Old Oct 02, 2014, 08:31 AM
ChuckTseeker is offline
Find More Posts by ChuckTseeker
ChuckTseeker's Avatar
Adelaide Plains Australia
Joined Dec 2007
New Product
UMX Habu S DF180m BNF
gee how many new products can they release in one day
looking good
Key Features
Completely built and flight ready
SAFE® technology delivers flight envelope protection and AS3X® technology
Ultra-lightweight construction with a scale inspired paint scheme
Powerful E-flite® Delta-V® 180m, 28mm EDF unit (installed)
BL180m brushless ducted fan motor, 11750Kv (installed)
Four-channel control featuring industry leading Spektrum™ DSMX® technology
Performance ultra micro linear long-throw servos (installed)
Engineered intake and exhaust ducting delivers maximum performance
Removable landing gear and steerable nose wheel
200mAh 2S 7.4V 25C Li-Po battery (included)
Celectra™ 2S DC Li-Po balancing charger (included)
Requires a full range 4+ channel aircraft transmitter with Spektrum DSM2®/DSMX technology
Overview
Fearless Sport Jet Performance
The E-flite® UMX™ Habu S DF180 is a high-speed performance jet that’s sized to enjoy just about anywhere outdoors. Based on the original UMX Habu, this new ultra micro sport model delivers an unparalleled RC experience. That’s because for the first time in a jet, exclusive SAFE® technology has been built-in to give you the comfort of flight envelope protection plus the locked-in feel that a custom-tuned AS3X® system provides. In addition, Panic Recovery mode can be used anytime you run into trouble, by instantly returning the plane to level stable flight.
E-flite® UMX™ airplanes let you fly with minimal fuss. The Habu S DF180 is designed to get you in the air in the time it takes to charge a battery. And because all UMX aircraft use advanced Spektrum™ DSM2®/DSMX® 2.4GHz technology, you’ll never have to worry about interference and will enjoy the freedom of flying them with a wide variety of Spektrum transmitters available.
Engineered with SAFE™ Technology
SAFE® (Sensor Assisted Flight Envelope) technology is a revolutionary electronic flight envelope protection system. This intuitive technology enables consistently smooth flight and battles windy conditions in multiple modes with varying levels of assistance and protection including:
Beginner Mode
Pitch and roll angle limits combine with electronic self-leveling to help you keep the UMX Habu S flying smoothly.
Intermediate Mode
Natural feeling AS3X® system stability with expanded pitch and roll angle limits for a larger flight envelope that protects you from entering extreme flight conditions.
Experienced Mode
Pitch and roll limits are removed while AS3X technology delivers smooth flight and a rock-solid feel.
Panic Recovery Mode
1. Pilot loses control of the aircraft in any flight mode.
2. Pilot pushes the panic recovery button. The aircraft will return to level flight...
3. ...once the aircraft is flying straight and level, the pilot returns all other controls to their neutral position and continues a gentle climb to a safe altitude.
The Delta-V® Advantage
The installed E-flite® 28mm Delta-V® 180m ducted fan and 11750Kv brushless inrunner motor combination efficiently converts incoming air to forward thrust. Careful sculpting of the internal duct allows the Delta-V® 180m fan system to deliver optimal performance.
Advanced Spektrum™ Control
The electronics installed deliver precision control of the throttle, ailerons, elevators and rudder. Advanced Spektrum™ DSMX® 2.4GHz technology means that you’ll never have to worry about interference and will enjoy the freedom of choosing to fly with a wide variety of Spektrum transmitters available
Li-Po Power
The included rechargeable ultra micro 200mAh 2S 7.4V 25C Li-Po battery is capable of delivering 3-5 minute flight times. The included Celectra™ 2-cell Li-Po AC/DC charger can recharge the provided high-output battery in about 20-minutes.
Product Specifications
Wingspan: 14.6 in (372mm)
Overall Length: 17.5 in (444mm)
Wing Area: 54.0 sq in (3.50 sq dm)
Flying Weight: 2.7 oz. (76 g)
Motor Size: BL180m Ducted Fan Motor, 11750Kv (installed)
Radio: 4+ channel (required)
Servos: Spektrum SPMSA2030L (Installed)
CG (center of gravity): 1.46 in (37mm) back from the leading edge of wing at wing root
Speed Control : Installed
Recommended Environment: Outdoor
Is Assembly Required: No
Needed to Complete
Recommended Transmitters
A 4+ channel DSM2- or DSMX-compatible transmitter.
ChuckTseeker is offline Find More Posts by ChuckTseeker
Old Oct 02, 2014, 03:37 PM
ncsky is offline
Find More Posts by ncsky
Maggie is in charge
ncsky's Avatar
United States, NC, Raleigh
Joined Nov 2011
Wow! This looks good, I have been a little hesitant to get a edf, but with the mode for beginner this looks like it needs to go on my list.
ncsky is offline Find More Posts by ncsky
Old Oct 02, 2014, 06:05 PM
DropTank is online now
Find More Posts by DropTank
Is it Friday yet?
DropTank's Avatar
Joined Jun 2008
I really like the color scheme on this one. I might just have to get this one.
DropTank is online now Find More Posts by DropTank
Old Oct 02, 2014, 06:32 PM
bobly is offline
Find More Posts by bobly
Joined Sep 2010
But set up for beginners ? -- I wouldn't think this would be much of a beginners plane. A competent pilot might have a ball with it, but just doubt that even with a beginners mode just can't see it being a good candidate for a beginner.
bobly is offline Find More Posts by bobly
Old Oct 02, 2014, 07:43 PM
jgalexander is offline
Find More Posts by jgalexander
Flying Full Size & Fun Size :)
jgalexander's Avatar
United States, CA, Calabasas
Joined Apr 2010
Hi,
Generally I'd tend to agree, but in this case, I think it'd actually be a pretty good second (or maybe even first) plane. First off, it's pretty slow, so there's time to react. Second, the main killer for newbies with nimble planes is that the planes roll so quickly that the pilot will overcorrect, lose orientation, and crash. The paint scheme (looks like a GP Evader, btw - cool!) of this version certainly helps, and toned down controls should help as well. Third and final: AS3X. I own the UMX MiG-15 and Habu, and that gyro stabilized stuff is número uno!! It can be windy as all heck, and the planes will just scoot along as though it was a calm spring morning... Pretty cool .
-Josh
jgalexander is offline Find More Posts by jgalexander
Old Oct 02, 2014, 07:48 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
i dig the new scheme for sure
corsair nut is offline Find More Posts by corsair nut
Old Oct 03, 2014, 05:16 AM
Helibase is offline
Find More Posts by Helibase
Switzerland
Joined Mar 2009
the paint scheme is looking great, but I was hopeing for a speed/power bump, but still the same low power motor/fan combo...
Helibase is offline Find More Posts by Helibase
Old Oct 03, 2014, 10:57 AM
IGluck is offline
Find More Posts by IGluck
United States, MD, Potomac
Joined Aug 2006
I wonder if I can just get a payroll deduction made to HH? So many great looking planes out in the past few months. The wife can't possibly object to one new plane a month, can she?
This one was the only one I pre-ordered. I have a second hand UMX MiG that I've been too scared to fly and this will be just the ticket to get into the category. Really looking forward to it, but with the weather in the northeast, it will likely be spring before it gets maidened.
Well, I guess that will give me enough time to stock up on the others on my wishlist. FW-190, Viking, UMX B-17, UMX Yak..... sigh.
IGluck is offline Find More Posts by IGluck
Old Oct 03, 2014, 10:59 AM
IGluck is offline
Joined Aug 2006
+1!
Old Oct 03, 2014, 01:55 PM
3D-Seth is offline
Find More Posts by 3D-Seth
3D-Seth's Avatar
Joined Jan 2007
This is not a beginner airplane. Its designed as a first time entry into EDFs or a step up for someone who has some 4 channel experience.
Seth Arnold
Horizon Hobby
3D-Seth is offline Find More Posts by 3D-Seth
Old Oct 04, 2014, 06:34 PM
dgomes is offline
Find More Posts by dgomes
Joined Dec 2010
What is the difference from the previous Habu UMX?
dgomes is offline Find More Posts by dgomes
Old Oct 05, 2014, 10:28 AM
Dave Eichstedt is offline
Find More Posts by Dave Eichstedt
Warbird & Jet Lover
Mahomet, Illinois
Joined Aug 2007
Trim scheme and we added SAFE.
Dave Eichstedt is offline Find More Posts by Dave Eichstedt
Old Oct 05, 2014, 10:40 AM
fred256 is online now
Find More Posts by fred256
Joined Jan 2014
And as I understand it, the new one includes a battery and charger, which the previous version did not come with.
fred256 is online now Find More Posts by fred256
Old Oct 05, 2014, 10:54 AM
Jaguar 20040 is offline
Find More Posts by Jaguar 20040
Germany
Joined Jul 2006
What exactly means trim scheme?
Kind Regards,
Jaguar 20040 is offline Find More Posts by Jaguar 20040
Old Oct 05, 2014, 01:22 PM
AlphaDeltaTango is offline
Find More Posts by AlphaDeltaTango
Emergency landing expert
United States, CO, Vail
Joined Sep 2013
Dave,
What is the official ship date on these? Will there be other S jets coming down the line?
Andy
AlphaDeltaTango is offline Find More Posts by AlphaDeltaTango
Article Horizon Hobby UMX Habu 180 DF BNF Basic kevin Micro EDF Jets and Power Systems 13 Jul 11, 2015 03:12 PM
News E-flite® UMX™ Habu DF BNF Basic awagar Electric Ducted Fan Jet Talk 25 Jul 23, 2014 12:13 AM
Sold New in Box UMX Used Habu 180 DF BNF Basic with AS3X Technology bruff Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Nov 03, 2013 06:30 AM
Sold New in Box UMX Habu 180 DF BNF Basic with AS3X Technology Woody_99 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Oct 31, 2013 07:32 PM
