Old Feb 04, 2015, 01:13 PM
Elec 1800 is online now
Find More Posts by Elec 1800
Flying 2 Fight Cancer
Elec 1800's Avatar
corona, ca
Joined Feb 2011
Originally Posted by danpos View Post
Looks good.
I am going to convert mine someday soon.
Please post more pictures of the entire process.
Thank you very much
Here are some updated pics. Started on the painting already
Elec 1800 is online now Find More Posts by Elec 1800
Old Feb 25, 2015, 04:45 AM
kindbill is offline
Find More Posts by kindbill
sir kind bill
Australia, WA, Shoalwater
Joined Mar 2007
does any one have info on the original motor as I have two FMS P47 and I plan to upgrade to the 4 blade and motor sow I plan to use the old motors in a twin
kindbill is offline Find More Posts by kindbill
Old Feb 25, 2015, 04:51 AM
Elec 1800's Avatar
corona, ca
Joined Feb 2011
Some updated pics
Old Feb 25, 2015, 04:05 PM
JM66 is offline
Find More Posts by JM66
JM66's Avatar
United States, OH, Rosemount
Joined Jul 2011
The early version p-47 had the purple FMS 4250-Kv500 motor and then FMS started installing the newer gold paep 4250-kv 540 motors. Both motors do well with the stock 4 blade prop on the P-47 as I have tried both sizes, but I like the 540 a little better along with running a 80amp esc with a 10amp CC ubec.
JM66 is offline Find More Posts by JM66
Old Mar 07, 2015, 05:45 PM
Dadawada is offline
Find More Posts by Dadawada
Dadawada's Avatar
United States, NC, Cary
Joined May 2014
Maybe it's time to throw in the towel.
So I upgraded the motor in my Carbon Z to a Power 60 and moved the E-Flite BL-50 (the stock Carbon Z motor) into the P-47 to turn the 14x8 4 blade prop. The BL-50 had been successfully flown in the Carbon Z on 6S.
The plane took off great and flew around for a few minutes fine. I did not run the plane full throttle the whole time. I noticed it was not has peppy as it was with the same prop and the FMS motor. But after a few minutes, the motor started to die and smoke could be seen coming from the plane.
Upon landing and inspection the motor was fried. Locked and would not budge. Everything else was fine.
So it may not work out running the FMS P-47 on 6S with a 4 blade prop.
Dadawada is offline Find More Posts by Dadawada
Old Apr 03, 2015, 06:58 PM
streger is offline
Find More Posts by streger
Joined Jan 2010
Wing attachment
I know this is a very old thread - but it has recent activity so I am going to jump on too.
Got this plane second hand, which most importantly meant no Manual.
Can someone please tell me the size of the screws that are [supposed to be] used to hold the main wings on? They must be 2.5mm diameter or smaller and of unknown length.
streger is offline Find More Posts by streger
Old Apr 04, 2015, 01:37 AM
kindbill is offline
sir kind bill
Joined Mar 2007
Do you mean the screws for the main spar clamps if sow I think 2mm to 2.5mm.
I glued wooden blocks onto my wings and ply sheets on the fuselage plus two wood screw to hold wing in place and only I use wood screws because they were in my tool box.
I d not trust the Wing spar clamps
Old Apr 06, 2015, 10:19 AM
Diamond Hobby is offline
Find More Posts by Diamond Hobby
Diamond Hobby's Avatar
United States, FL, Tallahassee
Joined Mar 2013
You can download the manual from our website if you need it. The Wing hold downs are 2.0 machine thread. There is a nut embedded in the holder located out in the wing
Diamond Hobby is offline Find More Posts by Diamond Hobby
Site Sponsor
Old Apr 06, 2015, 12:47 PM
matiac is offline
Find More Posts by matiac
AMA 994002
matiac's Avatar
United States, RI, Westerly
Joined May 2012
Don't know if I've asked this yet, but can the 1700 retracts be used in the 1400? Mine hasn't even been flown yet, and the left retract quit completely, and the right stutters so bad it's probably not too far behind, or something from the 1450's maybe?
matiac is offline Find More Posts by matiac
Latest blog entry: Stability issue
Old Apr 07, 2015, 08:04 AM
Joined Mar 2013
No they can't, they area different size. FMS has redone the retract and are now using FMSRE003, they are a little more robust.
Jim
Site Sponsor
Old Apr 07, 2015, 08:12 AM
Elec 1800's Avatar
corona, ca
Joined Feb 2011
Having fun
FMS 1400mm razorback converted P47 (6 min 9 sec)
Old Apr 20, 2015, 01:53 PM
matiac is offline
AMA 994002
matiac's Avatar
Joined May 2012
'Bout Time!
Well, after almost 4 years of letting it sit for lack of a bigger space to fly it, we took our V. 2 1400mm P47 to a local boat-launch with a paved parking lot, and FINALLY maidened it. Took off into a 10-15mph head wind, with flaps down, and she lifted off the ground in less than 20 feet. Flies really nice, with no bad tendencies, but I did notice it seemed a bit down on power with a Sky-LiPo 4s, 2650mAh at 20c continuous, and 40c burst. The retracts flew south about 2 years ago, so she flew with wheels down. Pretty responsive, although a little too sensitive at the Elevator. And where it didn't need a ton of runway for take off, needed almost the entire width of the parking lot (at least 50 yards) to land. She rolled. And rolled. And rolled. Finally one the those little concrete wheel stops stopped it, with a retract ripped right outta the wing, and a broken prop blade. No sweat, epoxy the retract back in, throw another blade on the hub...and put 'er away for the rest of the day, so the epoxy had enough time to fully cure. Had other stuff to fly, so it was all good. Don't rightly know why I was so afraid to fly it, other than the field size thing, this plane gave no reason to fear flying it. Didn't film it, as every time I film a maiden flight of ANYTHING, something usually goes wrong...
Old Apr 20, 2015, 02:03 PM
matiac is offline
AMA 994002
matiac's Avatar
Joined May 2012
Originally Posted by Elec 1800 View Post
Your plane flies pretty nice, and sounds absolutely EVIL when it flies by...nice job on that by the way...
New Product Giant FMS EPO P-51.....NICE kydawg1 Electric Warbirds 17242 May 20, 2015 11:19 PM
Discussion Giant P-40 EPO 1400 mm Lenop Electric Warbirds 3080 May 09, 2015 10:33 AM
New Product Another Giant (?) EPO P-51 Mustang coming.....from BH kydawg1 Electric Warbirds 398 Nov 08, 2010 07:18 AM
New Product FMS GIANT FOAM P-47 Thunderbolt Lexta Electric Warbirds 28 Oct 03, 2010 09:55 AM
