Old Feb 11, 2013, 10:50 PM
Tucson, AZ, USA
Joined Nov 2000
BV 212-03 kit
I'm going to build a 150% RBC 212 using a Wemotec 90mm/Mega. Obviously the duct size has to change. I'm also thinking of adding flaps (40 to 60 degrees)to help slow this plane down. Will the elevators have enough authority to trim out the flaps? I would like to use electric retracts - need rotating for all 3 (havn't found any yet). I expect that the weight will be in the 4 to 6 pound range. I also plan to have the wings removable.
Any bright ideas about the flaps and retracts?
Bob Reynolds is offline Find More Posts by Bob Reynolds
Old Feb 11, 2013, 11:46 PM
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Check out PW-RC.com for retracts.
Bob
bruff is offline Find More Posts by bruff
Old Feb 12, 2013, 01:53 PM
My project: FAIREY DELTA 1
Erik v. Schaik's Avatar
Uden Volkel, Netherlands
Joined Dec 2003
what about using a 70mm fan. would give plenty room for retracts.
br,
Erik
Erik v. Schaik is offline Find More Posts by Erik v. Schaik
Old Feb 12, 2013, 10:49 PM
Tucson, AZ, USA
Joined Nov 2000
Do you think that a 70mm fan could fly a 150% 212? Besides, I would still want rotating gear. There will be 4 servos in each wing - flap, elevator, aileron, & rudder.
Old Feb 13, 2013, 02:16 AM
Joined Dec 2003
Not sure if it will take off from grass, but bunghee lunch would be real. For 90mm I'd make it much larger. The Yak15 flys well on little power as well.
stevejets Huck,minifan,16-15-3,4s,350w
stevejets Huckebein 1/2 (2 min 35 sec)
Discussion Bv-212 335driver Pusher Prop Jet Models 2 Feb 22, 2013 10:20 PM
For Sale RBC Kits BV 212 -03 NIB for Minifan Atindra Aircraft - Electric - Jets (FS/W) 4 Dec 27, 2006 12:05 PM
Rbc Kits Bv 212 Bob P Electric Ducted Fan Jet Talk 222 Jun 17, 2006 10:05 AM
BV 212 progress on plug ChrisFeole Electric Ducted Fan Jet Talk 6 Aug 02, 2003 06:31 AM
