Old Jul 25, 2014, 06:36 AM
ukbren's Avatar
United Kingdom, Derbyshire
Joined Aug 2011
someone posted links to retailers on the previous page
ukbren is offline Find More Posts by ukbren
Old Jul 25, 2014, 07:35 AM
Madison, MS
Joined Oct 2006
Originally Posted by birdseed View Post
Can someone provide a link to where you can currently purchase these fans?
(I need two for a LX f18)
http://donsrc.com/cart/index.php?_a=...product_id=139
Or
http://www.x-flight.com.hk/index.php...&submit_y=-261
dpowellmeii is offline Find More Posts by dpowellmeii
Old Jul 25, 2014, 09:22 AM
Madison, MS
Joined Oct 2006
Does anyone have a Wemo MF 002-4 adapter they can measure for me? I have the Wemo MD 002-4 and I know they fit the CS10 perfectly and want to know what the differences are.
Thanks.
Old Jul 25, 2014, 09:58 AM
EDF rules... :)
AirX's Avatar
Joined Nov 1999
I am using Tamjets adapters, though Extreme has excellent adapters also.
Eric B.
AirX is offline Find More Posts by AirX
Old Jul 25, 2014, 10:01 AM
Madison, MS
Joined Oct 2006
Eric B.
Thanks but I prefer the wemo's. I've had excellent results with them.
Old Jul 25, 2014, 12:12 PM
EDF rules... :)
AirX's Avatar
Joined Nov 1999
The CS10 has an 8mm shaft adapter.
I dont think Wemotecs will fit.
Eric B.
Old Jul 25, 2014, 12:47 PM
Madison, MS
Joined Oct 2006
Eric B.
Thanks, I know the size of the CS10 as I have several of them. I also have the Wemo MD 002-4 adapters that I use on CS10 as stated above so I know they will fit.
What I would like are the measurements of the Wemo MF 002-4 to see if that one will fit since it has a hole in it for you to brace it with a screwdriver while tightening the rotor nut. I know that this adapter fits a 4mm shaft, hence the -4, could someone provide the shaft o.d. and length?
Thanks.
Old Jul 25, 2014, 03:11 PM
Aka: Tom Jenkins
ApexAero's Avatar
Palm Beach County, Fl.
Joined Aug 2008
Shaft grip and tightening tip:
Find a set screw that fits the spinner screw thread of your adapter and screw it in about 1/8 deeper than the shaft end,
Use your Zona Saw or Dremel and cut a groove/slot through the end, blow out the shavings, ad a drop of machine oil then extract the set screw with your allen key and clean up! Now you got a slot for your screw driver soaz yew kin tyten yer fan nut brotha! (Same thing if drilling a thru hole)
ApexAero is offline Find More Posts by ApexAero
Old Jul 25, 2014, 11:13 PM
Madison, MS
Joined Oct 2006
Good info, thanks. I've drilled a hole in a couple of my Wemo adapters. Just trying to save an extra task.
Old Aug 11, 2014, 01:28 AM
manuel v's Avatar
Mexico, BC, Mexicali
Joined Aug 2004
My first motor Hofman beast EDF motor.
Rewind to 12T, 20AWG, 55 in wire,
No load.
1.78A, 11.25V, 19750 rpm, 1755 Kv.
With EDF Changesun 70mm 10b.
4slipo. 22.75A, 14.43V, 23,800rpm, 94% NLS.
6slipo2200ma ., 41A, 21.83V, 33,000 rpm, 86.1% NLS. 895 watts.
(two 3slipo pack in series.)
Thrust was not measured, but maybe over 1400 g.
This is a very inexpensive combination for a foamy EDF.
Unfortunately it seems that this motor is no longer available.
http://www.rcgroups.com/forums/showthread.php?t=1964974
Manuel V.
manuel v is online now Find More Posts by manuel v
Old Aug 11, 2014, 07:32 PM
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
I get 33K+ rpm from the 2W25 at 870 watts so is it really worth rewinding what was a fairly expensive motor before they were cleared out? Not knocking you just saying 33K rpm is 1.4kg thrust in round figures.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Aug 11, 2014, 10:59 PM
chuck
santa barbara, CA
Joined May 2009
at 1 time not long ago they were cheap like < 20 bucks but at the kv they were i can see why they had trouble getting rid of them .....a real battery bbq
so in that respect maybe the quality bits and bearings? would make it worthwhile rewinding.
chas650r is offline Find More Posts by chas650r
Old Aug 12, 2014, 02:14 AM
manuel v's Avatar
Joined Aug 2004
Possibly the last motors that were sold,
I could buy 2 motors for only 27 dlls including shipping.
1.4 kg is fine for my model.
I thought it was 1.5Kg or more according to data published by others on this forum.
I did a test with EDF mounted on a Starmax F5 today.
22Volts, 45A, 990 watts.
My second motor:
I test inside starmax F18 rewind (13t, 1678Kv.) in 70mm XRP 14b EDF.
6s 2200ma, 42.5A, 22.5Volts, 956 watts.
Manuel V.
Old Aug 12, 2014, 05:35 AM
Extreme_RC's Avatar
Australia
Joined Mar 2006
For sure at the price if you can rewind them to a usable Kv they are a good option. I did a lot of testing with the 10b and 1.42-1.45 is what I saw at 33,200-33,500rpm.
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7081 Jul 28, 2014 08:25 AM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
