Old Mar 24, 2014, 10:07 PM
United States, CA, Santee
Joined Mar 2003
New to 4 Channel - Aileron/Rudder Mixing Questions
Hello all. I picked up a couple used electric planes over the weekend, and I have a couple questions. These are my first 4 channel planes (I've been flying 3 channel for a while now). The first is a Multiplex FunCub which my 14 year old son will be flying with a 72MHz Hitec Flash 5 transmitter. The second is a Multiplex Easy Star conversion w/ ailerons and brushless motor which I'll be flying with a Spektrum DX6i transmitter.
I'm curious about aileron/rudder mixing. Seems like a great option to be able to fly "hands-off" the rudder control stick for making turns. In fact, a little "up-elevator" at the same time seems like it would be a good thing for turning as well. Both transmitters seem to support some mixing functions.
1) If you program aileron/rudder mixing, can you still independently use ailerons for rolls without moving the rudder? For example, could I still do a knife edge roll without turning left or right?
2) What percentage of aileron to rudder movement makes sense? For example, If I move the ailerons 100%, I should have the rudder move what percentage?
3) If I wanted to mix a little "up-elevator" in also for turns only, can you do that without causing a "down-elevator" response when rolling in the opposite direction?
Thanks for your help. I'm new to ailerons and channel mixing, so be kind with your responses . Please note that the FunCub also has flaps, but questions concerning those will be saved for another day...
sstephenson is offline Find More Posts by sstephenson
Old Mar 24, 2014, 10:44 PM
Y=C+I+G
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
why don't you try without the mix first and see how you like it? same goes for flaps (even though you haven't asked yet).
cmdl is offline Find More Posts by cmdl
Old Mar 24, 2014, 11:33 PM
Joined Mar 2003
I've been reading other posts on the subject, and honstly I'm torn. While I know that technically I'd rather be a purist and throw all control surfaces independently, the truth of the matter is that my hand/eye coordination has never been my strong suit, and my kids can kick my behind all day long when it comes to that kind of motor skills. That said, maybe computer radios are the difference between flying and not flying for re-treads like me . Like you said, maybe I should just try it the old fashiond way and fall back on the computer assist if I need to.
I'm still wondering though, if I do a aileron>rudder mix with the DX6i, does that mean that every time I throw ailerons I will also throw rudder? I don't want that if I just want to do a simple roll. Maybe I want a rudder>aileron mix instead? Am I on the right track?
And to clarify my last point, can I mix in little up-elevator with rudder or aileron to avoid nose drop during a turn? Obviously I don't want to create a down-rudder scenario for a turn in the opposite direction.
Old Mar 24, 2014, 11:42 PM
United States, MS, Horn Lake
Joined Aug 2013
I've got similar questions (I can't believe I came on here looking for this sort of information, and the top post in the forum was pertinent to what I was looking for).
I've been flying helis for a couple of years and am more knowledgeable about helis. My only plane, a standard-sized PZ t-28, tends to drop in turns. My tendency is to apply down elevator, but that really just makes the turn sharper. I realize that rudder in the opposite direction of the turn brings the nose back up. However, I wondered if there was something I could do with mixing to counteract, though I didn't know how I would keep the mix from affecting a roll unless I tied into switches. I've never really used mixing with helis except with a 120 SR and the mix was just a recommendation I received, not something I created on my own. Therefore, I'm extremely inexperienced in regards to determining appropriate mixes and setting them up but would like to learn more.
jcjrogers is offline Find More Posts by jcjrogers
Old Mar 25, 2014, 12:17 AM
Art Schmitz
United States, TN, Crossville
Joined Jan 2012
10% rudder is a good place to start.
Never tried the elevator / turn mix.
Your rudder will work separately, but not the ailerons.
Most radios allow you to switch the CAR on and off.
lindart is offline Find More Posts by lindart
Old Mar 25, 2014, 03:04 AM
Joined Mar 2003
If I understand correctly, I think the DX6i gives me the option to aileron>rudder mix or rudder>aileron mix. If I'm not all wrong on this, I think that one of those two options would allow me to do 10% rudder when throwing the aileron stick. Anyone know which one?
Hmmm..... OK, I think I'm starting to get the picture.. If I mix aileron and rudder on the aileron stick, I can no longer do an ordinary roll with the aileron stick unless I program the mixing with an on/off on a switch. I don't know if I can do that on the DX6i. Can mixing be programmed on an on/off switch?
Wow. It's starting to seem like its simpler to just get used to using ailerons/rudder for turns and just the ailerons for rolls.
Old Mar 25, 2014, 03:11 AM
United States, WA, Seattle
Joined Oct 2013
You have a mix switch on the DX6i but I agree...it is simpler to just use rudder with ailerons when you turn.
Seattlehiker is offline Find More Posts by Seattlehiker
Old Mar 25, 2014, 03:16 AM
United States, MI, Monroe
Joined Jun 2009
Learn to fly controlling all surfaces first.
Tony K is offline Find More Posts by Tony K
Old Mar 25, 2014, 04:14 AM
Learn to build with wood.
Tucci's Avatar
United States, NC, Newport
Joined Sep 2012
I wouldn't bother with the ail/rud mix. You probably will want to do a flap/elev mix on the one with flaps though.
Tucci is offline Find More Posts by Tucci
Old Mar 25, 2014, 09:51 AM
xmech2k's Avatar
United States, CA, San Diego
Joined Jun 2007
Yes, you can have a switch to turn the mix on/off. It's right on the mix screen.
Yes, you can mix up elevator with both left and right aileron, as you choose the amount and direction of the mixes for both directions of the master channel. But this mix well not help keep the plane level throughout the turn, as even after you're done rolling for the turn, you still have to compensate the change in lift vector by maintaining some up elevator until you apply opposite aileron to level out. Then you'll have to fight a tendency to climb rather than just releasing the up elevator. Come to think of it, I wouldn't bother with the rudder/aileron mix either for a similar reason, unless the plane has bad adverse yaw.
As for flap/elevator mix, that depends on the plane. On the 2 planes I've flown regularly that have flaps, they ballooned if I extended them while going too fast, but needed no trim change at reasonable approach and landing speed. Just have to experiment and see what it needs. Your model may vary!
xmech2k is online now Find More Posts by xmech2k
Last edited by xmech2k; Mar 25, 2014 at 09:53 AM. Reason: stupid smart phone auto - spelling...
Old Mar 25, 2014, 09:56 AM
xmech2k's Avatar
Joined Jun 2007
Oh yeah, sstephenson, did you pick up those planes at the Weedwackers swap meet? How was it? I had to stay away. Too much stuff already!
Old Mar 25, 2014, 10:34 AM
Joined Mar 2003
Thanks a million guys. Great info here, and very helpful. The more I consider it, I think that adding mixing to a switch function is just adding one more thing to have to remember. I'm better off learning to use both sticks in a turn than I would be trying to remember to switch mixing "off" when I want to do a roll.
And yes xmech2k, I did pick up the FunCub at the Weedwacker's swap meet (the Easy Star was a Craigslist find). My kids and I had a great time there. Super nice bunch of guys. An awesome array of planes and gear. It was a great way to spend a Saturday morning! Not the place to be though if you're trying not to spend money
Old Mar 25, 2014, 10:56 AM
United States, NY, Queens
Joined Oct 2005
The purpose of adding mixing to the controls, setting expo, etc. is to adjust the transmitter to help in controlling your plane. At this time you don't know what help, if any, you might need. You are just guessing. Fly your plane for a while. Then if there are certain tendencies that need corrections, you can determine whether mixing will help with some of them.
The beginner setting on planes like the Apprentice and Delta Ray uses some mixing of the elevator with the turn controls to help the beginner. Most flyers find this mixing to be a nuisance once they learn how to fly. It makes controlling the plane for more advanced maneuvers more difficult, rather than easier.
Leo L is offline Find More Posts by Leo L
Old Mar 25, 2014, 11:36 AM
What Goes Up Must Come Down
PRNDL's Avatar
United States, NJ
Joined Jan 2013
In stead of telling you to learn to use the rudder I'll answer your question.
You would want to activate the aileron >rudder mix....when you use the aileron the rudder moves in the same direction making a coordinated turn. I would choose (minus) -30% right and left rudder. This doesn't mean the rudder will travel 30% but it can depending on how much travel the ailerons make. You can assign this mix to any switch offered in the mix menu.....just scroll through them. I would pick the gear switch since I don't suppose your have retracting landing gear. Flip it on or off and you should also be able to do your rolls with it on.
Good Luck!!
PRNDL is offline Find More Posts by PRNDL
Old Mar 25, 2014, 11:52 AM
Joined Mar 2003
Thanks guys.
Thanks PRNDL for answering my question about Aileron>Rudder vs Rudder>Aileron!
Discussion elevon mixing D6I aileron stick movement same as elevator. ell198679 Flying Wings 2 Nov 20, 2013 07:16 PM
Discussion Mixing Aileron And Elevator (V-Type Mix) -How To Waleed Radios 20 Oct 15, 2012 07:45 AM
Discussion Throttle/Aileron and Elevator/Rudder mixing questions Tumbler VTOLs 16 Aug 09, 2010 04:40 AM
Discussion 4 channel dual aileron Elevator flap mixing? Nethole Hitec/Multiplex USA 0 Jul 15, 2006 08:38 PM
Flash 4sx Elevon mixing question--Ailerons & Elevator reversed nicnicholson Hitec/Multiplex USA 2 Jul 05, 2005 07:44 PM
