Old Aug 12, 2015, 02:44 PM
AJWoods is online now
Find More Posts by AJWoods
Aircraft Designer Guy
AJWoods's Avatar
United States, CA, Santa Clara
Joined Jul 2005
Build Log
Cartoon C-130 Fat Albert
NEAT fast approaches ,and I have one more plane I wanted to finish, a cartono C-130 to go with my Blue Angels formation flyer.
They will be of approximately the same scale, which makes the C-130 have wingspan of 30 inches. I'm going to try vacuum forming the fuselage.
-A
AJWoods is online now Find More Posts by AJWoods
Latest blog entry: Xperiment Balsa Build
Old Aug 12, 2015, 03:28 PM
funwithplanes is offline
Find More Posts by funwithplanes
perplexed genius
United States, PA, Fairfield
Joined Dec 2014
what days are neat fair i am interested in going!
funwithplanes is offline Find More Posts by funwithplanes
Old Aug 12, 2015, 03:39 PM
AJWoods's Avatar
Joined Jul 2005
September 18, 19, 20th, indoor nights are Friday and Saturday.
-Adam
Old Aug 12, 2015, 05:51 PM
perplexed genius
Joined Dec 2014
thanks!
Old Aug 13, 2015, 01:34 AM
AJWoods's Avatar
Joined Jul 2005
I did a test cut tonight using the profiles I came up with. Glides like a champ!
A PSA to anybody that makes weird planes. I always make a little chuck glider at the beginning of every build. Its a quick way to make sure that the areas are correct (enough vertical behind the CG for these cartoon planes,) and it lets you dial in CG without dorking your finish painted creation.
Hopefully tomorrow evening I can get the fuse plug shaped.
-Adam
Old Aug 14, 2015, 02:15 AM
AJWoods's Avatar
Joined Jul 2005
Got the plug almost finished tonight, just need to make the gear sponsons, and cut the center barrel lengthwise.
-A
Old Aug 14, 2015, 03:33 AM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
thats going to be awesome! rolling wheels will be needed as well as some toon-JATO's
derk is offline Find More Posts by derk
Old Aug 14, 2015, 09:04 AM
Petefoss is online now
Find More Posts by Petefoss
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
I've got a couple old Estes 1/4A rockets!
What do you finish the foam plug with for forming Adam? I have a friend who likes Tower Coat film for fiber glassing but I don't know if it would work for thermoforming or not?
Petefoss is online now Find More Posts by Petefoss
Old Aug 14, 2015, 10:48 AM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
IF... one Heat shrinks a plastic bottle onto a plug , Surface iregularity/finish issues are minor worries.
Foam is sketchy as a plug however. Given the 250~300degree Oven heat required ..And the surprising compressive force from the shrinking plastic.
It will work.. only Once... though.
However..Use wood (not Balsa) and one can mass produce heat shrunk parts.
Find the lightest thinnest bottle possible, ie the Very small Water bottles would be a decent choice
Bare is offline Find More Posts by Bare
Old Aug 14, 2015, 11:36 AM
AJWoods's Avatar
Joined Jul 2005
This is a pretty high density/high temp machining foam ( I think similar to rohacell). I've pulled polycarb over it in the past for some nose coned and it didn't need any additional treatment. I form the depron at a much lower temp. So hopefully I can pull a fee sets of parts off these plugs.
A
Old Aug 14, 2015, 02:22 PM
speedy01 is online now
Find More Posts by speedy01
Gulf Breeze, FL
Joined Jul 2006
Originally Posted by AJWoods View Post
This is a pretty high density/high temp machining foam ....
Does that have a name and where can I get some (foam, that is)?
Thanks, A.
Gene K
speedy01 is online now Find More Posts by speedy01
Old Aug 14, 2015, 02:46 PM
AJWoods's Avatar
Joined Jul 2005
Not 100% sure, but I believe it's RenShape 5018. It's a polyurethane foam.
-A
Old Aug 14, 2015, 05:32 PM
Petefoss's Avatar
Joined Aug 1999
FYI only sand or shape PU foam. Don't hot wire it, the degradation products from PU foam are particularly nasty.
Old Aug 14, 2015, 08:52 PM
Bare is offline
Canada
Joined Nov 2000
Don't care What foam provenence :-)
I've tried Jelutong wood (favoured d by architectural model makers) .. a wee Plastic Water bottle Compressed hard enough to turn the square wood block into a fair semblance of an Orange... no joke, It squeezes Hard.
Even Pine loses it's sharp edges under that pressure.
Fir does not :-)
Old Aug 15, 2015, 08:55 PM
AJWoods's Avatar
Joined Jul 2005
Vacuum forming was a success, plug held up nicely. Nose was the hardest to form, I porbably should have made the plug about an inch shorter.
-A
Discussion First female Blue Angel performer...in Fat Albert! dll932 Life, The Universe, and Politics 0 Aug 05, 2015 10:04 AM
Build Log ASM C-130 Turned into "Fat Albert" greeter896 Giant Electric Planes 273 Aug 03, 2015 12:15 AM
Sold NEW LEG Fat Albert Kit $120 shipped Artsloper Aircraft - Sailplanes (FS/W) 1 Nov 11, 2013 05:43 PM
Help! GWS CargoTrans C-130 Hercules Blue Angels Fat Albert Decals RCJacq Electric Plane Talk 2 Oct 04, 2006 10:46 PM
C-130 Fat Albert Scheme? Troy Scale Kit/Scratch Built 26 Nov 07, 2004 09:42 PM
