Old May 21, 2015, 03:01 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Though I don't really like mixes, a low throttle/down elevator mix could be set up, but yes, having the plane a tad bit nose heavy does help in landings..
SteveT.
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old May 23, 2015, 02:36 PM
M.Putnam is online now
Find More Posts by M.Putnam
Shade Tree Aviation #2
M.Putnam's Avatar
United States, NC, Rutherfordton
Joined Jan 2002
58" Edge ready for maiden.
Motrolfly 4315-714
CC Talon 90 w/ bec set to 8 volts
Xoar 15x8
Hitec HS-7245MH servos
Glacier 4s 30c 4000 (Kudos to Steve T. for the battery box which will make battery changes much easier )
Took about 1.5 ounces added to the nose to balance. Programming is done and she looks great. Looking forward to a maiden tomorrow afternoon if the weather cooperates!
M.Putnam is online now Find More Posts by M.Putnam
Old May 23, 2015, 10:30 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
I'm glad to hear you like it Matt!!
SteveT.
Old Yesterday, 08:41 AM
Rich215 is online now
Find More Posts by Rich215
Rich215's Avatar
United States, CT, South Coventry
Joined Jun 2011
Today is maiden flight day!
After the death of my 30cc Aerobeez Slick 540, and the issues of too much noise at our club field, I decided it was time to go electric. After much reading on here I decided on the 58" 3DHS Edge. I must say I'm impressed with it so far. I've assembled planes from Extreme Flight, Redwing RC and Aerobeez and I think the build quality of the 3DHS brand is the better of the bunch.
This one's got the following:
T-Motor 570kv swinging a 15 x 8 APC
Gecko 85 amp ESC
(4) Align DS515M servos
Turnigy 40C 3000mah 6S Battery
Spektrum AR8000 Receiver
CG is right on at 3.75 inches with no added weight to the nose and there's room to move battery to change it either forward or back.
Now I just need to decide on which decals to apply
Rich215 is online now Find More Posts by Rich215
Old Yesterday, 10:11 AM
Potoczak is offline
Find More Posts by Potoczak
United States, PA, Kunkletown
Joined Mar 2015
Looks great let us know how it flys. How do you like the gecko speedo?? Was thinking about trying one.
Potoczak is offline Find More Posts by Potoczak
Old Yesterday, 03:00 PM
M.Putnam's Avatar
Joined Jan 2002
Motrolfly 4315-714
Xoar 15x8
Maiden flights done! I really like the way this plane flies. Power is strong with the Motrolfly 4315-714, but not overkill. Super stable in high alpha. Plane lands itself, no "ballooning" on approach. Might need a tad of mix for knifedge, hard to tell in breezy conditions. Again very impressed.
Old Yesterday, 04:22 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Congrats!! And...I'm glad to hear you are liking the Edge Matt...it is a very good plane IMO...
SteveT.
Old Yesterday, 05:45 PM
Rich215's Avatar
Joined Jun 2011
This thing is a freakin rocket. I'm no 3D expert but once I got past the jitters of the first flight and trimmed it out it was very easy to fly. I flew the first 3 flights without the SFG's then put them on for the 4th. I found they make the plane more stable especially when it is as breezy as it is today. I did find an issue with the ESC. If I go to full throttle too quickly I get what sounds like a knock and pulse from the motor. If I go to full throttle in about a 2-3 second span it's fine. Other than that I really like it. I need another battery though, It's too long between flights waiting for it to charge. I have the timer set for 6 minutes and putting back about 60%. The motor and ESC are a little more than ambient temperature after the flight.
I miss the sounds and size of the 30cc slick 540 but I think I will enjoy this plane. Especially since it fits in the back of my truck without removing the wings.
Old Yesterday, 05:49 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
What ESC?? It sounds like the timing is set incorrectly...
SteveT.
Old Yesterday, 06:59 PM
Rich215's Avatar
Joined Jun 2011
It's a ZTW Gecko series 85 amp. All settings are at defaults.
Old Yesterday, 07:39 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Check and see if you can find out what the timing should be ( if an outrunner) probably 8khz), and then find out what your ESC is set to. If it is not set to 8khz, see if there is a means to do so. That said. a lot of people have been finding the the newer ZTW ESCs have not been working well.
SteveT.
Old Today, 12:33 AM
Brush Hog is offline
Find More Posts by Brush Hog
United States, NC, Smithfield
Joined Jul 2012
Default settings on the Gecko work fine with MFs except there is an issue with some of the Geckos and quick acceleration. Contact Garret? at Altitude hobbies he has a firmware version which will cure it. You do need the program box to flash the esc. I would do it sooner rather than later, getting the knocks when you need throttle fast can end up in a lot of balsa splinters.
Brush Hog is offline Find More Posts by Brush Hog
Old Today, 12:44 AM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Agreed!!
SteveT.
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS Omega 130g NIB 58.00 Shipped boatdoc Aircraft - Electric - Power Systems (FS/W) 9 Aug 28, 2011 09:16 AM
Discussion 3dhs edge 41" edge as second ish) plane? Mr Bloppy 3D Flying 19 Aug 25, 2010 09:43 AM
Wanted Wanted - 47" - 58" 3DHS, EF or Sebart plane paintball_kidz Aircraft - Electric - Airplanes (FS/W) 0 Jan 02, 2010 11:12 PM
Wanted 47"-58" size 3DHS, Sebart or Extreme Flight paintball_kidz Aircraft - Electric - Airplanes (FS/W) 13 Jan 02, 2010 12:52 AM
