Old Feb 03, 2014, 10:18 AM
The Fixer
Martin Y's Avatar
Canada, ON, Milton
Joined Jan 2009
Originally Posted by PhilF51 View Post
Hi Martin Y. I think the same regards "slim wing servos" cut out wings to suit!
How did you get round the issue of fixing the stabiliser other than epoxy and self-tapping screw and passing the elevator servo lead through to the fuselage? Have to bear in mind that some day might need to remove the stabiliser to replace servo extension or lead......
Hey Phil
I installed blind nuts through the rear tail wheel hole. Taped a flat magnet at a 45 to a square piece of wood. Put a bright white led into fuse to see. Inserted to where the hole was then put on screw with washer and tightened slowly till nuts sunk into wood. For the servo I removed the leads from the connector. Opened the hole in the stab a bit more. Feed wires through and put back into socket. Had to open the hole for the extension lead as well (made it square) in the fuse.
Martin Y is offline Find More Posts by Martin Y
Latest blog entry: Flyfly Fox Glider
Old Feb 16, 2014, 01:36 PM
Joined Aug 2012
Originally Posted by Martin Y View Post
Mine is almost done. Hatch covers are good for the 9G servo's other from that not. No stabiliser screws or blinds nuts installed from factory . Had to cut out wings for slim's to fit properly. Added reinforcement to the wheel as it would have ripped out first time.
Wing servo's I went with -
http://www.hobbyking.com/hobbyking/s...idProduct=8956
Elevator servo -
http://www.hobbyking.com/hobbyking/s...idProduct=8760
Motor - http://www.hobbyking.com/hobbyking/s...dProduct=18165
This one nicely strong and quite.
Motor Pod I used with reinforcement above back windows -
http://www.hobby88.com/shop/product_...roducts_id=342
new wheel
EFPLC is offline Find More Posts by EFPLC
Old Feb 24, 2014, 05:34 AM
Christchurch UK
Joined Mar 2008
Hi Martin. I decided on locating pins for stabiliser and then epoxied it on. Then just forward of the stabiliser leading edge and just below, I cut out a mini servo hole in the fuse, glued small pieces of 5mm ply behind to take the servo screws. Servo is Hitec 225MG. I used my own 2mm hardware to connect. The rudder is using closed loop wire set-up. Rudder servo in pre-cut position (Spektrum A6000)
Using HS125 Slims for flaps, installed after a bit of cutting about but stuck momentarily for two more HS125 Slim Wing servos for ailerons (back order)
I used the fly fly horns throughout but the rest of the hardware I junked
In the meantime I will install the AR7610 RX and set up flaperon system on the DSX9 using dummy servos for ailerons temporarily. Each servo has it's own channel. Not sure yet wether to motorise it or slope only
PhilF51 is offline Find More Posts by PhilF51
Old May 11, 2014, 05:57 AM
Certified Power Juicer
Jack_LaLanne's Avatar
Germany, Berlin
Joined Feb 2009
any chance this can be had from within europe?
hobby88.com:
255.90 USD shipped plus 19% VAT = 303.62 USD for me
a bit on the expensive side
Jack_LaLanne is offline Find More Posts by Jack_LaLanne
Latest blog entry: FlyFly Hobby ASW28
Old May 11, 2014, 06:22 AM
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
hobby88.com:
Definitely Jack, lots of dealers (particularly in the UK) carry FlyFly (I'm sorry, I can't remember which)..
Woodstock 1 is offline Find More Posts by Woodstock 1
Old May 11, 2014, 06:26 AM
Joined Dec 2005
http://www.gliders.uk.com/products.asp?dept=219
http://www.sloughrc.com/default.asp?...temid=A-FFB016
Old May 11, 2014, 08:02 AM
Germany, Berlin
Joined Feb 2009
Thank you woodstock. It seems like I won't get away any cheaper than ordering directly from Hong Kong.
Old May 11, 2014, 11:16 AM
Joined Dec 2005
There must be Dealers on the Continent that do Fly Fly.... Or is this also a Hobby King model, in which case maybe in the European warehouses?
Old May 11, 2014, 11:19 AM
The Fixer
Martin Y's Avatar
Canada, ON, Milton
Joined Jan 2009
I got mine direct from hobby88. Not to many dealers around I could find without getting dinged heavy for duties.
Old May 11, 2014, 11:55 AM
Joined Dec 2005
Sorry, I meant the European Continent...
Old Jul 05, 2014, 09:49 PM
airborne2.4's Avatar
The Bahamas, Freeport
Joined Jul 2009
Great price http://www.airshowrc.com/electric_gliders_fly_fly.html
airborne2.4 is offline Find More Posts by airborne2.4
Old Jul 07, 2014, 03:33 PM
United States, TN, Knoxville
Joined Jul 2013
wheel
EFPLC, can you explain what you did with the wheel mod? I've eaten two tires on two flights.
skyduck is offline Find More Posts by skyduck
Old Jul 07, 2014, 05:05 PM
Dean
A10FLYR's Avatar
USA, CO, Littleton
Joined Apr 2005
Originally Posted by airborne2.4 View Post
Did anyone notice how long the 4 meter DG 808 is? 137.8 inches!!!
A10FLYR is online now Find More Posts by A10FLYR
Question Flyfly 3m fox info required yakhakker Scale Sailplanes 2 Feb 06, 2012 03:46 PM
Question Fox EPO glider 2.3 from HK will it fly safely with this specs? seedo Foamies (Kits) 0 Jan 30, 2012 11:56 PM
Discussion Airfield Fox 2.32 meter electric glider. DWA Slope 1 Aug 12, 2011 04:14 PM
Discussion New releases by flyfly hobby-3 Metre fox , 2.6 Metre ask21 gliders Damian Couzoff Australia 12 Jul 26, 2010 05:11 AM
