Old Jul 21, 2014, 08:57 PM
DanWard is offline
Find More Posts by DanWard
Deer Park, Tx (East side of Houston)
Joined Oct 2009
Help!
So what do I do now, shorter DLE standoffs?
So this is my first 1/4 scale gasser...a lot of firsts...please see supporting pictures.
The cowl has a former that is supposed to butt up to a former on front of fuselage.
I cut the cowl until it slipped past engine and the two formers butted together.
But now it appears as if I have way to much prop shaft sticking through front of cowling. I might end up with a 5/16" gap between cowl ring and back of prop spinner. That can't be right, can it?
So I guess I ditch the stock DLE35RA 60mm standoffs and start shopping for shorter ones, assuming there are shorter ones to be bought. Is there?
Shorter standoffs would probably mean cutting a larger hole in firewall for carburetor to plunge partially through firewall, right?
I have no idea what I am doing and no friends that fly or build this sort of plane so any and all help that the group can provide is appreciated.
DanWard is offline Find More Posts by DanWard
Old Jul 21, 2014, 11:31 PM
bigblueswope is offline
Find More Posts by bigblueswope
bigblueswope's Avatar
United States, GA, Loganville
Joined Aug 2012
At 200 feet you'll never notice it. Prop it up and burn some gas! ;-)
bigblueswope is offline Find More Posts by bigblueswope
Old Jul 22, 2014, 06:26 AM
gene6029 is offline
Find More Posts by gene6029
gene6029's Avatar
Wilson NC 27896
Joined Apr 2009
Another possibility is to move the firewall back the amount you need. Yes, there are shorter standoffs out there, or you can get custom ones made, but you will have to cut a larger hole into the firewall to allow the carb to set back into. It shouldnt be too difficult to cut off the firewall & move it rearward. You can install tristock behind the firewall & pin the firewall with dowels. Reinforce everything with glass & it will be stronger than new. .Gene
gene6029 is offline Find More Posts by gene6029
Old Jul 22, 2014, 07:14 AM
tacx is offline
Find More Posts by tacx
tacx's Avatar
United States, MI, Romeo
Joined Apr 2009
If you are not experienced in building I don't suggest messing with your firewall. From your pics I think you should get shorter standoff. It looks like you have enough rearward movement to lesson the 5/16 th gap.
tacx is offline Find More Posts by tacx
Old Jul 22, 2014, 07:23 AM
edwin1 is offline
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
How about spacers for the cowl. Move it forward a bit. A few wood blocks at the screw points should work.
Edwin
edwin1 is offline Find More Posts by edwin1
Old Jul 22, 2014, 08:02 AM
grosbeak is offline
Find More Posts by grosbeak
Illegitimi non carborundum
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
If you do decide to cut a hole in the firewall (as I did for a recent install) I recommend rounding off the edges to keep chafing of fuel lines and wires to a minimum.
grosbeak is offline Find More Posts by grosbeak
Old Jul 22, 2014, 08:09 AM
jetmech05 is offline
Find More Posts by jetmech05
Jacksonville Fla.
Joined Mar 2007
I say fly it there's an inch and a half on my 40% Sukhoi it looks ok.
If you go shorter standoffs you'll have to cut open the firewall. If you try and move the cowl forward you'll a big space.
What I don't see is a good airflow path for cooling the engine. I see the clyender sticking in the airflow but I don't see the exit out of the cowling to let the air flow around and exit.
jetmech05 is offline Find More Posts by jetmech05
Old Jul 22, 2014, 06:50 PM
redh is offline
Find More Posts by redh
Fla.
Joined Apr 2005
Jetmech makes a good point about " airflow ". Maybe the smart thing would be to slide the cowl fwd a bit and leave a slight gap for Airflow . With a bit of thought you could make it look OK and maybe save yourself some problems with engine overheating. ENJOY !!! RED
redh is offline Find More Posts by redh
Old Jul 23, 2014, 01:15 PM
Hemikiller is offline
Find More Posts by Hemikiller
-insert witty saying here-
Hemikiller's Avatar
United States, CT, Killingworth
Joined Dec 2005
Edwin
My thought as well, looks like 1/4 all around would do the trick.
Hemikiller is offline Find More Posts by Hemikiller
Old Jul 24, 2014, 07:01 PM
DanWard is offline
Joined Oct 2009
Thank you
I wanted to stop in and say thanks for all the replies.
Today I stopped at the local airport and looked at a full scale Pitts. All the cooling air that enters the cowl exists around the exhaust under and towards the back of the cowl. To get my cowling on after muffler is on is going to require a pretty fair sized oval hole so I think I will have enough air flow.
I also found a set of 50mm standoffs and a single fender washer under each allowed the engine to pull back towards the firewall which just made everything come together...looks sweet!
I really appreciate all the input. This group is really where the only guidance I get comes from as no one in my club flies anything like this build. They are mostly nitro, electric, or sail planes.
Thank you!
Old Aug 23, 2014, 05:21 PM
wuest3141 is offline
Find More Posts by wuest3141
Tucson
Joined Nov 2009
Generally, you want twice the size of air exit hole as the size of the air entrance hole. A lot of people don't have the exit holes big enough.
Don't worry about the prop shaft sticking out a little more than scale.
What's more important is to expect more shaking with the gas engine, than with a nitro engine. Make sure that you have triangle stock strengthening the firewall to the rest of the plane.
wuest3141 is offline Find More Posts by wuest3141
Discussion Determine Cg distance - how do you measure so accurately and with what? Fly2High Hand Launch 30 Nov 30, 2013 10:00 PM
Discussion I Quit Flying, Now What Do They Want ? Chophop Life, The Universe, and Politics 26 Nov 02, 2013 11:20 AM
Discussion So, what do you think of modern car designs now? Flyingwingbat1 Life, The Universe, and Politics 74 Dec 08, 2006 11:17 AM
Question Ok, so what do i do now? aerohydro Scratchbuilt Indoor and Micro Models 5 May 29, 2005 05:49 PM
3m77 changed the formula,so what do we use now? kit basher Electric Plane Talk 4 Mar 16, 2002 07:34 AM
