Old Sep 13, 2014, 02:17 AM
RedRotorRC's Avatar
Joined Jul 2014
New Product
STRIDER 250mm - Next Generation Multirotor With Onboard RROSD Engine
At REDROTOR RC we’ve been working very hard on an awesome new product and are proud to present a limited pre-release offering of 'Strider’ with built in RROSD engine!
Pre-order the Strider here
First batch has been all shipped out!
Visit WWW.REDROTORRC.COM
DOWNLOAD USER MANUAL HERE
We’re introducing a 250mm size Quadcopter with enormous amount of tech in an extremely compact package. We've integrated a ton of timely, costly, and complicated electronics features into the frame to save you money, time, and headaches while delivering the most feature rich balanced mini quad on the market today.
Designed proudly in California by bt408 and drclawscat
Watch the Introduction here and subscribe:
Strider Mini Quad Intro by RedRotor (2 min 21 sec)
Crash Reel!
Strider Mini Quad Crash Reel Volume 1 (2 min 21 sec)
RROSD Feature Sneak Peek
Strider 250 RROSD Feature Sneak Peek (1 min 13 sec)
Early RROSD In Action Sneak Peek
Strider 250 RROSD w/ Fatshark Dominator HD Feed (1 min 46 sec)
Desktop Wallpaper
Airframe
FEATURES:
• 126g* lightweight, compact, ultra-stiff, folding, 250mm symmetric, & highly durable carbon fiber airframe
• Premium all aluminum and nylon hardware mix for ultimate weight and strength
• Designed for both 5” and 6” props and a unique dual folding mechanism (one for crashes, one for storage)
• Filtered regulated power support for 3S-4S
• Jello-free isolated HD video mount provides silky smooth video
• RROSD (Integrated OSD) with remote timer, voltage, current sensor, RSSI (digital and analog), remote control super bright LEDs, and remote control lost model siren.
• Filtered power for FPV transmitter and camera
• Lightweight: AUW of 540g with 2200 3s, all FPV gear, wide lens Mobius fully loaded!
• Keep reading for full details…
AIRFRAME:
• Perfect X symmetry, ultra stiff and light frame design provides for the best possible flight characteristics
• Rugged, stiff, and durable carbon fiber frame designed to survive non-stop crashes
• Lightweight and ultra compact folding frame weighs only 126g* and measures 208mm x 65mm x 40mm folded up
• Support for both 5” and 6” propellers with extending arms and on the fly configuration swap; measures 250mm -264mm
• Vibration isolation mount allows for silky smooth HD recording
• Forward oriented chassis design provides a 123 degree horizontal FOV for you HD camera with no extension plates required on both 5” and 6” prop configurations
• Pop Slot allows the arms to 'give’ on a crash to absorb impact and still allow take-off w/o fear of props hitting chassis, quick reset design allows you to quickly reset arms to the preconfigured position instantaneously
• All ESCs mount within the chassis and a minimal arm profile provides maximum lift with minimal prop wash loss
• M2 12 x 16mm and M3 16 x 19mm bolt patterns fits a wide variety of motors
• Versatile and functional plates allow many FPV gear mounting options
RROSD ENGINE:
• Built in RROSD engine provides:
• Built-in power distribution and regulators to handle 3S and 4S systems
• Filtered FPV line for video transmitter & flight camera with pre-installed hookups
• Selectable 12V and 5V output for FPV cam
• Accurate flight pack voltage, current draw, and mAh consumption display
• RSSI (digital and analog compatible) displays in percentage
• Remote control of start/stop flight timer in OSD
• Remote control of super bright LEDs for orientation and group flying
• Remote control lost model siren
• Programmable alarms for pack voltage, current consumption
• Firmware upgradable
What you need to add:
Flight Controller, Video Transmitter, FPV Camera, 4x Motors, 4x ESCs, Battery, and Propellers, HD Camera optional.
Recommended Electronics:
Flight Controller: Naze32 or CC3D
Speed Controllers: BS12A ESCs or BLHeli 12A ESCs
Motors: Sunnysky x2204s – 2300KV or Cobra 2204-2300KV, Cobra 2204-1960KV
Video Transmitter: 5.8Ghz ImmersionRC 600mw, Boscam TS832 600mw
Video Antenna: Cloverleaf or Skew Planer Wheel
Flight Camera: 35mm PZ2404 or 25mm HS1177
Batteries: 3s (1300-2200) or 4s (1300 - 2200)
Propellers: 5x3 GF, 5x4 GF, 5x4.5 HQ, 6x3 HQ, 6x4.5 HQ, 6x4 GF
RedRotorRC is offline Find More Posts by RedRotorRC
Old Sep 13, 2014, 02:21 AM
RedRotorRC's Avatar
Joined Jul 2014
reserved 1
Old Sep 13, 2014, 02:22 AM
RedRotorRC's Avatar
Joined Jul 2014
reserved 2
RedRotorRC's Avatar
Joined Jul 2014
reserved 3
Old Sep 13, 2014, 03:59 AM
deno6031's Avatar
Turkey, Izmir
Joined Oct 2011
now this looks very prominig good work
deno6031 is offline Find More Posts by deno6031
Old Sep 13, 2014, 06:46 AM
Coaxial to CP? *shrugs*
ShaneXman's Avatar
United States, CA, Laguna Niguel
Joined Nov 2011
*WOOT* *WOOT*
Nicely done guys! I can't wait to see this thing in action. *thumbs up*
-Shane
ShaneXman is offline Find More Posts by ShaneXman
Old Sep 13, 2014, 07:11 AM
MassiveOverkill's Avatar
United States, FL, Melbourne
Joined Feb 2011
Very interesting.............so if I'm looking at this correctly the 2nd bolt is in a slot and friction holds the arm in place, but in a crash the bolt will slide in this slot. Ingenious!
To fix, you simply loosen the bolt, slide it back into position and re-tighten. Sure beats having to replace zip ties\nylon bolts. Only improvement I can see is maybe installing a squat lightweight wingnut-type fastener so you won't need tools to loosen\tighten the nut. A spring-loaded slot may work too but the existing design looks great.
MassiveOverkill is online now Find More Posts by MassiveOverkill
Site Sponsor
Old Sep 13, 2014, 11:25 AM
Bay Area, CA
Joined May 2000
Originally Posted by ShaneXman View Post
*WOOT* *WOOT*
-Shane
Thanks guys!
Yes the second (outer) bolt on the arm slides along the slot to absorb even the most severe crash. This concept works really well to save bolts and arms from breaking as you said. To reset the arms, you simply 'yank' them back to the original position, there's no need to loosen any screws
bt408 is online now Find More Posts by bt408
Old Sep 13, 2014, 11:39 AM
Conradm's Avatar
Joined Jul 2014
That looks awesome!
Conradm is online now Find More Posts by Conradm
Old Sep 13, 2014, 03:00 PM
Team WarpSquad
Cτte d'Ivoire
Joined Jun 2012
Originally Posted by RedRotorRC View Post
We’re introducing a 250mm size Quadcopter with enormous amount of tech in an extremely compact package. We've integrated a ton of timely, costly, and complicated external features into the frame to save you money, time, and headaches while delivering the most feature rich balanced mini quad on the market today.
bt408 and drclawscat: Could you provide a summary of how this Strider 250 differs from the Nemesis 250? Built-in OSD and the sliding arms are obvious. What are some other improvements that you guys incorporated into the new design?
Brainstorm is offline Find More Posts by Brainstorm
Old Sep 14, 2014, 01:25 AM
ezikiel12's Avatar
United States, CO, Denver
Joined Mar 2013
Looking forward to getting my hands on this beast
Excellent work as usual, I'm sure quite a few of us Colorodans will be sporting one of these bad boys asap
ezikiel12 is online now Find More Posts by ezikiel12
Old Sep 14, 2014, 03:29 AM
RedRotorRC's Avatar
Joined Jul 2014
Hi Brainstorm, the two airframes are separate design wise in quite a few ways. They both have their place and purpose in the mini world. Both will be supported by us and parts will go up on the RedRotor site soon!
Focusing on this offering:
What really sets the Strider apart from all other frames is the electronics core. Power Distribution, 3s and 4s Regulation with 12v and 5v out, FPV system filtering, plug and play electronics, independent channel control of LEDS/siren, complete OSD engine onboard the frame sends back RSSI readout, load, timers and current/voltage monitoring + more all built into the frame really set it apart.
It's way faster and easier to build since it's all nicely integrated in a single onboard engine. Solder you esc and motor wires, battery lead and you're mostly done with the build aside from plugging in cables to the frame (RSSI, 3 channel input, vtx, cam, etc).
The frame is designed for agility + flight time. With all the electronics onboard the final AUW is easily 80-100+grams less than what you might find on a frame with comparable features. The meticulous airframe design focus ensures it's ultra stiff, weighted well, and durable while featuring vibration isolation only on the camera to give you the most direct responsive flight control/feel.
Can't wait to get one in your hands Justin!
Old Sep 14, 2014, 03:39 AM
RedRotorRC's Avatar
Joined Jul 2014
A couple scenarios to picture:
-Fly with more confidence being able to see your RC link strength, how many amps your motors are pulling, and your battery status!
-If your Strider goes down, activate the strobe and Siren mode to locate it quickly.
-Flying with buddies? Activate different LED patterns on the fly to locate each other and identify who's who.
-Switching from 5" to 6" props for high altitude, efficiency, or maximum thrust in minutes by changing props, loading new settings into your fc, and resetting pivot screws to 6" configuration.
-Traveling? Pull the arms out and fold them either inward or forward to store the Strider in a compact package.
-Crash land? With the slot system, if you land right side up with mainly intact props you can takeoff again without worrying about your props hitting cables or each other and return home. Simply yank the arms forward to put them back into their designated position.
Old Sep 14, 2014, 03:54 AM
Switching to guns!!!
CO_rcDude's Avatar
Littleton, CO
Joined Dec 2009
Lookin good!!! My wallet is in the corner crying right now.
I see miniquads all headed this way before too long. Why not? It makes perfect sense to have some of the electronics integrated into a frame element!
CO_rcDude is offline Find More Posts by CO_rcDude
Old Sep 14, 2014, 08:12 AM
R.C. Aviation Fanatic
Razors edge 29's Avatar
Canada
Joined Aug 2009
Very interesting concept.
Even though the integrated electronics on frame is a great idea, I'm wondering about the strength of this plate and how easily it will damage in a crash
also
price to replace this section?
Razors edge 29 is online now Find More Posts by Razors edge 29
Discussion The Next Generation to the Gnott, SmArt Just a mo Royal Air Force Model Aircraft Association (RAFMAA) 1 Nov 18, 2013 03:12 AM
Sold Star trek the next generation sketch book movies generations and first contact innoplastic Non R/C Items (FS/W) 0 Jun 07, 2013 12:22 AM
New Product The Next Generation of full metal EDF with PATENT design EPF HOBBY Product Announcements 250 Jan 28, 2013 06:15 PM
Discussion Next Generation Onboard video technology questtek Dock Talk 15 Jan 20, 2011 11:17 AM
Alert The Unicorn - a Next Generation EPP flying wing Newest Generation thread part III Don Sims Foamies (Kits) 507 Apr 22, 2004 01:25 AM
