Old Jul 20, 2014, 06:50 PM
Joined Mar 2007
Question
What are the materials used in this mold?
Hi everybody,
sometimes I encounter people building molds like the one in the picture attached.
What materials are used in this mold techinique? Looks like plaster coated with some kind of resin.
Best Regards
edulago is offline Find More Posts by edulago
Old Jul 21, 2014, 03:53 PM
Joined Nov 2004
At a guess it is ultracal faced with epoxy.
AUSELECTRIC is offline Find More Posts by AUSELECTRIC
Old Jul 22, 2014, 08:58 AM
Joined Mar 2007
If you observe, the coat is too thick... Looks like it was applied before plaster... But if resin was applied before, plaster would not bound to resin...
Old Jul 22, 2014, 10:00 AM
Duane
Wazmo's Avatar
No. VA
Joined Nov 2004
There are hydrophobic resins available specifically for this application. They're called plastic faced plaster (PFP) molds. Adtech's ES-221 surface coat epoxy is one.
Wazmo is online now Find More Posts by Wazmo
Old Jul 22, 2014, 07:02 PM
Kevin Matney's Avatar
United States, MI, Monroe
Joined Mar 2000
surface coat
This is the surface coat I use to start my molds. High Temperature Surface Coat (Aluminum)
Kevin Matney is offline Find More Posts by Kevin Matney
Old Jul 23, 2014, 11:35 AM
Joined Mar 2007
Thanks everybody! I was looking for something cheaper and faster. Probably I will go with a fiberglass mold.
Best Regards
Old Jul 23, 2014, 06:26 PM
Joined Mar 2000
I lay half of a mold in 2 hrs and wait over nite to do the next half.
Old Jul 24, 2014, 08:57 PM
Calgary, AB, Canada
Joined Oct 2002
What brand surfacing coat is that Kevin if you don't mind?
Also, have you had any experience re-finishing & buff/polishing that particular resin?
ptxman is offline Find More Posts by ptxman
Old Jul 24, 2014, 09:13 PM
Joined Mar 2000
Resin Service
High Temperature Surface Coat (Aluminum) - HSC302X
I use right out of the mold .But your can sand it and buff if you need to repair it.
Old Aug 19, 2014, 07:00 AM
Joined Mar 2007
Today a receive an answer from the owner of this mold. It was made with urethane called Pro-cast.
Thanks everybody!!!
Old Aug 19, 2014, 10:23 PM
Tehachapi Jim's Avatar
United States, CA, Tehachapi
Joined Jul 2004
Kevin, once you have your first layer of the hi temp resin down, what do you use to continue? I mean do you transition to a different resin? If so what type? Glass, coremat, carbon roving etc.?
Jim W.
Tehachapi Jim is online now Find More Posts by Tehachapi Jim
Question What size bearings are used in t-motor 2206/2208/2212/2216? Helidoc25 Multirotor Talk 2 Jul 04, 2014 12:20 AM
Discussion What sort of landing tapes are you using? - Preparing for an open ALES in May. aeajr Electric Competition Soaring-F5J/ALES/e-Soaring 28 Jan 07, 2014 04:54 PM
Discussion What paint to use in Corian molds sunnybreeze Composites Fabrication 1 Oct 14, 2013 03:57 PM
Discussion What are all the parts used in making an cnc rcniteshrc CAD/CAM 1 Sep 28, 2013 03:39 AM
