Old Apr 28, 2012, 08:19 PM
VIDEOPRO's Avatar
Central Maryland
Joined Apr 2008
LFI S-21 Russian Light Fighter to complement the PAK FA T-50
Alright I'm not sure where I pulled this schematic from, but I have a 55mm fan, motor and esc that will work for this. My plan is to make a model of this with an estimated wing span of 23" - 24". I believe I pulled this from a thread sometime around when the Russian Pak T 50 hit the news. Anybody know for sure what this is let me know. Is it Russian or some other country? As of now my paint scheme in mind is the Russian winter snow camo scheme since I have the paint colors on hand. (Black, White, Gray)
Like I said I have all the supplies sitting here and decided to attempt this build. Here is what I have done so far.
Found the new schematic at the following link:http://forum.keypublishing.com/showthread.php?t=100029
VIDEOPRO is offline Find More Posts by VIDEOPRO
Old Apr 28, 2012, 09:26 PM
NAKIAM949's Avatar
United States, MD, Waldorf
Joined Dec 2007
Not sure what it is, could be the Russian answer to the F35....either way I think you might just have a winner on your hands, I'm subbed
NAKIAM949 is offline Find More Posts by NAKIAM949
Old Apr 29, 2012, 07:56 PM
VIDEOPRO's Avatar
Central Maryland
Joined Apr 2008
Well, when I put the schematic into photoshop for aligning the 3 views to confirm the lines my front view looks slightly different from what is showing on the original schematic. Did some more work on the project.
Old Apr 30, 2012, 08:34 PM
Designer/Scratch Builder
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Hello VideoPro.
The T-50 is the Russian version of the US F-22 class twin engined fighter. The drawing that you are building from would be in the same class as the F-35.
LFI S-21 is what it has been called on the military aviation sites....among other things It is not an official concept....so they say, but "what if" drawings.
Anyway great start on your project!
Kevin Cox is offline Find More Posts by Kevin Cox
Old May 01, 2012, 06:56 PM
VIDEOPRO's Avatar
Central Maryland
Joined Apr 2008
All electronics installed.
Turnigy 2610 4500kv edf motor.
55mm edf fan unit.
Thunderbird 36 amp esc.
2 - HXT 900 servos for elevators
2 - HXT 500 servos for ailerons
Plan on using Rhino 1550 3s batteries that I have sitting here not being used.
Weight as of now without the battery and canopy: 328 grams.
More progress photos:
Old May 06, 2012, 09:40 PM
VIDEOPRO's Avatar
Central Maryland
Joined Apr 2008
Thanks to Kevin Cox for the info about what this is. I did a search online and found out that this just may be the Russians light fighter concept to complement the PAK FA T-50. Although there are reports that the Mig 35 may fill this role for now.
I wish I found this schematic before I added my panel lines. I may just need to build a larger 90mm version of this with retracts. To me it looks like a F-16 with a look of the F-35.
Old May 07, 2012, 02:52 AM
smithy
jumpy's Avatar
Cornwall, UK
Joined Dec 2004
Nice work she looks great. Definately got hints of a mig29 in there, especialy the top half.
Phil
jumpy is offline Find More Posts by jumpy
Old May 07, 2012, 12:23 PM
VIDEOPRO's Avatar
Central Maryland
Joined Apr 2008
Phil
Thanks Phil,
I wonder if this is really in the works. I have noticed changes to the schematic drawing with more details added to it as well. I do like the second drawing better. Yes, it does have the hints of the Mig 29.
Old May 08, 2012, 06:46 AM
mesnick's Avatar
Italy, Lazio, Rome
Joined Nov 2004
is a beautiful work, congratulations VideoPro.
interesting project, very nice color scheme.
wait to see the flight..
Mesnick
mesnick is offline Find More Posts by mesnick
Old May 08, 2012, 11:33 AM
MattinAZ's Avatar
United States, AZ, Scottsdale
Joined Jan 2005
Very nice work.
MattinAZ is offline Find More Posts by MattinAZ
Old May 08, 2012, 04:08 PM
VIDEOPRO's Avatar
Central Maryland
Joined Apr 2008
Thanks guys!
Here are some more progress photo's. Painting is complete unless I need to do touch up. Most likely will after I glue on the verticals. Some of the markings are glued on. Still need to add a number to the fuselage and other small markings. I decided to use the former roundel insigna although I see the PAK FA only has the outside line of the star and not the inner solid star. This will stand out for better visual. In the process of cutting the ailerons and elevators. will be ready soon for a maiden flight.
I need to build a mock up toss dummy for finding the CG.
Old May 08, 2012, 04:24 PM
Kevin Cox's Avatar
Joined Jan 1997
That is an incredible piece of work!
Old May 09, 2012, 04:25 PM
VIDEOPRO's Avatar
Central Maryland
Joined Apr 2008
Thanks Kevin,
It is turning out better than I thought. Buidling my 64mm EDF scratch F-22 has taught me a lot with using the dollar tree foamboard. That has made this build so much easier for me. For my next project, I have on the drawing board a twin 90mm F-22 with a wing span of 55". Already started to get the parts for it.
Discussion Profile Pak Fa T-50 bobdaeronort Foamies (Scratchbuilt) 44 May 14, 2013 08:06 PM
Video Suchoi T-50, PAK-FA Pusher Jet Maiden Flight Hans-Joachim Electric Plane Talk 6 Jul 13, 2010 06:59 AM
Discussion Sukhoi PAK T-50 makes its first flight! Tumbler Electric Ducted Fan Jet Talk 10 Feb 01, 2010 02:42 AM
Discussion Anyone Have a PAK FA T-50 3-View? yellow13 Foamies (Scratchbuilt) 2 Jan 31, 2010 06:06 PM
