Old Jun 10, 2013, 05:04 AM
Australia, NT, Alice Springs
Joined May 2002
Vlf DC-3 wip
Hi Guys,
Just wanted to post something I have been working on this weekend.
Its a DC-3 based on dz1sfb's VLF build style. I have the basic outlines done. I still need to work out battery locations etc.
Let me know what you think, any suggestions etc.
thanks,
Dale
toasthall is online now Find More Posts by toasthall
Old Jun 12, 2013, 07:54 AM
Joined May 2002
After lots of cutting I've finally got all the parts for the fuselage cut. Still need to work out placement for the electronics etc before I glue it all together.
The black foam is horrible to work with! The wings are going to be done in white foam. I will wait and see if she flys before I sand and paint the fuselage.
Dale
Old Jun 25, 2013, 05:22 AM
Joined May 2002
Got some time to work on this tonight. After making 2 left wings, I finally got the wing together.
Old Jun 25, 2013, 07:01 AM
Slipping the Surly Bonds
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Kudos!
Ken
dz1sfb is offline Find More Posts by dz1sfb
Latest blog entry: Mini H Quad Project
Old Jun 25, 2013, 09:42 AM
SG Talon... Super Genius.
Lenox, Michigan
Joined Nov 2005
Too bad you didn't do some trimming and sanding on the fuse Toast. With all those layers it is easy to get a nice shape out of it. You should see some of the stuff Ken does with his VLF designs. Pretty awesome.
SGTalon is offline Find More Posts by SGTalon
Old Jun 25, 2013, 02:15 PM
Nacogdoches, Texas, USA
Joined Nov 2008
I like it! Maybe once you've got it all balanced and the battery location figured out, you should build a second fuse with cutouts in the right place for everything before you laminate the layers together. Could be a very clean design.
4evrplan is offline Find More Posts by 4evrplan
Old Jun 25, 2013, 06:22 PM
Joined May 2002
Thanks Guys,
It was Ken's designs that inspired me to try the DC3 as a VLF before I do it as a full fuselage build. The fuselage hasn't been glued together yet as I still need to sit down and work out where I am going to put stuff and where to add cutouts to reduce weight. Initially I was planning on doing the test flights without shaping the fuselage but I think she would look much nicer with a rounded fuse.
I have lots of changes to add to the plans so far and I am sure there will be more!
cheers,
Dale
Discussion P-38 Lightning VLF roger5005 Foamies (Scratchbuilt) 2 Feb 21, 2013 07:35 PM
For Sale FS- 3 NEW HS-81 Servos and 3 new ch56 xtals (hitec DC, GWS UM1, and FMA DC) Etonic Aircraft - General - Radio Equipment (FS/W) 1 May 29, 2005 11:30 AM
Mig-3 WIP petterms Scale Kit/Scratch Built 11 Oct 18, 2004 07:36 AM
