Old Aug 13, 2007, 11:43 AM
Sir-Ipswich is offline
Find More Posts by Sir-Ipswich
Sir-Ipswich's Avatar
Joined Feb 2007
HOT Head; Is there a quick fix?
My 1/10 scale nitro antique gets really hot so hot the the chassis becomes too hot to handle. (alumminium)
I have tryed richening the needle settings but a trail of fuel comes out of the exhaust.
The head is plain alumminium, i tryerd wraping it in copper wire to increase suvface area, no luck
Any ideas? can i get a giant cylinder head?
Sir-Ipswich is offline Find More Posts by Sir-Ipswich
Old Aug 13, 2007, 06:51 PM
ronmeister is offline
Find More Posts by ronmeister
Love is like Pi: Irrational
ronmeister's Avatar
USA, ND, Grand Forks
Joined Jan 2005
The copper wire could very well be insulating it, not adding surface area for further cooling.
You can buy larger engine head yes.
You can also add engine shim(s) to increase the displacement, but I have a feeling that the shims wouldn't do much.
Have you checked the engine temperature in the first place?
The engine could very well be running right, but a lot of heat is just transfered to the chassy.
For me, if the engine mixture is right, and it is running well, I wouldn't be turned away because the chassy is hot.
Ron
ronmeister is offline Find More Posts by ronmeister
Old Aug 14, 2007, 02:25 PM
Associated Freak is offline
Find More Posts by Associated Freak
R/C Freak
Tulsa, OK
Joined May 2007
I used to have this same problem from my RC10GT. I simply used some spare lexan from a body that I was painting up and made some shims to fit under the engine mount to insulate the mount away from the chassis. The chassis still gets warm, but not as bad as before and seems to have had no negative effects thus far. (Shim was added 4 years ago)
Associated Freak is offline Find More Posts by Associated Freak
Old Aug 19, 2007, 06:47 PM
rageworks is offline
Find More Posts by rageworks
Joined Jan 2006
Try wearing some gloves.
rageworks is offline Find More Posts by rageworks
Old Aug 21, 2007, 04:41 PM
grungerguy is offline
Find More Posts by grungerguy
its hard living in the UK
grungerguy's Avatar
Joined Oct 2005
i like your thinking
grungerguy is offline Find More Posts by grungerguy
Cool Hot Glue = quick fix? Chriscc123 Coaxial Helicopters 3 Apr 22, 2007 10:16 PM
HB Broken Main Frame Quick Fix David Griffith Micro Helis 0 Apr 05, 2004 02:13 PM
Voyager E Low HEad Speed Wobble Fix? jrhelicopters Electric Heli Talk 13 Jun 03, 2003 03:50 PM
Is there a way to fix Jurassic 400 can motor? genovia Electric Plane Talk 6 Aug 30, 2002 04:04 PM
Piccoboard gyro--quick fix Eco8gator Electric Heli Talk 3 May 31, 2002 01:22 PM
