Old Nov 23, 2013, 10:28 PM
RCvertt's Avatar
Joined Aug 2007
Originally Posted by crasha View Post
...The radius of the bends in the RDS rods will dictate the control throw. I will bend the rods to suit each surfaces required throw. This also provides full sevo resolution
Bends of 30 degrees will actually double the available stall torque of the servo!
The smaller the bend radius the more torque available...
Very nice build you have started here.
Can you point me to more info on what this RDS rod bending is? I have never heard of it before and would like to understand how it increases the stall torque.
RCvertt is offline Find More Posts by RCvertt
Latest blog entry: Chupacabra sighting !!!
Old Nov 24, 2013, 04:26 AM
Terrain......PULL UP!!!
crasha's Avatar
Joined Feb 2011
Hi Vettster! I have followed some of your builds over the years. Thanks for sharing your knowledge!
A buddy and I did a mock up of the raptor today to get an idea of equipment placement before all the formers are glued in. It is good to have a second set of eyes check for problems. All seems to be going together quite well
Also tested the gears again. My friend was concerned that the actuators were struggling (he mentions this at the end of the vid) but when he tried to stop them retracting using his fingers he could not stop them . Wish I had video of that ! They do slow down and speed up at certain points due to the geometry of the gear
JL F-22 electric landing gear testing (1 min 26 sec)
crasha is offline Find More Posts by crasha
Old Nov 24, 2013, 05:11 AM
crasha's Avatar
Joined Feb 2011
Hi RCvertt
I am no expert in RDS but have wanted to try it for a long time. It is usually used in scale warbirds or dynamic soaring gliders. I have never seen it used around here. I may need to test it first in an EDF.
You can purchase the couplers from servo city. Here is some light reading which explains how it all works. The rod bending I was talking about refered to the angle of the bend in the rod used for each surface
http://augiemckibben.tripod.com/site...IVE_SYSTEM.pdf
RDS overview (3 min 0 sec)
Old Nov 24, 2013, 11:14 PM
RCvertt's Avatar
Joined Aug 2007
Thanks for the RDS info. Very informative and looks like a good system to try out.
The gear on that raptor are looking fantastic. Good idea going with electric instead of pneumatic.
Old Dec 05, 2013, 01:51 AM
crasha's Avatar
Joined Feb 2011
Well I have put another 20 hours of work into the raptor without much to show for it
Most of the work has been composite reinforcing. The gear mounts are reinforced with kevlar and some carbon on the main mount. All the formers which have structural mounting brackets for wings/stabs have been laminated in fine fibreglass
Also had to fabricate some formers to strengthen up the joint in the fuselage (these were not in the kit!)
Starting to glue in some of the formers in the fwd fuselage section
Old Dec 08, 2013, 07:51 PM
RCvertt's Avatar
Joined Aug 2007
Good work.
Are those white canisters for pneumatic air retracts? I thought we agreed to use electronic ones for my first flight.
Old Dec 10, 2013, 03:17 AM
crasha's Avatar
Joined Feb 2011
Good work.
They are air canisters that will be used for the brakes. I will either plumb them in parallel for the brakes or maybe use one for a functional tailskid later on using one of the gear rams I have removed to operate the skid
Old Dec 27, 2013, 07:37 PM
jeta1's Avatar
Australia, WA, Perth
Joined Apr 2011
Nice build mate you are going to have one sick jet at whiteman.
Rob
jeta1 is offline Find More Posts by jeta1
Old Oct 15, 2014, 02:15 PM
crasha's Avatar
Joined Feb 2011
Finally back to this build thread. Lots of raptor work has been done, there was a huge amount of composite work done to the airframe. Gluing the formers in took weeks of test fitting to make sure everythig lined up properly!
For now it is being test flown in primer to set it up properly before going to all of the work of painting. I did airbrush the exhausts though so at least it sort of looks right
Old Oct 15, 2014, 02:23 PM
crasha's Avatar
Joined Feb 2011
Fuel tank set up. Two main tanks in parallel each with their own surge/taxi tank. Total fuel load 4 litres.
Taxi tank mounts are 3D printed
Old Oct 15, 2014, 02:29 PM
crasha's Avatar
Joined Feb 2011
Wiring and turbine installation. For the maiden it flys in primer without the gear doors. The gear doors will use lado elec actuators when fitted
Old Oct 15, 2014, 02:38 PM
crasha's Avatar
Joined Feb 2011
Ready to test fly! The maiden flight had a scary takeoff due to the elevator needing more up trim. In the air it flew perfect and needed no aileron or rudder trim which was surprising. On the maiden it was a little sensitive in pitch control. After adding more expo, reducing the throw and shifting the CG forward a few mm it is now rock solid!
Maiden flight vid
Jetlegend F-22 Maiden flight (8 min 42 sec)
Old Oct 15, 2014, 04:42 PM
crasha's Avatar
Joined Feb 2011
Vid of the 5th flight. Adjustments have been made each flight and it is almost setup. A few more flights and it should be perfect.
It was a great flight until I landed a little too fast in the cross wind. This is the first crappy landing the raptor has done and I am glad I went to the trouble of reinforcing the gear mount. No damage was done. I still need to work on the high speed ground handling and the brake settings
Jetlegend F-22 5th flight (7 min 2 sec)
Build Log F-22 Depron Detailed Build, Plans and Video restie Foamies (Scratchbuilt) 281 Jul 21, 2014 10:01 AM
Discussion Andrew's F-22 Raptor andrewboktor Foamies (Scratchbuilt) 8 Apr 09, 2013 06:19 PM
Sold JetLegend F-16C 1:8 Fighting Falcon ARF Molded Jet w/scale Retracts hobbyclub Aircraft - Fuel - Jets (FS/W) 1 Jan 06, 2013 09:13 PM
Alert JetLegend F-16C Fighting Falcon ARF Molded Jet w/scale Retracts hobbyclub Fuel Jet Talk 0 Jan 05, 2013 07:32 PM
Help! Can you help me?[JetSet44's F/A-22 building] D@CMOS Pusher Prop Jet Models 2 Sep 18, 2007 07:28 AM
