Old Mar 15, 2002, 12:43 PM
MX is offline
MX
Find More Posts by MX
MX
Embedded Systems Engineer
MX's Avatar
Grass Valley, CA
Joined Sep 2001
Mounting RFFS-100 coils?
How are people mounting their RFFS-100 actuator coils?
Do you use CA to permanently mount them? I'm a little
hesitant to make them permanent given my crash record.
Would hot glue work? Then I could peel it off if the plane
is totaled and move them to a new airframe.
MX
MX is offline Find More Posts by MX
Old Mar 15, 2002, 01:01 PM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
I CA'd mine on. But, I had the same thoughts, so I tried to use a minimal amount of CA. My thought was that I might be able to use debonder to soak them loose. But, hopefuly this doesn't affect the glue used on the actuators themselve. Good question. Maybe experienced actuator users will tell us what they do.
Phil? Ralph? Graham? Mark?
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Mar 15, 2002, 01:05 PM
Graham Stabler is offline
Find More Posts by Graham Stabler
Sticky Shepherd
Graham Stabler's Avatar
Oxford/England
Joined May 2001
I allways model with foam so there easy to break off whatever glue you use, but if you are going to glue them to balsa I have heard ambroid is good as it may be removed with thinners. Water soluable glues like pva might be another alternative.
Graham
Graham Stabler is offline Find More Posts by Graham Stabler
Old Mar 15, 2002, 01:13 PM
Dave Wulff is offline
Find More Posts by Dave Wulff
Dave Wulff's Avatar
USA, FL, Fort Lauderdale
Joined Feb 2002
Wind your own, it's easy and cheap. Then you can just forget about the old coils. After much talking with fill I have refined a winding method that uses no soap/white glue, and no soaking to get them apart. Beautiful, finished coils in under an hour, most of which is drying time for the epoxy. The trick may be to find the wire, 41-44 awg. If there is interest, I will post the method. Just let me know.
Dave Wulff is offline Find More Posts by Dave Wulff
Old Mar 15, 2002, 01:29 PM
Mcfly is offline
Find More Posts by Mcfly
Fort Wayne IN USA
Joined Jan 2001
Dow, I would like to learn how to wind my own actuators, Please post!!! Thank you, Bill
Mcfly is offline Find More Posts by Mcfly
Old Mar 15, 2002, 01:32 PM
opualuan is offline
Find More Posts by opualuan
high-speed freak
opualuan's Avatar
San Jose, CA
Joined Sep 2001
yes, of course there is interest. do tell!
I wrapped my coils in a thin strip of fiber-reinforced 3M tape, then glued the tape to the surface. I was worried about the insulation flaking off if I needed to remove them... now, it's just tape sticking to them. it weems to work fine this way.
opualuan is offline Find More Posts by opualuan
Old Mar 15, 2002, 02:13 PM
Boston, Mass
Joined May 2001
Dow,
How about posting, and then writing up a short technique article for the Ezone. Remember Dave Lilley's exorting us to do this so the information becomes permanent. Seems to me this is something that should become permanent. Plus, you'll go down in the history of Micro and be famous forever.
Maybe you and Phil can co-author it. I got the publishing guidelines from Dave and it's pretty basic. Send a Ms Word file and any photos. He does the rest. You can write it in HTML if you want, but that's not required.
Old Mar 15, 2002, 02:26 PM
Charley is offline
Find More Posts by Charley
Thousand Oaks, Ca
Joined Jan 2002
Coil Winding
Dow
Please share your coil winding method with us.I was able to buy a few ozs of #41 and #44 wire from a email friend;so am ready to try a different method of winding coils as I have not yet mastered the ART of winding coils.So have to buy from DU ,Cloud9 or Aeronutz in England until I can DIY. This from a retired electronics aerospace engineer.
THanks Chuck
Charley is offline Find More Posts by Charley
Old Mar 15, 2002, 02:53 PM
Dave Wulff's Avatar
Joined Feb 2002
Hot topic, huh? I ran it past Phil last week, so it is basically typed up. Just needs a little fine tuning to clear a few details up. Will post it on a new thread, today if I can.
Dave W.
Old Jul 02, 2002, 04:09 PM
Inari is offline
Find More Posts by Inari
Las Vegas Realtor
Inari's Avatar
Las Vegas
Joined Feb 2002
I used a hot glue gun. The glue will peel right off when needed.
Inari is offline Find More Posts by Inari
Old Jul 02, 2002, 04:41 PM
aeronutz is offline
Find More Posts by aeronutz
Leicester England
Joined Jun 2001
BEEN HERE DONE THIS
We went throught all this moths ago - yawwwn !
Search for coils in the data base?
One thread started out in Latin it was that olde
I am sure GS will dig up a thread for you
Mark
aeronutz is offline Find More Posts by aeronutz
Old Jul 02, 2002, 05:13 PM
Sticky Shepherd
Oxford/England
Joined May 2001
Mark, this thread IS from months ago, Inari was mearly adding something to it.
Now behave before I set the dogs on you
Graham
Old Jul 02, 2002, 06:17 PM
Inari is offline
Las Vegas Realtor
Inari's Avatar
Las Vegas
Joined Feb 2002
and we go through the "we've been through this before, check the threads" remarks before. Let's not alienate the newer folks here. I'm sure the question "What's the best trainer" has been asked many times over however each time it elicits dynamic new responses and no one complains. Lets learn not burn.
Range issues and homemade connectors for RFFS-100 fill Scratchbuilt Indoor and Micro Models 12 Feb 28, 2002 03:32 PM
Wanted - RFFS 100 Allan Wright Aircraft - Electric - Airplanes (FS/W) 0 Feb 24, 2002 08:43 AM
RFFS-100 Opinions mlitke Scratchbuilt Indoor and Micro Models 6 Feb 23, 2002 10:54 PM
RFFS 100 Shipments dhurd Scratchbuilt Indoor and Micro Models 9 Feb 15, 2002 02:07 PM
RFFS 100 Videos dhurd Scratchbuilt Indoor and Micro Models 9 Feb 13, 2002 02:25 PM
