Old Feb 28, 2015, 10:23 AM
KABAL99 is online now
Find More Posts by KABAL99
FRANCE
Joined Dec 2004
Another AIRWOLF
Hi friends
to begin this new thread i would like to ask a Q
Do you think it could be ok to fly an Airwolf Funkey 90 (trex 700 size) with the last new Trex 550 850Kv motor with the good reduction to run the rotor at 1450 RPM??
The purpose is to fly 6 S lipo of course!
has it the power to lift the heli with complete scale (LG, pod, machine gun......)
picture will follow
I forget to explain that it will be my very first scale but like 35 years old people, for me Airwolf has been a very famous heli serie
many thx
KABAL99 is online now Find More Posts by KABAL99
Old Feb 28, 2015, 10:38 AM
FRANCE
Joined Dec 2004
First 2 pics are from the Century website
others come from mine at the very first "what i have to do and how "
I plan to use T REX 600 ESP frame with M BLADES to run a 1.50m rotor .
ADF pod will be DIY and is comming
Lateral machine gun will be DIY and sliding in the wing's fuse
LG is coming too after lot of DIY
Old Feb 28, 2015, 11:02 AM
Keyrigger is online now
Find More Posts by Keyrigger
Love my scale Whirlybirds
Keyrigger's Avatar
Mississauga, Ont., Can.
Joined Sep 2009
Good luck to you with the build. It is not the easiest fuselage to work with when running electric, but it makes on of the best looking Airwolfs out there. From personal experience, you will find that as you start to add your detail, the weight will balloon and your 6s system will not have the overhead to lift the extra weight. I did some calculations based on your motor and the 112t main gear and an 11t pinion (both Mod 1.) and you will have the speed (10t might be possible but no overhead) governed to fly the helicopter.
Most large scale helicopters go with 10 to 12s systems to get both duration and motor power. According to technical specs, my 6s system in my 17 pound TOW Defender should have had lots of power to run it but it struggled when pulling up from a shallow dive or trying a full pitch climb-out. The motor delivered 2700 watts power and when you calculate what it takes to hover it now, that should have been more than enough but once I changed to a 12s 3300 watt system, the lagging power disappeared and it flies like it should. You can use 3300 to 4000mAH batteries which will allow you to use the doors to load them in and there might even be enough room with the 700 size to slide them in from the top. I would highly recommend a full floor be installed rather than the wedges on their own. Hope this helps.
Don
Keyrigger is online now Find More Posts by Keyrigger
Old Feb 28, 2015, 11:08 AM
FRANCE
Joined Dec 2004
YEP
thx for the advices
i was thinking about the same thing for the loss of power of my TREX 550 motor
i will go with a 12 S set up and something like 530 kv motor
I plan to make a total new floor for the mechanic
thx friend
Old Feb 28, 2015, 11:59 AM
Keyrigger's Avatar
Joined Sep 2009
I would drop your motor kv to something like a 400, tops. With you swinging 700 size blades, a scale rotation speed would be something in the neighbourhood of 1350 to 1500rpm. That would be with the 112t main and a 12t pinion. Vibration is the killer of most scale helicopters, mostly as a result of the body picking up resonance from high rotation speed blades which results in some pretty spectacular break-ups before leaving the ground. You could use a 450 (very common 12s motor) as long as you drop the pinion to a 10t and land you right at 1450rpm with the 112/10 gear combination. Lots of solutions. Hope this helps. Take care.
Don
Old Mar 02, 2015, 11:05 AM
FRANCE
Joined Dec 2004
hi
LG modification
it comes from Eurokit , a very cool seller in Italia
you can see the original and then what i cut and drill
last pic shows the front wheel on the left and the 2 lateral LG on the right
wheel will be 45 mm for the front and 50 or 52 mm on the rear
Old Mar 21, 2015, 04:09 AM
FRANCE
Joined Dec 2004
first cutting of the frame and red lines for next cuttings
Old Mar 22, 2015, 12:31 PM
FRANCE
Joined Dec 2004
first test for the floor of the mecanik
made with cardboard box
the wood parts will be cut next week end
Old Mar 22, 2015, 12:59 PM
Keyrigger's Avatar
Joined Sep 2009
It looks like you should have no trouble getting the batteries in and out. Nicely done.
Don
Old Mar 22, 2015, 01:09 PM
FRANCE
Joined Dec 2004
hi
i think i will put the motor battery (2 lipo of 6 S) in each side behind each seat and i will use the standard battery tray for the servo battery
Old Mar 22, 2015, 05:17 PM
JLogan is offline
Find More Posts by JLogan
AMA#313760
JLogan's Avatar
United States, MI, Taylor
Joined May 2009
Yes your going to want to use 12s for this size ( two 6s ) , a 6s setup would be killer on your lipo, motor ect. as far as motor KV, What speed controller are you going to use? A CC 120 HV(80HV) would help with the higher(550 KV )as if you fly govern mode it cuts your top RPM's down to maintain the set RPM's. So maybe that 550kv may work in this case. Out side that you really need a lower KV motor if your going to run flat curves.
John
JLogan is offline Find More Posts by JLogan
Old Mar 23, 2015, 02:32 AM
FRANCE
Joined Dec 2004
I will use a 400kv motor if i find something cheaper than a scorpion because i dont want to buu a 250 $ motor....:-(
Old Apr 01, 2015, 06:10 AM
FRANCE
Joined Dec 2004
last step before cutting
Old Apr 03, 2015, 06:59 AM
FRANCE
Joined Dec 2004
almost done
Old Apr 03, 2015, 07:02 AM
FRANCE
Joined Dec 2004
frame installation
For Sale Fusuno Airwolf Fuselage for 450 Size Helicopters w/Retracts mrforged Aircraft - Electric - Helis (FS/W) 9 Feb 25, 2015 09:52 PM
Discussion Airwolf, Bell 222 or Hughes 500 Canopies for the Blade mCX2? Michael_Blue Coaxial Helicopters 3 Jan 13, 2015 04:36 AM
Help! Help with Setting up for Walkera Airwolf 200sd03 with devo 7 fikriforme Beginner Training Area (Heli-Electric) 5 Nov 02, 2014 12:26 PM
Discussion gads.....another airwolf ltbidrawn Electric Heli Talk 2 Nov 17, 2011 05:14 PM
Rave Another RealFlight G3 Airwolf HurricaneWolf Simulators 1 Mar 28, 2005 11:08 PM
