Old Mar 06, 2015, 04:21 PM
United States, AZ, Phoenix
Joined Dec 2013
Dell poweredge c6100
Has anyone tried to convert a DELL POWEREDGE C6100 C410X 1400W POWER SUPPLY yet?
OG Racer is offline Find More Posts by OG Racer
Old Mar 08, 2015, 07:15 PM
AMA 1033652
mnemennth's Avatar
United States, TX, Victoria
Joined Jul 2012
Wow... lots of new stuff on this thread since I last visited. That ASTEC 23920 project tbird is working up is flippin' SCARY; enough juice to weld 1/4" plate.
However, I find myself in need of a power supply to replaced my beloved HP DPS-1200W; I've got two Turnigy Reaktor 300Wx2 I need to feed, and it's ALMOST enough to feed ONE.
As luck would have it; I sought out a 24V PSU on fleaBay and found THIS:
http://www.ebay.com/itm/141268154108
Made a $35 Offer and now it's on its way to me. I figure starting out with brand-new is always nice; these chargers are designed for 12-32VIN, with full rated output at 18VIN, so 24VIN should be good and efficient.
So... anybody seen this PSU before? Is there any existing Hackery knowledge out there, or am I trailblazing here again?
Also... anybody recognize the socket on the tail of this beast?
mnem
*Charged*
mnemennth is online now Find More Posts by mnemennth
Old Mar 13, 2015, 01:56 PM
racingmat's Avatar
France, PACA, Marseille
Joined Mar 2015
Originally Posted by costefan View Post
Hi,
How to turn then on IBM AWF-11DC-1400w ?
I have been given a nice piece of PSU supplying 12V @90A
(only 40$ on EBay)
I would be interested if someone can share information about it!
Thanks!
racingmat is offline Find More Posts by racingmat
Old Mar 14, 2015, 08:30 AM
racingmat's Avatar
Joined Mar 2015
Hi,
I found out the way following the general method here : http://www.rcgroups.com/forums/showt...3#post31053486
Old Mar 14, 2015, 02:25 PM
Joined Mar 2015
DELTA EDPS-190AB and Qaulity components DCJ2902 pinouts
These are found in newer Cisco Switches - different wattages, but same pinout.
Hank42 is offline Find More Posts by Hank42
Old Mar 14, 2015, 05:02 PM
United Kingdom, England, Middlesbrough
Joined Dec 2014
Banggood are selling ' Switching Power Supply 170-250V To 24V 25A 600W For LED Strip'£41 OR Switching Power Supply 110/220V To 24V 20A 480W For LED Strip Light£26.
Would switching supply be OK for balance chargers?. They both have an adjustable V out put also.
conisat is offline Find More Posts by conisat
Old Mar 17, 2015, 07:26 PM
Joined Dec 2013
Is there anyone that can help me convert this power supply t use with my chargers?
Old Mar 21, 2015, 06:27 AM
Joined Mar 2015
DPS-1520AB problem under heavy load
Hi,
Maybe someone can help me. who uses the DPS-1520AB.
I searched and read a lot about the topic, but could not find the exact solution for that type of PSU.
I can turn it on by connecting A1-B1, but under heavy load (>1000W) the PSU shuts down. I measured the 12V voltage and it is rock solid 12.25V until it shuts off after 5-30 seconds of heavy load.
I assume some other pins need to be connected too. 12V sense or something else? But which is that pin?
I've found a photo that someone connected also B5 and C5 together, I tried but that does not help.
I also took the PSU apart and checked the caps visually, they seem to be OK, and it is very clean inside. So I think the problem is not caused by the worn condition of the PSU.
I have two of these and both does the same.
I wonder if anyone got these working above 1000W continously.
Thank you!
Zorg33 is offline Find More Posts by Zorg33
Old Mar 21, 2015, 11:06 AM
Joined Mar 2015
Originally Posted by Zorg33 View Post
Hi,
Thank you!
my english very poor.im use 1520ab too.b5&c5 you are wrong,it is c5&d5.c5&d5 together to fan speed fastest
188354620 is offline Find More Posts by 188354620
Old Mar 21, 2015, 11:27 AM
Joined Mar 2015
Hi,
Thank you!
if you willing,please give me your email address,because i have any fault in my dps-1520abb.or you can contact my email:529999732@qq.com
Alert Need advice on high grade power supply for ISL-8 Byron Betterly Batteries and Chargers 7 Dec 07, 2003 08:31 PM
12volt, 9amp power supply for sale Paul Susbauer Aircraft - Electric - Airplanes (FS/W) 1 Dec 03, 2003 12:44 PM
12volt wallwart power supply reading 14.6 ? (help) power Batteries and Chargers 4 Sep 09, 2003 04:21 PM
Where to Get A Quality Power Supply? Joe Elston Batteries and Chargers 4 Apr 29, 2003 02:09 PM
High end charger and power supply for sale! Very new. ted616 Aircraft - Electric - Airplanes (FS/W) 6 Dec 02, 2002 11:31 PM
