Old Feb 18, 2014, 12:31 PM
pete914 is offline
Find More Posts by pete914
pete914's Avatar
United States, VA, Richmond
Joined Jan 2010
FRSKY High precision Variometer vario for soaring??
Hi all,
I'm confused, I read good reviews about the high precision vario. I have voice readout of Vspd (which is in M/S although I'm setup for imperial) and Alt (which is given in imperial) which is nice, but the audio tone for the vario is horrible. It just beeps when the Vspd reaches whatever trigger point you set. There's no variation in the pitch, just beeping. Please tell me I'm missing something.
Compared to my Pitlab vario this thing flat out SUCKS otherwise
pete914 is offline Find More Posts by pete914
Old Feb 18, 2014, 05:40 PM
VRquaeler is offline
Find More Posts by VRquaeler
The Netherlands, OV, Steenwijk
Joined Apr 2011
better vario
Hi Pete914,
Yes, it is a known issue with the actual "high precision variometer".
See my comments in the Taranis thread here:
http://www.rcgroups.com/forums/showp...ostcount=21582
If you are more interested in this take a search for "openvxvario"
or look here:
http://code.google.com/p/openxvario/
Cheers Sascha
VRquaeler is offline Find More Posts by VRquaeler
Old Feb 18, 2014, 05:48 PM
d_wheel is offline
Find More Posts by d_wheel
Old fart. VAAATSP
d_wheel's Avatar
Deep in the Heart of Texas
Joined Jun 2004
Originally Posted by pete914 View Post
Hi all,
What transmitter are you using it with. On the Taranis, I didn't have to set up anything, except for a switch to turn it on/off, and it gives varying tones depending on vertical speed. Not as sensitive as I would like, but it seems to work fine.
Later;
D.W.
d_wheel is offline Find More Posts by d_wheel
Old Feb 18, 2014, 07:05 PM
pete914 is offline
pete914's Avatar
Joined Jan 2010
thanks for the replys guys
I'm running a Taranis
How did you get varying tones?
I have the sensitivity set to -5, -1.5, .8, 5 at the moment. Pretty insensitive for a model plane IMO...
I don't see any other settings for the vario?
Old Feb 18, 2014, 07:19 PM
d_wheel is offline
Old fart. VAAATSP
d_wheel's Avatar
Joined Jun 2004
I don't know what to tell you. I just connected it, set up a switch to turn it off and on, and flew. Tones go higher in pitch as it climbs and lower in pitch as it descends. I don't know how to set sensitivity, so I guess it is at the default numbers.
Later;
D.W.
Old Feb 18, 2014, 07:25 PM
Joined Apr 2011
Settings
Hi pete914,
You can make it a bit more useful with the settings:
Sensitivity set to -3, -0.1, 0.1, 3
Optionally you you can try -3, -1.0, 0.5, 3 to compensate for the natural sink rate of your plane. Try out what fit your needs.
Cheers Sascha
Old Feb 26, 2014, 02:19 PM
pete914 is offline
pete914's Avatar
Joined Jan 2010
Here's a video with a -10, -2, 0.8, 10 settings.
Not great flying on my part, but the lift was spotty around 3pm on a feb day
FrSKY Taranis audio Vario Variometer Testing (4 min 56 sec)
Old Aug 26, 2015, 07:09 AM
pete914 is offline
pete914's Avatar
Joined Jan 2010
Just wanted to revisit this post.
Any updates on this vario? This unit is dying for a firmware update to improve the vario sounds
Help! FrSky Vario programing with the FrSky FLD-02 - LCD Display gotime360 Radios 5 Feb 23, 2014 12:45 AM
Help! FrSky Vario programing with the FrSky FLD-02 - LCD Display gotime360 Hand Launch 2 Feb 16, 2014 08:06 PM
Help! frsky high precision variometer erratic hpcre Radios 7 Nov 14, 2013 03:14 PM
For Sale FrSky Variometer High Precision RC-JG Aircraft - Sailplanes (FS/W) 0 Oct 29, 2013 07:54 AM
Sold ($24) FrSky Variometer Sensor w/Smart Port (High Precision Version) Whoaty55 Aircraft - General - Radio Equipment (FS/W) 1 Oct 18, 2013 03:24 PM
