Old Aug 27, 2015, 10:30 AM
headlessagain is online now
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
Same here. Any amendments to the correx plan? I was thinking that the fuse could be built out of 3mm depron covered in laminating film/new stuff as it would be easier to form.
Andy
headlessagain is online now Find More Posts by headlessagain
Old Aug 27, 2015, 04:02 PM
Dukejet is offline
Find More Posts by Dukejet
Dukejet's Avatar
Australia, QLD, Biloela
Joined Aug 2012
Thanks guys. The council burnt off the last of the long grass. So I gad to go "balls to the wall" on the cricket oval. The flight was short because I was shaking so much. A LOT of work in this one given I was making it up as I went alone ( apart from the awesome build videos) .
Auw-1025g's ......battery is 209g , frame 816g
The fuse, tail freathers are 6mm depron and the wing is 3mm. The spar is 6mm depron laminated between two 1.5mm balsa sheets and apoxied. Didn't have "yard stick". Most of the formers have this as well. Motor mount is 3ply aprox 8mm thick. In the video you'll see I show off the hatch, set between the two formers. All bits are cut and placed as the plan states.
The wing join has 2 cf rods as pins for the L/e fixture. The T/e has 3mm balsa from the mid brace back so the screws have something strong enough to brace the wing. In side the fuse as well of course. Canopy is a piece of a 2.5ltr soft drink bottle.
Even with the strength of 6mm I had to put 6mm stringers between the formers over the wing. So I don't know about a 3mm fuse.
Dukejet is offline Find More Posts by Dukejet
Old Aug 30, 2015, 07:10 AM
Sean Oelofse is offline
Find More Posts by Sean Oelofse
.....till the wind drops.
Sean Oelofse's Avatar
Port Elizabeth, South Africa
Joined Oct 2006
Originally Posted by Dukejet View Post
Woohooooo! Baby she flys great! .......
Well done Dj!!!......Great maiden.
Originally Posted by pistnbroke View Post
Hey Sean,
is your brother into this hobby too?
yes......... More helicopters and FPV. ... but twist his arm and take him with to the slope next time you go!
Sean Oelofse is offline Find More Posts by Sean Oelofse
Old Aug 30, 2015, 08:15 AM
pistnbroke is offline
Find More Posts by pistnbroke
absolutely maybe
pistnbroke's Avatar
Australia, WA, Currambine
Joined Apr 2011
Hey Sean,
hmmm ok, what if I tell him we know you from here....will he still speak to us?
do you know where he's flying from in Perth?
There are a couple of guys from South Africa that fly FPV where I fly....all the SA people appear to know each other here
Regards
Ian
pistnbroke is offline Find More Posts by pistnbroke
Old Aug 30, 2015, 02:35 PM
Joined Oct 2006
I'll WA him and PM you.
Found EPP, PSS slopers RTF or near RTF in good condition! Just flyy Aircraft - Sailplanes (FS/W) 0 Jul 29, 2008 09:08 AM
Sold Medium weight pss slopers ***Prices Reduced*** Brandon Aircraft - Sailplanes (FS/W) 6 Dec 29, 2007 11:28 PM
For Sale "PRICE REDUCTION" - Slopers for Sale - CSD, PSS, Polecat, Dave's Aircraft Works 664KIX Aircraft - Sailplanes (FS/W) 16 Jul 04, 2007 01:00 PM
Correx or Corroplast in the UK edthedoc Electric Plane Talk 3 Apr 19, 2005 05:37 AM
Correx / Corroplast Park or Indoor Flyer irpilot Parkflyers 1 Oct 08, 2002 07:43 AM
