Old Apr 03, 2015, 07:33 PM
DLord is offline
Find More Posts by DLord
DLord's Avatar
United States, FL, Cocoa Beach
Joined Jan 2010
Radio Controlled Foiling America's Cup Catamaran: AC 4.8RC
Since the rules were just so dramatically changed for the full size boats AND since two of us have already built boats(as AC 55's from the previous thread) I wanted to come up with basic Rules that would be as close to the new rules as possible while allowing the two completed boats to be immediately legal. John Xman suggested length and beam done to a 1/10th scale. That worked well allowing the two completed boats to closely fit while maintaining the proportions of the full size boats.
AC 4.8RC:
Length: 4.8'=57.625" (rounded)
Beam: max 3.75'=45"/115cm( amended 8/2/15-)
Tentative rules based on my D4Z:
--movable ballast system legal and may exceed maximum beam-no restrictions,
-- foils may extend outside the maximum beam.
--rudders may be transom hung
--SA up to 1900sq"
--no channel restrictions
--no foil type restrictions
--no rig restrictions
Directly scaled Model length is 1/10th fullsize, SA is 1/100 fullsize, weight is 1/1000th fullsize, RM is1/10000th fullsize.
NOTE: sailarea, weight and RM of the model cannot be equal to the directly scaled values from fullsize.
As far as I'm concerned that is the Basic set of rules until more boats are built and an excellent foiling system or systems are developed and proven.
-No boat built under these basic rules may later be disqualified or modified in any way by later rule changes.
My primary direction now will be to complete and foil my boat with three different foiling systems as well as experiment with the Trapeze Power Ballast System. I would imagine Jim in Australia will be doing similar development .
The idea and absolute requirement for a successful RC Americas Cup foiling cat is:
1-that it foils in light air,
2-that it foils upwind,
3-that it routinely gybes on foils,
4-that it is capable of sailing a triangular or windward/leeward course faster than any comparable size monohull.
These will be tough requirements to meet but are essential for future growth of the class.
The D4Z below is one of the first two AC 4.8RC cats and is nearly complete and will be under constant development. Jim in Australia's prototype is under development but is sailing and has foiled for short bursts.
Scratchy 101 had a good idea and that was to not "bury" the original AC 62 thread because he thought it had a lot of good info. So here is a link to the end of that thread for those who want to check it out:
http://www.rcgroups.com/forums/showt...180752&page=48 opens on last page of old thread
DLord is offline Find More Posts by DLord
Old Apr 04, 2015, 05:01 AM
rcmm is offline
Find More Posts by rcmm
Joined Mar 2014
AC4.8RC - Boat 1
A couple of videos to summarise my efforts to date.
My first boat:
AC 55RC Prototype - 6 (2 min 50 sec)
rcmm is offline Find More Posts by rcmm
Old Apr 04, 2015, 05:13 AM
rcmm is offline
Joined Mar 2014
AC4.8RC - Boat 2
My second boat currently under development:
With outward facing L-foils:
AC55 RC (1 min 32 sec)
Same foils inward facing, but effective main foil area smaller:
A 55" Cat (AC) - RC (1 min 44 sec)
Old Apr 06, 2015, 03:09 PM
DLord is offline
DLord's Avatar
Joined Jan 2010
AC4.8RC /D4Z Rig
My D4Z rig is 90.4" from the water to the tip of the wingtip. 1825 sq.in./12.7 sq.ft(1.18sq.m) and it's reefable. Wingtip is 6.5" above top of mast. Mast is 81.5". As usual, my sailmaker is running behind-he just ordered 3 yards of 2.2oz Dimension Polyant ODL material yesterday and says I'll have them by the end of the month. I'm installing the corner reinforcements, battens and the reefing system. Will use an upper "gaff" like the Fire Arrow and a "wingtip" filled with foam like the Fire Arrow. Large sock luff. May install a canting rig system down the line.
Old Apr 09, 2015, 03:28 PM
DLord is offline
DLord's Avatar
Joined Jan 2010
Ac 48
Here is the first render I've seen of an AC 48. This one done Martin, editor of catsailingnews : http://www.catsailingnews.com/
Old Apr 11, 2015, 12:11 PM
Scratchy101 is offline
Find More Posts by Scratchy101
Scratchy101's Avatar
Canada, BC, Greater Vancouver Regional District
Joined Dec 2011
Here's a 2 hour video here on "Foiling in the USA".
Scratchy101 is offline Find More Posts by Scratchy101
Old Apr 11, 2015, 05:34 PM
gio06226 is offline
Find More Posts by gio06226
Joined Apr 2007
If he didn't put the caption in the picture it could have been a rendering of the Oracle AC72 .....
gio06226 is offline Find More Posts by gio06226
Old Apr 11, 2015, 06:33 PM
Joined Dec 2011
Here's a "proportional" drawing from the link I posted in the other thread.
Old Apr 17, 2015, 04:32 PM
BilleFly is offline
Find More Posts by BilleFly
Joined Dec 2010
https://www.youtube.com/watch?v=gAb1JuC1yD0
After looking at your video
it appears that foiling an RC cat ; could present some very difficult
challenges ? I would like to give it a try ; but i'll let you guys do some
more problem solving first .
Right now , i'm gathering info on how to foil with a kite-board ; read the
link below, and you'll see why it will be difficult for me :
http://www.thekiteboarder.com/2010/1...e-billy-floyd/
Bille
BilleFly is offline Find More Posts by BilleFly
Old Apr 17, 2015, 05:02 PM
DLord is offline
DLord's Avatar
Joined Jan 2010
AC 4.8RC Foiling Cat
Bille, you've got courage and guts!!! Good luck with kitefoiling-I hear it's a blast.
Sooner or later several of us working on foiling cats will have a good system. Testing my D4Z will start around the first of June and pictures and video will be here.
There are at least three other guys working on foiling cats but not necessarily AC 4.8RC's. Should be an interesting year........
Hope it goes very well for you!
Old Apr 17, 2015, 07:09 PM
BilleFly is offline
Joined Dec 2010
... Good luck with kitefoiling-I hear it's a blast.
I've bin researching the foils for about a year now ; current weight-shift
control they use on kite-foiling; will NOT work for me because of the
fake legs.
Your name has bin on a Lot of Threads , i've come across in the last year.
I , "Hope" when i come up with a solution for my needs ; i can run them
by you in a (Pm , before i waist a bunch of time building something that
you would already know , (probably won't work) ?
I'll be going with mechanical linkage off my prosthetic(s), for turning
and height control.
Which brings to question for you guys :
How about a flap system to control your C/L with a servo ; until Ya
got the other stuff figured out ? It looked like --rcmm 's-- cat, it jumped
out of the water all at once ; if he could add lift slowly , after the cat got
up to speed ... ? Then all the other technology could kick-in ? Is changing
the AOA of the main foil ; a bit too sensitive right now , for an RC ? Feel
is a Lot in a bunch of different applications ; like me, i have ((O)) feel
from my legs, and my balance is all Visual. There is a considerable lag-time.
Could be the same for foiling with an RC ?
And last : any questions about composite and use of epoxy ; that's what
i'm Good at , so feel Free !! There are some epoxy's on the market, that
are just down-right dangerous to your health ; if not used properly (.)
Thanks : Bille
Old Apr 17, 2015, 08:12 PM
DLord is offline
DLord's Avatar
Joined Jan 2010
D4Z Foils
Bille, my D4Z cat is going to use very, very experimental main foils initially. If they work they will be quite simple and a version might work for you.
Generally foils fall in one of two main categories-fully submerged which encompasses wand controlled foils as well as UptiP foils(mostly) and Surface piercing foils which start out fully submerged but rise out of the water the faster they go until they reach an equilibrium due to speed. Both fully submerged and surface piercing foils use a trailing T-foil(or L foil) on the rudder or rudders that automatically creates pitch stability. I'm thinking that a surface piercing T foil like the ones below might work for you because they have automatic altitude control due to speed.
But any system like this won't be immune to inadvertent body weight movement though they should be a lot more stable in pitch than a current fully submerged kite foil.They should be extremely stable in heave(excellent altitude control). I'll be testing them in a few weeks.
You can PM or e-mail me anytime.
Old Apr 18, 2015, 10:31 AM
BilleFly is offline
Joined Dec 2010
Fingers Crossed !
That is SO COOL ; and your correct, it just could work
for my application.
GOOD Work !!
Bille
Ps : I Like the work you did on your Hulls, as well !! ----- (where is the Thumbs-Up icon ?)
What are they made of ?
Old Apr 18, 2015, 11:57 AM
DLord is offline
DLord's Avatar
Joined Jan 2010
D4Z, an AC 4.8RC America's Cup Cat
Thanks, Bille. The D4Z started life over 15 years ago when I designed it, built the plug and molds and the first kevlar hull. Kevlar was ok until I wanted to modify it to be an "AC" boat but I'll never use kevlar again. The cross arms are torsionally reinforced carbon from the company that became Rock West Composites-the platform can't be twisted. Last June I thought it would be a kick to see if others would be interested in an America's Cup RC cat so I decided to modify the D4Z.
Almost done! Testing of the D4Z and Fire Arrow will start again in late May-June. http://www.rcgroups.com/forums/showt...2190004&page=4
boatdesign.net Fire Arrow thread: http://www.boatdesign.net/forums/mul...36058-135.html
PS it will be inititially tested with a "Trapeze Power Ballast System" for extra righting moment.
Old Apr 20, 2015, 06:07 AM
rcmm is offline
Joined Mar 2014
AC4.8RC - Boat 2 - Wing Sail
Some (very poor) footage of testing with a foam wing sail. The relative positions of the CLR and CoE are not quite right, and initially the sail was too tall. Will try a shorter wing and add a jib.
AC 4.8RC - Wing Sail 1 (1 min 10 sec)
Will add foils when the rig is sorted.
Discussion America's Cup and Wing Sails; Attention Aerodynamicist, and Engineers! Jwmflying14 Dock Talk 8 May 14, 2015 04:32 PM
Review Thunder Tiger - 1/25 ETNZ 1M America's Cup Racing Yacht Kit Review Michael Heer Sailboats 2 Aug 30, 2014 04:22 PM
For Sale Amati Endeavour UK Challenger America's Cup 1934 1:80 BNIB Jlara6 Boats (FS/W) 1 Apr 29, 2014 11:05 PM
Discussion Anyone Watching the America's Cup Races? Pipemajor Life, The Universe, and Politics 78 Sep 28, 2013 02:24 PM
Discussion Foiling Cats, Little America's Cup JIM CALDWELLA Sailboats 5 Sep 25, 2013 06:32 AM
