Old May 21, 2015, 12:27 PM
AGT6 is offline
Find More Posts by AGT6
AGT6's Avatar
Canada, ON, Ottawa
Joined Oct 2013
On the landing gear.
I'm still having issue with the right side being weak.
Before I order a new set I wanted to know if any has had luck making a set out of piano wire?
Thanks.
Andre.
AGT6 is offline Find More Posts by AGT6
Old May 22, 2015, 08:25 AM
AGT6 is offline
AGT6's Avatar
Canada, ON, Ottawa
Joined Oct 2013
Prop & gear update
Rebent the landing gear.
I'm going to see if I can use my mig welder to run a small bead and hold the bend.
Other wise I did confirm a 5mm piano wire will work. So I can make a new set of struts or buy some I guess.
The spinner still needs a bit more work on the bench grinder.
Have to open up the holes to fit the new MS 13x8 prop.
BTW I did have to use my drill to open up the shaft hole on the prop.
Last thing I did was removed all the weight from the cowl.
With my lightest 4S 2650 up to the forward bulk head it still balances out.
Or at least I think. Hoping this will reduce my nose over issues.
More to follow
Old May 25, 2015, 09:35 AM
AGT6 is offline
AGT6's Avatar
Canada, ON, Ottawa
Joined Oct 2013
Flaps
Didn't do the split flaps and only boo is I wish I'd see that white spar before I positioned the servo. I could have seated them lower.
Oh well.
Old Yesterday, 03:11 AM
Grup is offline
Find More Posts by Grup
Grup's Avatar
doha Qatar
Joined Jan 2004
I've just added a used 190 to the stable and it's missing a few parts; mostly prop, the small screws that hold the wing on, and a spinner. There's a parts set available and the wing screws (2.3x20mm) are in there, so that turned out to be easy.
Prop and spinner are out of stock, but I've located an MAS 13x8 so I'lll use that.
What about a spinner? Is there a Dubro or other brand that will fit?
Regards
Grup is offline Find More Posts by Grup
New Product FW-190 Typ B 1200mm EPO retracts lights mopetista Electric Warbirds 18 May 24, 2012 11:15 AM
Sold Hobbico Flyzone Focke-Wolf 190 RxR FW-190 propflipper Aircraft - Electric - Airplanes (FS/W) 10 May 08, 2012 06:07 AM
Build Log GWS FW-190 in EPO Foam mcsarge Electric Warbirds 259 Feb 20, 2010 04:58 PM
Discussion Just finished my EPO FW-190 TopSpin GWS (Grand Wing Servo) 34 May 22, 2009 05:55 AM
Sold GWS EPO FW-190 PNP Brushless + Retracts!! $150 SHIPPED!! Andrew1944 Aircraft - Electric - Airplanes (FS/W) 2 Jul 21, 2008 02:26 AM
