Old Jul 14, 2015, 08:31 AM
Brynmr is online now
Find More Posts by Brynmr
Brynmr's Avatar
United States, SC, Liberty
Joined Dec 2013
Art Hobby Falco E conversion
I'm putting a motor on my Falco but in order to do that I have to switch out my Falco fuse for the Agena fuse. I got all the parts from Andre except the Agena build instructions so I'll need some advice. Should be fun though.
Brynmr is online now Find More Posts by Brynmr
Old Jul 14, 2015, 08:34 AM
Brynmr's Avatar
Joined Dec 2013
On the Agena schematic the boom's length is measured as 550 to 600 mm. Anyone know what determines the boom's final length?
Old Jul 15, 2015, 09:22 PM
Jet_A is offline
Find More Posts by Jet_A
United States, PA, Allentown
Joined Dec 2011
Beats me. Weight in the nose to get the CG correct?
Jet_A is offline Find More Posts by Jet_A
Old Jul 16, 2015, 10:53 AM
Brynmr's Avatar
Joined Dec 2013
Andre sent me a PDF of the building instructions but nothing in it about the length of the boom LOL.
Yeah, I'll get everything together and check the cg before it's all glued down.
Old Jul 18, 2015, 11:46 AM
Brynmr's Avatar
Joined Dec 2013
I caught the idea to place the receiver behind the servos then I read the instructions and that's what they call for. LOL
Anyway, moving along nicely. I want to get to the tail construction before I do anything else. Ok motor first then tail.
Old Jul 18, 2015, 02:01 PM
Lou is offline
Lou
Find More Posts by Lou
Lou
Ground Penetration Tester
United States, VA, Waynesboro
Joined Dec 2005
Looks like a neat conversion. What motor and battery are you going to use? The stripes, you paint those on or use covering?
Lou is offline Find More Posts by Lou
Old Jul 18, 2015, 03:24 PM
Brynmr's Avatar
Joined Dec 2013
Thanks Lou, I'm having fun. I'm using the motor Art Hobby sells for the Agena: http://www.arthobby.com/index.php?pa...ub_category=65
The Stripe are painted on with Krylon Fusion. I have a stripe theme going with my planes. Kind of old school.
Old Jul 18, 2015, 03:32 PM
Brynmr's Avatar
Joined Dec 2013
I might go with this battery. http://www.motionrc.com/admiral-1100...specifications
Or the 1000mAh 2S 7.4V 30C. It's lighter and smaller and will probably be fine for what I need.
Old Jul 19, 2015, 02:02 AM
donsinger1 is offline
Find More Posts by donsinger1
aka KF7DS
United States, OR, Portland
Joined Nov 2009
Brynmr
Which Agena is this, the EV or ES?
Did
donsinger1 is offline Find More Posts by donsinger1
Old Jul 19, 2015, 06:19 AM
Brynmr's Avatar
Joined Dec 2013
The only difference between the EV and the ES is the wing design so all other EV and ES parts are the same. Since I'm using my Falco wing it doesn't matter.
Old Jul 19, 2015, 06:45 AM
Brynmr's Avatar
Joined Dec 2013
Added cool satin black to my canopy.
AND I came up with a REALLY cool way to glue the motor mount in the nose. Here's what you do: Get a coin slightly smaller than the opening and add several washers via CA to one side bringing the thickness to 5mm. Make sure the washers are on the bottom as the coin sits on the table. Place a small sheet of Saran Wrap over the coin to protect it from any glue then you can drop in the glued mount into the fuse and place the fuse nose over the coin. Tap the mount until it's flat against the coin. You get a level and consistent 5mm all around. The hard part is getting the right size coin. I used a British coin which fit perfectly for this model.
Old Jul 19, 2015, 12:04 PM
Lou is offline
Lou
Lou
Joined Dec 2005
Like the colors. It reminded me of years ago when you would see similar on wood canoes, paddles and other wood items. Always liked it.
As for the battery, go with as high of a C rating that you can. I recently puffed a couple of 3s 25c pushing the plane a touch to hard. They are still usable as the puffing is very minor but it was a reminder to be more cautious.
Looks like it is all coming along quite nicely.
Old Jul 19, 2015, 01:59 PM
Brynmr's Avatar
Joined Dec 2013
Lou: So you think a 1000mAh 2S 7.4V 30C would be better than a 1100mAh 3S 11.1V 25C ? I haven't done much research on lipos yet.
Old Jul 19, 2015, 02:25 PM
Lou is offline
Lou
Lou
Joined Dec 2005
A higher 'C' discharge rate is always better...and usually more expensive. The higher rate can take more abuse power wise. If you have already the 25c they will work fine for you.
Mine puffed because I did too long and too many motor burns going to altitude. Totally my fault and not the batteries, they were Thunderpowers. For what I was doing I should have had something like 55c discharge rate batteries.
If you were doing something like ALES or F5J then the 25c would definitely not be a good choice. For general putzing around you should be fine. Sorry if I alarmed you.
Old Jul 19, 2015, 03:22 PM
Brynmr's Avatar
Joined Dec 2013
No problem. I have one 25c batt but the others have a higher discharge rate which I'll probably go with for this plane. Thanks for the info.
Art Hobby Falco-V 60"er tomi Slope 0 Oct 17, 2004 04:38 AM
WTB: Art Hobby Falco wing tomi Aircraft - Sailplanes (FS/W) 14 Sep 27, 2004 08:19 PM
Art Hobby Falco 1.5m Botterii Slope 3 Jun 09, 2003 10:10 PM
Art Hobby Falco V 1.5m Hlg ropuri Aircraft - Electric - Airplanes (FS/W) 1 Jul 16, 2002 08:36 AM
Art Hobby Falco 1.5M HLG leverick Electric Sailplanes 9 Feb 19, 2002 07:56 PM
