Old Oct 18, 2014, 09:08 PM
Buschbarber's Avatar
United States, NY, Rochester
Joined Apr 2004
The motor is the Spinmax 2810-9. I will have to weigh it
Buschbarber is offline Find More Posts by Buschbarber
Old Oct 19, 2014, 07:09 AM
We shall serve the Lord
kingsflyer's Avatar
United States, TX, Kingsland
Joined Sep 2005
Originally Posted by Buschbarber View Post
I have a Polaris Ultra with the stock motor and Master Airscrew 3 blade 8x6 prop running on 3S 3000mah batteries.
I would like more speed off the water and wondered what the hot setup is for Motor, ESC, and Prop.
I started asking the same questions almost as soon as I got mine. I didn't like the idea of using a 4S battery because I already had a bunch of 3S batteries. I finally settled on a setup that would fly with a 3S 2200 30C battery all the way forward in the nose of the canopy area and give me 3 minutes of WOT excitement.
I use the HK NTM Propdrive Series 35-36-1800 motor:
http://www.hobbyking.com/hobbyking/s...dProduct=26486
You will need a 60 amp ESC but you can use your same prop and battery. The best news is that your 3S battery will now sit up under the canopy where it belongs.
I flew my Ultra at SEFF the past two years with this setup and it was the fastest of any other Polaris type planes there. It was faster than the Skippers or even Mark's Polaris and had much better vertical performance. It was the only one I saw that could take off and climb straight up. Mine is on the far left in the picture.
Enjoy!
McD
kingsflyer is online now Find More Posts by kingsflyer
Old Oct 19, 2014, 01:33 PM
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Just stay with the same motor but substitute a two blade 8x4 APC prop and use a 4s battery. That's what I use when I feel a need for speed. Note the need to reduce the prop or you will overload the motor and ESC.
Caution. It will be much faster and you will have to take precautions to avoid control surface flutter. No slop in the linkages is allowed. I lost an aileron when I first flew with this setup and ended up reattaching the ailerons with pin-type hinges. I also beefed up the control horn mounting.
EDIT
Or go to a bigger, relatively high KV motor and suitable ESC and use 3s, as suggested above. Note that the higher current will then require high-C and/or larger battery. You can't get away with 2200 25C, for example. I would not use less than about 3000 30C or 2500 35C for such a setup. The good thing is that the Ultra is big enough to carry a large battery comfortably. You may need to cut out the back of the battery slot to get balance correct.
Either 3s or 4s can work well as long as you make the necessary changes in each case.
Daedalus66 is online now Find More Posts by Daedalus66
Old Yesterday, 08:38 PM
ggrimley's Avatar
United States, SD, Rapid City
Joined Dec 2011
The first two Polari are ready for their maiden flights (hopefully) in the morning.. After they have proven worthy, the rest of the decals and paint will go on... The white one is a kit, the blue one is a parallel build...
ggrimley is online now Find More Posts by ggrimley
Old Yesterday, 09:15 PM
Foam is my friend!!!
NewZee's Avatar
United States, NY, Depew
Joined Mar 2014
Two nice looking birds! Good Luck on the maidens!!
NewZee is online now Find More Posts by NewZee
Old Today, 08:04 AM
Northwest Ohio
Joined Jan 2002
Good luck ggrimley. Just be careful on the maidens with no color on the planes for visual orientation!
Scott
Model Aero is offline Find More Posts by Model Aero
Old Today, 11:20 AM
ttabbal's Avatar
United States, UT, Herriman
Joined Jan 2012
And double check the elevator to make sure it's not reversed!!
ttabbal is online now Find More Posts by ttabbal
Old Today, 12:16 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Models look very good. Props look quite large. Are you using lower KV motor? Usual is 2200 kv with 6x4 APC prop.
Building two in parallel is a very good idea.
Old Today, 04:17 PM
Kit Manufacturer
coreman's Avatar
United States, MA, Southbridge
Joined Feb 2010
Master Airscrew props are really flexible and I have done some testing on them for thrust and amp draw. I would try a DIFFERENT 8x6 prop. Personally, I would try an APC 8x6E and see what you get. I was finding more thrust and less amp draw on a different plane with those two props. I find the MA deform under load
coreman is offline Find More Posts by coreman
Latest blog entry: Off to HHAEFI we go!
Old Today, 10:06 PM
ggrimley's Avatar
Joined Dec 2011
@ttabbal... How about the ailerons, do they matter???. The Blue core Polaris had it's maiden with the ailerons reversed... fortunately he flew straight until he was three mistakes high, then tried to turn left, but rolled right, Twice!!!, but still had time to level out and land. here is the video.
Blue Polaris first flight (2 min 46 sec)
The white (from the kit) flew fine on its first flight, but the second was shortened by pilot error.. ended with broken tail... Here is that video..
Pilot error (0 min 26 sec)
Here is the pic.
