Old Jan 26, 2015, 04:41 PM
Black_Angel's Avatar
Joined Jan 2015
Stretched Copterx 450 Black Angel Project
Last weeks or maybe even months i have researched, buyed, built and setup ( x 5 or 6 times) my first real sucessfully CP Rc Helicopter a Copterx 450 Black Angel DFC . I ended up buying 2 kits, 1 as spare parts. I now thinking of building my spare kit as a streached version...normally that would be stright forward project..just buy a stretch kit, but BA already uses the stretched belt, becouse ther is no gear but a direct belt solution who makes everything smooth and less noicy than with gear involved.
So now im starting reasearching and hope for some ideas and help under the way..just as i got on my first built..who would not been very sucessfully without the great help i got from members here. I readed some one had used Gaui 523mxl x4mm tail belt for doing same..together with the Tarot 480 stretched tail. Ref http://www.helifleet.com/copterx-450...-stretch/h3432
I found http://www.gaui.com.tw/product/x3-se...3-belt-522mxl/ but no 523..
I want to built this...
522MXL is this a belt size standard?
BA
Black_Angel is offline Find More Posts by Black_Angel
Old Jan 26, 2015, 09:50 PM
just gotta mess with it!
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
Online
Search for MXL belts online.
You can combine a longer belt with your own custom tail boom, cut from a carbon fibre tube of the right diameter. Not sure if the BA uses 12mm or 14mm. Otherwise using the Tarot 480 boom, you need a specific length.
The following listing gives loads of belt lengths in 1/8" width, tho unfortunately they're not in ascending or descending order of length, so you have to trawl thru it. Maybe you can end up with a code that will lead you to a source where you can buy one or two belts rather than a thousand!
http://www.globalindustrial.com/g/mo...125-Belt-Width
Edit: just clicked on the 498 belt, which is what my Forza uses. Minimum order is 20!
2Doggs is offline Find More Posts by 2Doggs
Old Jan 26, 2015, 11:19 PM
Joined Jan 2015
ok great, i got the idea now...How should i estimate length? I see the setup i found uses 523: http://www.helifleet.com/copterx-450...-stretch/h3432. Will a 523 MXL be same lenght from different providers?
BA uses 12mm tail boom.. How much longer is the 480 boom? My BA tailboom is 33cm
My current belt is same as tarot stretched belt:453T
BA
Old Jan 26, 2015, 11:31 PM
2Doggs's Avatar
Joined Nov 2009
The MXL belt pitch is 2.03mm - so for every 2 additional teeth or grooves, you will need a boom that's 2.03mm longer.
If a heli can use up to 325mm blades and you wanted to stretch it to use 360's, the boom would need to be 35mm longer, and maybe a bit more if you were also going to use longer tail blades, so let's say 40mm longer. The belt would then need to be at least 40t more, which would make it 493. You could maybe use the 498t belt from the Forza. Getting a belt with 530t or so would enable the use of even longer blades, maybe 370 or 375.
Unless you were going to turn the BA into a "floater", running only a moderate HS, I might be a bit concerned about the strength of the maingear when stretched.
Old Jan 26, 2015, 11:36 PM
Joined Jan 2015
Floater with moderate HS would be great....i think 36cm blades best for me, i think no easy supply of 370-380 etc
You think there referance of 523MLX with the 480 tarot boom is wrong?How long is forza tailboom compared to tarot 480?
BA
Old Jan 27, 2015, 12:58 AM
Joined Jan 2015
I see KDS Chase 360 and Gaui X3 uses 522MXL
BA
Old Jan 27, 2015, 08:00 AM
2Doggs's Avatar
Joined Nov 2009
I think the Forza boom may be a tad shorter than the Tarot 480 one. The maximum blade length is 350mm, and I know some people have stretched it using a longer boom and a 522 belt. The Forza uses a 14mm diameter boom however, same as the Mini Titan, compared with 12mm for Trex and clones.
Going back to your original links, I don't think there's such a thing as a 4mm wide MXL belt. The MXL spec is Imperial, with a tooth pitch of 0.080", and available in widths from 1/8" and up. It looks to me like there's a big difference in the price charged by the manufacturer, albeit for an order with maybe 20 units, compared with the resellers prices!
Old Jan 27, 2015, 11:15 AM
Joined Jan 2015
ok..so i should try with 522 belt then i guess? how wide should it be?
BA
Old Jan 27, 2015, 12:44 PM
2Doggs's Avatar
Joined Nov 2009
1/8"
Just the same as the existing belt - which will be 1/8". My 450 Pro's use a 1/8" 397MXL belt, and my Forza a 1/8" 498MXL, and the one on my 500 looks like 541MXL, tho the printing is half off the belt so it's hard to tell. It's still only 1/8" wide tho.
Old Jan 27, 2015, 12:59 PM
Joined Jan 2015
ok thanks for very usefull info, now i understand more of this. I had no idea ther was so many possible solutions on belts, thats great..I will search online for some proveder.. i found this one http://www.gaui.com.tw/product/x3-se...3-belt-522mxl/ ( shipping from asia is easiest for me)
BA
Old Jan 27, 2015, 01:06 PM
2Doggs's Avatar
Joined Nov 2009
Yeah, the price isn't too steep on that, but you might be able to find one for less. I'm still using 450 Pro belts I bought in a pack of 5 from eBay, and they worked out about $0:50 each!
This thread is getting crowded, tho - who are all these other posters?
Old Jan 27, 2015, 01:44 PM
Joined Jan 2015
yes im checking ebay and alibaba too..
BA
Old Jan 27, 2015, 02:29 PM
2Doggs's Avatar
Joined Nov 2009
you'll also need a longer tail rod - so either use a carbon one, or a source for the wire and a die to cut a thread on it.
don't just move the tail servo back on the boom, that will be ugly!
Old Jan 27, 2015, 03:05 PM
Joined Jan 2015
yes im aware of it..i found a tarot tail rod together with tarot boom.. i was thinking of getting the carbon rod instead of the wire..but i think my rod wire guides not fit..
http://www.banggood.com/Tarot-480-pa...-p-949658.html
http://www.banggood.com/Tarot-480-Sp...-p-950667.html
http://www.banggood.com/Tarot-480-Sp...-p-950725.html
http://www.banggood.com/Tarot-360mm-...-p-949657.html
http://www.banggood.com/Tarot-480-Ca...-p-949659.html
BA
Old Jan 27, 2015, 07:21 PM
2Doggs's Avatar
Joined Nov 2009
Yes, the carbon rod needs a single guide that's different from the ones used for the wire rod. Some carbon rods use a large enough diameter carbon tube that no guide is needed.
Looks like you've got it all going on tho, so it will be interesting how it works out. I'm not a big fan of black main blades, so I would probably paint them or find mostly white ones.
We may make it to page 2 before anyone else posts!
Discussion CopterX 450 Black Angel DFC: Slow Tail Wag FIXED jono20 Electric Heli Talk 5 Feb 02, 2014 12:25 AM
Discussion CopterX Black Angel 450, Bad Vibration when slow start throttle andione1983 3D Electric Heli Flying 5 Mar 07, 2012 09:29 PM
Discussion CopterX Black angel 450 questions please help andione1983 3D Electric Heli Flying 2 Nov 19, 2011 01:54 PM
Discussion TX programming for CopterX 450 CX Black Angel jannus Mini Helis 1 May 10, 2011 12:20 PM
