Closed Thread
Old Jun 07, 2014, 05:49 PM
United States, TX, Houston
Joined May 2003
Question
What size die for making controll horns
I want to thread a brass rod so I can make my own control horns for a Nan Shadow. Should I use a 3mm 5 die or a 3mm 6 die so it fits the inserts in the flaps and ailerons? I believe the 5 & 6 designations are for fine and course threads. As for the bar stock, should I use 3mm brass rod and run it through the die?
S Gibson
Hoot is offline Find More Posts by Hoot
Old Jun 07, 2014, 07:37 PM
USA, CA, Visalia
Joined May 2007
The tap I use to clean the threads is a 3x0.5.
galenreed is offline Find More Posts by galenreed
Old Jun 07, 2014, 11:38 PM
Some people call me Maurice
vespa's Avatar
Thousand Oaks, CA
Joined Mar 2004
Hoot,
First of all, just buy the horns. They are sold everywhere.
Second, 0.5 is the standard pitch for M3 and yes, 3mm OD rod is correct.
Third, you'll want to start with 4-5mm rod, turn it, thread it, mill it, then drill it. Or just but the horns already made.
vespa is online now Find More Posts by vespa
Closed Thread
Wanted XL Control Horns for hs-65 mg sized servos JGAF Aircraft - General - Miscellaneous (FS/W) 0 May 05, 2014 03:32 PM
Question What size spur gears do they make for traxxas stampede bug1 Off-road Cars 15 Feb 22, 2014 11:01 AM
For Sale Die Cut Control Horns lv2soar Aircraft - General - Miscellaneous (FS/W) 2 Apr 01, 2010 10:05 AM
What side for rudder control horn on DLG? JOLOVINS Hand Launch 10 Jan 26, 2005 07:11 PM
Flying on the cheap - what to use for control horns and rods? fprintf Foamies (Kits) 5 Apr 14, 2002 12:48 AM
