Old Sep 03, 2014, 06:23 AM
NITRO !
Gary Cee's Avatar
United States, MI, Marysville
Joined Apr 2010
Tassie Mike ,
IMPRESSIVE ! Thanks for the link .
I am all the more eager to get mine going .
Gary Cee is offline Find More Posts by Gary Cee
Old Sep 23, 2014, 06:39 PM
Joined Sep 2014
Tower .61 Gas-glow
Warning! Do not try this unless you are ready to possibly hurt your engine.
While searching for the G5 plug I found a video on You Tube(www.youtube.com/watch?v=3vPjmw7Cz6k0 of someone runing a ST2500 on gas using a glowplug.This was before OS. Did not say what plug. Ran with problems with a pump carb. Said a smaller engine ran fine with the igniter left on. I ran my Tower 61(reg. carb) on gas with a Fox idlebar plug. I will try different plugs. OS if i can ever get one. Had to keep the battery on. Thats OK, I will just have an onboard battery. Plug was not hurt in any way. It was very rich with the same glow setting, but it started(flipping) and kept running. It did not sound rich, so I tried leaning and richer and had to lean a lot. It sounded good. I have not tached or flown it yet. The idle mix did not need to be reset. I was using 87 regular gas16-1 or 8% non synthetic outboard. Only ran it a minute or so at full throttle. Ran very cool and it is very free, unlike castor. I did not take it apart, but rocking I could not feel a loose con. O f course it should wear out the con. bearing. I will run it and see. I have been running glow engines for 60 years and no one said to use gas. So far so good. I am still shaking my head. Wild. HK #3 glow plug did not work. Started OK. Fox long idlebar so far is the only one. It runs like regular alcohol glow fuel. Ether(starting fluid) might be added to the gas to get it to run with out the battery. Since no wear right away, I will have to run a gallon or more. It will take a lot of time. So I might not update for awhile.
I am using the .60 to test the worst case. Small crank pin. I will try a ST4500. I have been running 10-12% oil with Methanol. 8% oil with gas should not hurt it. I will also try a Ryobi at 32-1 to see if less oil makes it run without the battery connected.
I think this is artificial pre-ignition. If a piece of carbon is in a gas cylinder, it may start to glow. It may fire the cylinder before the sparkplug. It will fire advanced of normal timing, which may hurt the engine. Here the timing is adjusted by the mixture, so it does not hurt anything.
saturn13 is offline Find More Posts by saturn13
Sold OS GT33 Gasoline Engine $300.00 FlyawayClyde Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jan 22, 2014 08:52 AM
Sold 5 NIP OS glow plugs type F bribtb Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jan 05, 2014 11:18 AM
Sold OS #RE, Fireball, K&B, and other Glow Plugs wing881 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Nov 10, 2013 12:49 AM
Sold OS .46 LA engine with muffler, glow plug chris8105 Aircraft - Fuel - Airplanes (FS/W) 5 Sep 18, 2005 06:45 PM
Help! when starting os 4-stroke engine dies after taking off glow plug ingnitor EKI16 Engines 15 Aug 01, 2004 04:01 PM
