Old Jul 12, 2015, 06:19 PM
DrFragnasty is offline
Find More Posts by DrFragnasty
Thermal Wrangler
DrFragnasty's Avatar
Launceston Tasmania
Joined Mar 2004
Yellowjacket; easy repair.
I'd use light 'glass and medium Zap.
Rough-up the surface near the crease. Just on one side. The side you have in your photo.
Cut a fabric patch for the fin that bridges the crease, ensuring fibres orient around 90 degrees to the crease. Cut another separate patch for the rudder.
Get a plastic bag to protect your fingers from sticking.
Flood the crease with Zap and apply the fabric keeping pressure on it until it cures.
Make sure it cures straight.
Don't get too close to the hinge.
DrFragnasty is offline Find More Posts by DrFragnasty
Old Jul 12, 2015, 06:24 PM
YellowJacketsRC is online now
Find More Posts by YellowJacketsRC
They Call him Dead!
YellowJacketsRC's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
Thanks for the help!
When you say ZAP, do you mean CA? Does it have to be "Foam Safe" CA?
When you say cut a patch, how wide should it be?
I assume it should be about as long as the crease?
YellowJacketsRC is online now Find More Posts by YellowJacketsRC
Old Jul 12, 2015, 07:00 PM
Thermal Wrangler
Launceston Tasmania
Joined Mar 2004
Medium Zap, I expect it'll be ok on your foam (I can't recall). Apply a tiny bit to test.
As for the size of the patch; see photo
Old Jul 12, 2015, 07:34 PM
They Call him Dead!
Joined Jul 2003
Thanks!
Old Jul 12, 2015, 08:10 PM
Roy_N is offline
Find More Posts by Roy_N
Roy_N's Avatar
United States, WA, Burien
Joined May 2014
Get some of those shot needles with the tips cut off from Armsaor.com and inject the crease with foam safe CA. Have a flat surface available and press flat while the CA cures.
Roy_N is offline Find More Posts by Roy_N
Old Jul 12, 2015, 08:20 PM
Masterpiece is offline
Find More Posts by Masterpiece
Hervey Bay, Sunny Qld, Australia
Joined Jun 2001
Armsoar.com will work better ;-)
Masterpiece is offline Find More Posts by Masterpiece
Old Jul 12, 2015, 08:37 PM
gtrbaby is online now
Find More Posts by gtrbaby
New Zealand, Waikato, Hamilton
Joined Jul 2011
I would add a piece of carbon tow along the existing carbon - maybe 2inch long - then do your patch with glass the strength is in the carbon
gtrbaby is online now Find More Posts by gtrbaby
Old Jul 21, 2015, 05:55 PM
They Call him Dead!
Joined Jul 2003
Thomas says these are his throws:
Are they measured from the tab n center of wing?
My throws:
Speed: 0mm
Cruise: 2mm
Float: 5mm
Flaperons:
Up: 14mm
Down: 23mm
Flaps:
~50 degrees
Elevator:
Up: 12mm
Down: Touches boom
Snap Flaps:
Elevator down MAX: Flaperons up 4mm
Elevator up MAX: Flaperons down 2mm
CG:
70mm
Old Jul 21, 2015, 05:58 PM
They Call him Dead!
Joined Jul 2003
Also I am confused about Flaperon settings.
He says 14mm up and 23mm down. Is this measured without flaps being "deployed" ? SO he is describing differential here?
Old Jul 21, 2015, 06:10 PM
Joined Jul 2011
yes - that's differential and quite a lot of aileron movement - you wont need that much
Old Jul 21, 2015, 06:12 PM
They Call him Dead!
Joined Jul 2003
Thanks!
Should I scale the throws back but keep the same percent of differential in?
Old Jul 21, 2015, 06:19 PM
Joined Jul 2011
I ran dual rates - big as shown and scaled back 50% - its easy to over control with the big throws
yes keep same percentage in differential - more down than up
Old Jul 23, 2015, 11:49 PM
They Call him Dead!
Joined Jul 2003
Ok
It just occurred to me that I thought in Differential you typically wanted more throw on the up throw of the aileron than on the down. Having so much more down throw as he states is going to cause al lot of drag on that side and create adverse yaw, no?
Awesome 480 Neos - awesome prices Andrew Gilchrist Aircraft - Electric - Airplanes (FS/W) 0 Nov 05, 2001 05:52 PM
