Old Oct 21, 2014, 07:17 PM
14s 180mah should be enough...
IFLYOS's Avatar
United States, NC, Pfafftown
Joined Feb 2001
This happens when you mis-match versions of the Multiwii Sketch and MultiWiiConf.
What version of the sketch did you flash?
IFLYOS is offline Find More Posts by IFLYOS
Old Oct 21, 2014, 07:22 PM
Team WarpSquad
United States, PA, Doylestown
Joined Jan 2014
All sticks centered at 1500 and End points go from 1000 to 2000 as seen in the MWconf.exe gui (Not in the TX menu), Right?
Which MW sketch are you using? The one Whitespy put in the Flip?
What are the minthrottle and maxthrottle values in config.h?
Which FC do you have defined? Should be "#define FLYDUINO_MPU"
waltr is offline Find More Posts by waltr
Old Oct 21, 2014, 09:01 PM
United States, FL, Tampa
Joined Mar 2013
Check in the gui your throttle graph and make its a straight line, not curved.
acessford101 is offline Find More Posts by acessford101
Old Oct 21, 2014, 09:06 PM
United States, FL, Bonita Springs
Joined Sep 2014
Thanks for the quick responses -
Sketch is Multiwii_Flip_Pimped (don't find a version number)-Witespy says install this if you install the "Pimp Your Flip" card.
Multiwii Config is Version 0
What versions should I be running?
Sticks are centered at 1500, end points are 1000-2000
Minthrottle is 980, maxthrottle is 2025
the FLYDUINO_MPU is defined
RPowell6428 is offline Find More Posts by RPowell6428
Old Oct 21, 2014, 09:27 PM
IFLYOS's Avatar
Joined Feb 2001
Use this sketch: https://www.dropbox.com/sh/3ptxpweso...IMPED.zip?dl=0
Use this Multiwii Config:
https://www.dropbox.com/sh/3ptxpweso...onf23.zip?dl=0
Those will get you on the same version and eliminate one of the most common causes of the half throttle start.
Also, it is worthwhile to load the clear eeprom sketch before re-flashing, just in case..
Old Oct 22, 2014, 06:25 AM
Joined Sep 2014
Thanks, I'll give that a shot and report back.
Old Oct 22, 2014, 06:59 PM
Joined Sep 2014
Thanks to all who gave advice. Reloading the sketches and getting the versions synced did the trick. Quad now flies quite well.
Just for grins I am planning to add a GPS to this quad. Got the boards from Witespy but hookup and wiring details are sorely lacking. Does anyone have this data handy or can you point me to a location where I can get the info. Wiring diagrams would be nice.
thanks again
Old Oct 23, 2014, 03:39 PM
TeachSeventh
W5BSA's Avatar
Houston
Joined Dec 2008
thanks again
You would be better off making this quad your Acro bird. Get the Witespy Multiwii Pro EZ 3.0 Blacked Mag edition build you a second bird for Mission adventures take advantage of features such as return to home, waypoints, etc. Your GPS plug and play on this board. It's $39. Good luck, Joe
W5BSA is offline Find More Posts by W5BSA
Old Oct 23, 2014, 03:49 PM
Joined Sep 2014
Thanks, I'll look at that.
Old Oct 23, 2014, 04:56 PM
TeachSeventh
W5BSA's Avatar
Houston
Joined Dec 2008
You're welcome. The FLIP's are fantastic boards. Learn to fly in ACRO mode. Just fly the heck out of it until you learn to make it do anything you want it to without even thinking about it. Do that and you can fly circles around those that depend on the assist modes. Do something to help you with orientation. Night flying is a great way to learn Acro mode. See my photo with my LED scorpion tail on my quad. Jack helps on my FLIP tricopter. Learn to fly your multis just like an RC plane. Will make a better multi pilot out of you in the long run. Then if you go on to autonomous or FPV you will have better success. Always a good thing if you can take over manually and fly your ship back home if it gets itself in trouble: ) Main thing is have fun while you're learning.
