Old Today, 03:42 PM
Not as Good as The Kid
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
A rat tail file, like the one I sharpen my chainsaw with, would probably solve it easily. A few mm off the former should do the trick, maybe. Just go in through the fuse hole.
Aeroplayin is online now Find More Posts by Aeroplayin
Old Today, 04:44 PM
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Originally Posted by Aeroplayin View Post
Yes, I know, but this is the actual reality if you take the time to look at what's really happening with the geometry. If Steve is seeing something else, then maybe we have different versions, but this is what I see when I follow the actual path of the cables. I've discussed this in PMs with others here and I'm fairly certain they see the same thing, although this drawing may be a bit exaggerated to make my point visually obvious.
No...he said he was going with drawing "A" which does not cross the cables, and will make the cables rub on the fuselage. Drawing "B" (the one you are showing) is the one that should be used with the 74" Edge..
SteveT.
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Today, 05:06 PM
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
SteveT.
This is what I was referring to when I mentioned your post, Steve. I did have an issue with rubbing on "Drawing B" as in my illustration, because the cable had to wrap around the former to go through the cable holes in the fuse and connect with the provided rubber control horns. Not a big issues but does take a little modification to get it right. A rat tail file will probably take car if it if you want it to be perfect.
I had/have no problems with mine, and did exactly as the instructions show (which is the same as drawing "B").
Old Today, 05:17 PM
SteveT.'s Avatar
San Jose, CA
I don't understand why you would (and I'm not saying you didn't), and I didn't. As far as I know there has only been one version of the plane. Just out of curiosity, what length servo arm are you using? I am using a 2.5" offset, perhaps, if you are using a longer one, that is the difference.
SteveT.
Old Today, 05:28 PM
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
I tried the 2.5 arm at first, and it was worse. If you look my drawing, you can see how the geometry of the shorter arm makes the angle to the former lower, making the turn around the former even more pronounced.
Old Today, 05:31 PM
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
This all really makes me wonder how so many 74's got off the ground, or any planes for that matter.
Slack in one cable is no big deal....almost every plane I've ever flown had it... If I were building a pattern plane for competition I may.....MAY get that serious into overthinking it.
However....I must offer this disclaimer....some of us (like me) don't attack these small details...we just build it and fly...there are other more important details like throttle linkage that I DO worry about....but not this.... Others actually enjoy working out these details....so, if that's you....have fun!!
But...it's also worth presenting the whole picture for those "LESS" detail minded.....but equally paranoid new builders out there....when you see this level of personal dedication to the perfect build....don't just assume you MUST also go into this level of detail on your build.
Now for a different detail that cannot be overlooked....tighten the wing bolts...
build on...
Bivens is online now Find More Posts by Bivens
Old Today, 06:01 PM
SteveT.'s Avatar
San Jose, CA
You are correct, it would...but...and I don't mean to sound like a broken record, but I didn't have this problem...don't know why, but I don't...
SteveT.
Old Today, 06:04 PM
SteveT.'s Avatar
San Jose, CA
build on...
And remember to install the wing tube....I know, you're going to say..."How/why would you install your wings without a wing tube"....but there is a young man here in one of the 3DHS forums that tried to fly without one..
SteveT.
Old Today, 06:10 PM
ex-noob
Lardog's Avatar
Sammamish, WA, USA
Joined Jan 2010
Sounds like the kid at my field that flew the first 3 flights of his new gasser with just straight gas, no oil added!
Fortunately, it didn't end up in disaster, as I would expect trying to fly without a wing tube would.
Lardog is online now Find More Posts by Lardog
Old Today, 06:18 PM
SteveT.'s Avatar
San Jose, CA
It did.....
SteveT.
Old Today, 06:19 PM
If it has wings it will fly...
ckleanth's Avatar
United Kingdom, England, Birmingham
Joined Mar 2011
SteveT.
No if you have a perfect setup crossing the cables or not does not have an affect for A and C setup. the reason is explained here
build on...
well, when I started with rc planes there were no ARF stuff so I did get into the hobby by actually building planes (and flying them). As an engineer attention to the details and how things work on the plane is important (at least to me)., The 3D bug came later
ckleanth is online now Find More Posts by ckleanth
Old Today, 06:36 PM
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
It was really not a big deal,l and I was only answering a direct question. I was never implying that the design was flawed because there are quirks to all ARFs. The reason why this issue is not a big deal is because the geometry gets "better" as the rudder is turned, since both the arm and the horn lengths perpendicular to the fuse median actually "shorten", taking the former out of the equation. So there isn't a lot of rubbing if you leave it alone, or at least not for too long. Even a slight amount of slack in the cable is no longer an issue at this point because the tension is on the cable that is pulling.
As I said, I left it the way it was and only added another 1/4 inch to the servo arm, whicj makes the geometry a little better. IMO. I have many hard flights under extreme power with no issue, and the videos I posted will show the level of abuse I'm talking about.
I love the plane and would find it hard to be without one, and this is a small, but undeniable, quirk that has an easy resolution if it bothers anyone.
Old Today, 06:47 PM
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
I did build my own planes too, and invested many many hours at the bench, as part of my love for that part of the hobby, at the Godfrey workshop. Those planes were part of TOC and IMAC royalty, so believe me when I say that detail was in every part and assembly process. Jesky, Leseberg, Quique, and Hyde, were all part of that history, but for me, it is history, and I have no time or desire to spend that much time building big airplanes anymore. I like EF and 3DHS planes, and that's about it.
Old Today, 07:54 PM
ckleanth's Avatar
Joined Mar 2011
dont you just love it when you get it wrong.
guys crossing the cables for A and C setup will not be the same, you will still get a slack on one side. if the wires do not cross and you have a "perfect setup" then you wont get the slack.
edit: there is no scaling, the numbers are purely for comparison
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS 41" Edge 540 PNP $225 gonzoman5 Aircraft - Electric - Airplanes (FS/W) 10 Oct 05, 2011 10:53 AM
Wanted 3dhs Edge 540 47" (red bull scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 13 Sep 29, 2011 02:19 PM
Wanted 3DHS Edge 540 47" (Red Bull Scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 0 Sep 24, 2011 01:58 AM
Wanted 3dhs edge 540 47" (red bull scheme) vhuang168 Aircraft - Electric - Airplanes (FS/W) 2 Sep 08, 2011 10:13 PM
