Old Nov 23, 2014, 03:40 PM
Lou
Ground Penetration Tester
United States, VA, Waynesboro
Joined Dec 2005
Question
Where to buy .047 threaded couplers?
I need a handfull of the .047 threaded couplers that come with the Dubro Micro Clevis package. But I do not need the rest of the stuff in the package.
Any idea of where these can be bought in a quanity of 25 or more?
thanks,
Lou
Lou is offline Find More Posts by Lou
Old Nov 24, 2014, 09:30 AM
Stu48's Avatar
United States, VA, Fredericksburg
Joined Jan 2014
Kavan (Germany) makes 2mm threaded couplers with a 1.2mm inner barrel diameter to fit 1/32" wire push rods. SIG is listed as the US dealer. I didn't see them on SIG's website but they may be able to get them if this is what you are looking for.
Stu48 is offline Find More Posts by Stu48
Old Nov 24, 2014, 12:25 PM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
These ? --
Dubro 2mm Threaded Couplers
eflightray is offline Find More Posts by eflightray
Old Nov 24, 2014, 06:59 PM
LesUyeda's Avatar
San Diego, California
Joined Dec 2004
According to my Screw guide, .047 diameter is #0-80 size.
Les
LesUyeda is online now Find More Posts by LesUyeda
Old Nov 24, 2014, 09:59 PM
KE your cub.
Curare's Avatar
in the gutter, again....
Joined Jun 2005
Having a look around it donesn't look like you'll be able to buy the couplers separate, at least not from du-bro.
At the risk of throwing a spanner in the works, is there a specific reason you want to use a threaded clevis? Is getting the pushrod length perfect that big a problem?
The reason I say this is that for small control surfaces, a simple wire pushrod with a "z" shaped kink will give you enough adjustment to get your controls aligned, for a fraction of the weight, and cost.
Of course I understand though that sometimes running a system like this is completely impractical, and a threaded adjuster is the only way.
Curare is offline Find More Posts by Curare
Old Nov 25, 2014, 07:50 PM
Lou
Joined Dec 2005
Thanks everyone. Yes, these are a bear to find and I do appreciate everyones help.
@Stu48 ... thanks for the Kavan idea. I forgot about them. I will take a look at their site and see what they have.
@Curare .... nope, not uber critical but I wanted to use the .047 as opposed to the .032 on a two meter powered glider. The .032 will work but I wanted just a bit bigger wire for safety sake and less possibility of flex. I am over cautious to a fault often.
@eflightray .. this is the Dubro package the part comes in ...
http://shop.dubro.com/p/micro2-clevi...47-2-pkg?pp=12
I really like this .047 size for gluing into CF tube as it is a bit of a better fit than the .032 kit. The 2mm coupler would work and to save weight I could shorten the threaded end but I would also need to increase the size of the CF tube.
I may just call Dubro or email them and see if they will sell coupler separate. I use this size more than anything else.
Thanks everyone.
Discussion Thread Crapping VS. Exposing Price Gougers (Where's the line?) naeseth Trader Talk 155 Today 07:01 AM
Discussion Where can I buy a servo threaded rod bar? angelillogr Robotics 0 Nov 10, 2011 07:02 AM
Question Where to buy pushrod tubing for .032 & .047 wire? Phiber Optik The Builders Workshop 2 Dec 05, 2005 12:35 PM
Question Where to buy 6-32 Aluminum Threaded rod Orion_V The Builders Workshop 4 Aug 02, 2004 02:55 PM
Where to buy Kevelar thread? War Bird Radio Modeling Science 25 May 28, 2004 03:54 PM
