Old Apr 11, 2016, 07:41 AM
Death_From_Above is offline
Find More Posts by Death_From_Above
Death_From_Above's Avatar
United States, IN, Walkerton
Joined Jan 2012
MSRX servo replacment
hi,
i recently puchased a used msrx. the right side servos would stick and lag. so i removed it and replaced with one from my old mcpx's.
when i was done soldering , put battery in to check, the servo would max out and become very hot. did ths on two different servos. both mcpx servos worked before attatching to msrx board.
its just a blue n red wire, did i miss somthing?
Death_From_Above is offline Find More Posts by Death_From_Above
Old Apr 11, 2016, 09:30 AM
dankar04 is online now
Find More Posts by dankar04
Tucson, Az
Joined Feb 2007
Mcp-x is a c/p heli that uses much bigger battery then MSR-X. The rate freq. might be different. Did you try cleaning old MSR-X servo ? I never tried mixing servos in these. Possible HH might have new ones or help you out. Just because servos fit do not mean they work in another type heli. Some of bigger heli flyers find this out when put $5.00 servos in 450 c/p's.
dankar04 is online now Find More Posts by dankar04
Old Apr 11, 2016, 10:20 AM
Joined Jan 2012
oh wow. never thought of that. ill try cleaning again tho.
but ebay has a few servos claiming to work for msrx and mcpx.
http://vi.raptor.ebaydesc.com/ws/eBa...=1460387111468
servo 6833 should work for both? any chane my stock v1 mcpx servos are non compatible for the msrx? or this add is wrong?
i also have a brand new 6833 servo i haven't tired yet..
sorry , im new to blade helicopters...
Old Apr 11, 2016, 10:38 AM
Joined Jan 2012
i just looked a little closer. in the pic you can see at the top of servo, is a little different with the metal piece . i feel stupid now over looking that. but i cant find any info regarding replacment servo number for msrx. minus those sites claiming 6833.. and a new board is $60+
Old Apr 11, 2016, 11:05 AM
Joined Jan 2012
Eureka !
http://helifreak.com/showthread.php?t=398493
apparently the upgraded 2.3g SPM6836 or the servo from SPMSA2030L is the stock servo on msrx?
so confused....... 6836 , SPMSA2030L is listed as upgrades to the mcpx and nano cp. why is it stock for a FBL heli?
Old Apr 13, 2016, 05:31 PM
elan is offline
Find More Posts by elan
elan's Avatar
VT
Joined Feb 2006
Originally Posted by Death_From_Above View Post
Eureka !
-All of those models your mentioned are FBL helis...
elan is offline Find More Posts by elan
Old Apr 14, 2016, 12:34 PM
Joined Jan 2012
the 2.3g servo is said to be an upgrade for the mcpx from the 1.9g.... i was wondering why msrx would need more torque than mcpx..
Wanted Looking for BMS 308BB servos to replace my stock S60 servos on 200SRX Phil McCrackin Aircraft - General - Radio Equipment (FS/W) 0 Feb 03, 2016 12:20 PM
Discussion Do I need to do a servo calibration after replacing my servo? Noobie1 Micro Helis 4 Oct 14, 2015 09:19 AM
Discussion Blade MSRX & MSR replacement? Palm Desert Heli Beginner Training Area (Heli-Electric) 9 Feb 12, 2014 12:38 AM
Msrx bnf basic for tgy9g or hex9g servos RcAirplaneNoob Non R/C Items (FS/W) 0 Dec 07, 2013 02:02 PM
Wanted Your 9g servos for my blade msrx bnf RcAirplaneNoob Aircraft - General - Radio Equipment (FS/W) 0 Dec 07, 2013 02:01 PM
