Old Feb 25, 2013, 02:08 PM
Joined Jul 2011
Boscam GS920 with T8FG headtracking
hi, I just received a FPV goggles from HK for 350 dollars and it says Boscam GS920 on the box. I've been searching for info on this goggles on the net but couldn't find anything about setting up the head tracking on this. I'm trying to get the head tracking working but don't know where to start. I have a Futaba T8FG and using R6008HS RX. i know the manual said to use channel 5 and 6 but i'd like to use channel 6 and 7 cuz i need channel 5 for autolevel on my KK2 board. Any help with setting up the headtracking step by step would be appreciated and thankyou.
BouncingProtos is offline Find More Posts by BouncingProtos
Old Feb 25, 2013, 02:22 PM
barok's Avatar
Joined Apr 2006
for HT thru the training port(square plug).. you have to enable the training switch and assign those channel..
barok is online now Find More Posts by barok
Old Feb 25, 2013, 08:35 PM
Joined Jul 2011
Ive gone to FUNCTION and set channel 7 & 8 CTRL to SG switch instead of the trainer switch. Then i went to TRAINER and set to FUNC 100% on both 7&8 channel. I hooked my goggle thru the trainer port of my radio. Turned on my radio then my goggles, then turned on my pan tilt last. Nothing..... Pan tilts when i flip the switch but doesnt move ehen i move my goggles around. Did i miss something?
Old Feb 26, 2013, 07:39 AM
barok's Avatar
Joined Apr 2006
use the trainer switch..
use a rubber band to keep it turned on..
Old Feb 26, 2013, 03:39 PM
Joined Jul 2011
I finally got some progress. I went to TRAINER and set channel 7 to MIX with channel 5. Pan is working now but no tilt. I went to TRAINER again and set channel 8 to mix with channel 5 but still no tilt. I know its something simple but its hiding from me.
Old Feb 26, 2013, 11:06 PM
Live FPV or Die
VRflyer's Avatar
Montreal,Canada
Joined Feb 2002
Do you have a screen on your Fuataba radio that show bar graph for each channel?
per example if you move the aileron stick, you see the bar move on your radio screen. When the headtracker work properly, you see the bar moving on this screen. It could help to find the problem
VRflyer is offline Find More Posts by VRflyer
Old Mar 01, 2013, 09:49 AM
Joined Jul 2011
I can only get pan to work, no luck with tilt. I have seem one video of this guy setting for pan with the same radio (tx) and goggles but he didnt setup for use of tilt. Im starting wonder if this goggles only has pan HT. it doesnt say anything on the manual but head tracking
Old Mar 02, 2013, 08:35 PM
Joined Feb 2013
Where did you buy them from for $350??
wayward is offline Find More Posts by wayward
Old Mar 05, 2013, 09:06 AM
Joined Jul 2011
I got it from hobbyking
Old Apr 29, 2013, 02:10 PM
Too many numbers
United States, IL, Lake in the Hills
Joined Oct 2010
Did you ever figure this out? If not, let me know.
c131frdave is offline Find More Posts by c131frdave
Old Oct 04, 2013, 08:40 AM
Joined Sep 2010
You can set ANY channel to work with the tracker via the trainer menu.
Boscam Goggle does have PAN and TILT.
The manual says Ch 5 & 6 but that is JUST AN EXAMPLE.
Sorry if this sounds like a hacked tutorial but you really need to understand several basic concept. Somebody please correct me if I am wrong.
1. For safety reason, trainer function usually turned on when you hold the SH switch. But you can set it to ANY switch you like.
2. You can set any channel to any switch (and mix it, whatever) in your T8FG. Thats the reason why you pay so much for that transmitter: because its computerised.
3. The goggle can send its signal (PAN & TILT) to any channel (1 to 8) you like. You can choose and set it up from the google menu.
Official tutorial: http://www.rc-cam.ru/manual/GS920_ma...o7ektv1355elu2
Now for a little additional tutorial.. I set mine to work for Ch7 and Ch8, btw.
1. in T8FG: SYSTEM > TRAINER // page 2/4 looks like this
5 GEAR OFF
6 VPP OFF
7 AUX5 NORM
8 AUX4 NORM
Note that GEAR, VPP, AUX, whatever is almost just a label.
You can set any channel to be ANYTHING you like in the Function menu.
But thats beyond this "tutorial"
Just remember that you might have different label and thats ok.
2. in T8FG: SYSTEM > TRAINER // page 4/4 looks like this
ACT OFF
SW SF
12/8CH 8CH
Note that ACT only have to options: INH (means not used) and ON/OFF
The above example (OFF) means I haven't switch it on.
SW is basically what switch you want to use to turn it on/off
Default was SH, but I want to use SF. You can change it to ANY switch you like.
3. in the goggle menu.. I set
[2] PAN CH SELECT CH7
[3] TILT CH SELECT CH8
You can experiment with PAN RANGE, TILT RANGE and stuff like that
Thats about it really.
Remember that you have to turn it on for the trainer system to work.
And the power button on the goggle double as "reset button". Because the gyro will drift and if might be confusing and you need to reset your "normal position". You'll understand once you press it and see how it works.
NOW.. for the love of god..
I still don't understand the concept of HOW TO REVERSE the movement.
I have correct tilt but my pan is reversed.
I tried to reverse the channel on Tx but that doesn't seems to affect the trainer signal.
Help, anyone?
stormizer is offline Find More Posts by stormizer
Old Oct 04, 2013, 11:56 AM
United States, KY, Morehead
Joined Jan 2005
Help, anyone?
I don't know on the 8fg but on the 12fg you change it in the trainer menu your pan & tilt channel need to be set to FUNC then you can change the rate to -100 to reverse the travel for that channel. I would assume the 8fg has the same trainer options.
skew is offline Find More Posts by skew
Old Oct 11, 2014, 08:07 AM
dagob's Avatar
The Netherlands, NH, Amsterd„
Joined Feb 2006
Boscam GS920 & Flysky FS - TH9x
Does anyone know if this goggles can work with Flysky TH9x transmitter? thanks in advance
dagob is offline Find More Posts by dagob
Wanted Headtracking mount with camera and servos sprokus FPV Equipment (FS/W) 0 Feb 01, 2013 08:47 AM
Discussion Comand the gier with the headtracker Reichegger Multirotor Talk 1 Jan 25, 2013 12:22 AM
Sold Fatshark rcv922 base goggles with headtracker bherbstreit FPV Equipment (FS/W) 3 Jan 22, 2013 09:43 AM
For Sale Logitech Webcam Sphere with Mic and HeadTracking RCSwitz18 Non R/C Items (FS/W) 1 Jan 20, 2013 09:48 AM
Discussion Video Transmitters Boscam TS35? 400mW vs Boscam TS352 500mW WhiteNite1971 FPV Talk 0 Jun 17, 2012 05:56 AM
