ Slope 8 Jun 09, 2013 07:04 PM
Discussion Monokote Covering for Dollar Tree Foam roger5005 Foamies (Scratchbuilt) 2 Apr 28, 2013 11:35 AM
Discussion Best glue for balsa skin covering foam? drstation Sailplane Talk 21 Mar 17, 2013 11:16 PM
Discussion Looking for a foam 3d trainer peterdawolf 3D Flying 5 Feb 24, 2013 06:30 AM
Discussion Looking for opinions on foam covering films rcnutt Foamies (Scratchbuilt) 10 Mar 14, 2012 07:13 PM
