Old May 08, 2016, 09:53 PM
chevyv8 is offline
Find More Posts by chevyv8
Joined Apr 2015
Lipo is warm with 5 min of time
I am new to rc planes and lipos. My wife bought me an airfield 1450mm p51 last year for Christmas. I flew it once and realized I need a trainer first. Prior to the flight I charged the lipo it came with. Flew it for a few minutes and stored the plane and the battery. Having not done anything else to the battery. I pulled the plane out the other day, charged the battery and started checking things over. I had the plane in my yard with the tail blocked and spun the motor to full rpm a couple times. Plane was in power for about 3 minutes total. Plane was powered on for about 5. I opened the canopy and immediately felt some heat in the battery/reciever compartment. The battery was warm but not hot. I did not take a temp reading.
Should I be concerned, should I do something different.
chevyv8 is offline Find More Posts by chevyv8
Old May 08, 2016, 10:07 PM
Wintr is online now
Find More Posts by Wintr
Wintr's Avatar
USA, MO, Florissant
Joined Nov 2010
Captive like that, you didn't get much cooling air through the battery compartment, and the battery generates heat, so will warm with use. BTW, you should get a cell checker to test the battery; it should be stored between flights at about 3.8-3.9V. Higher or lower Voltages, long term, will slowly degrade the battery.
Wintr is online now Find More Posts by Wintr
Old May 10, 2016, 09:59 AM
Mike_Then is online now
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
Exactly. You had no airflow moving over the battery, hence the higher temperatures. Also, if you were throttling up the plane full blast for a few minutes, you were asking the battery to produce a lot more power than it does in flight. Most people don't fly full throttle for the entire duration of the flight; throttle management is an important part of electric aviation.
Mike_Then is online now Find More Posts by Mike_Then
Latest blog entry: F-14 resurrection
Old May 10, 2016, 10:54 AM
cmdl is offline
Find More Posts by cmdl
http://www.sgvhumane.org/
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
What Wintr and Mike mentioned - and to be certain of what is going on, you should buy a wattmeter. If your full throttle current draw is too close to the lipo's capacity x C rating, you're pushing the lipo too hard.
cmdl is offline Find More Posts by cmdl
Old May 10, 2016, 07:39 PM
Rockin Robbins is offline
Find More Posts by Rockin Robbins
Drone offender FA377YHFNC
United States, FL, DeLand
Joined Mar 2009
Still, for not flying and just being warm to the touch you were okay. Luckily. In general, don't run your motors full throttle for more than a few seconds. Even on systems properly balanced, that can cause red hot stuff to come out of motors and batteries. The red stuff consumes your plane and causes pain when you touch it. Avoid!
Rockin Robbins is offline Find More Posts by Rockin Robbins
Old May 10, 2016, 07:59 PM
cmdl is offline
cmdl's Avatar
Joined Jan 2012
I've run my motors full throttle for a whole minute while on the ground - nothing happens to them. Motors will only fry if they're overamped.
Old May 10, 2016, 08:14 PM
Birds is online now
Find More Posts by Birds
Birds's Avatar
Joined Mar 2016
Why would one do this.??
Birds is online now Find More Posts by Birds
Old May 10, 2016, 09:06 PM
cmdl is offline
cmdl's Avatar
Joined Jan 2012
Run down my lipos when I wasn't able to fly.
Old May 13, 2016, 11:02 AM
Joined Mar 2009
Try it with a Radian, where the motor is surrounded by foam. Believe me, you can fry a motor that is not overamped if you don't have the airflow that normally cools it.
Old May 13, 2016, 11:32 AM
cmdl is offline
cmdl's Avatar
Joined Jan 2012
It won't fry as long as it isn't overamped - the airflow isn't what keeps a motor from getting fried - it helps cool it a bit but that is more useful toward us being able to touch the motors after flying than saving a motor from getting fried.
Old May 14, 2016, 12:41 AM
Ira NZ is offline
Find More Posts by Ira NZ
Bombs away! Err...landing
Ira NZ's Avatar
Upper Hutt, New Zealand
Joined Apr 2006
Originally Posted by Mike_Then View Post
you were asking the battery to produce a lot more power than it does in flight. Most people don't fly full throttle for the entire duration of the flight;.
And in the situation where it draws the most current. Current draw can vary hugely with airspeed. For example my calmato draws about 50 amps static. Maybe a little more.
But full throttle in level flight it will drop down under 20 amps. Shallow dive can get it down into the 15 amp range.
Ira NZ is offline Find More Posts by Ira NZ
Old May 15, 2016, 09:47 PM
James_S is offline
Find More Posts by James_S
United States, WA, Woodinville
Joined May 2014
I have several planes that I frequently fly full throttle for the entire flight, it depends on the style of plane.
I would thoroughly test a battery that was stored for a year at an unknown state of charge. LiPos don't appreciate being stored over or under charged.
James_S is offline Find More Posts by James_S
Sold Original Matrix 785mm quad. Capable of 30 mins flight times Johnnymeg Aircraft - Electric - Multirotor (FS/W) 3 Apr 29, 2016 09:40 AM
New Product Quad Light - 563 gram, 15-17 ich props, 40-50 min flight time carbon_cnc_eu Scratchbuilt Multirotors 31 Mar 24, 2016 11:51 AM
Discussion iDrone 1 with 35-40 min flight time **UPair Chase Competitor** Quadbuddy Multirotor Talk 5 Dec 21, 2015 04:12 AM
Discussion Walkera 5-5 2 min flight time :( Hallsy Coaxial Helicopters 6 Apr 07, 2008 10:39 PM
Discussion Short flight time (3 mins) with Walkera 5-5B HeliDrew Coaxial Helicopters 1 Jan 18, 2008 04:43 PM
