Old Mar 15, 2016, 06:32 PM
Roadkilld is offline
Find More Posts by Roadkilld
Joined Mar 2016
Hacker b50 9xl?
Hello-I just got a hold of an old unused hacker b50-9xl for a very good price,I am trying to learn about fast electrics because I want to change some of my old nitro boats to electric. From what I read about this motor, it is a 12-18 cell motor, I really want to try this in a Dumas sorcerer wood boat (45 nitro),but I also have 2-55" scarabs,also. If I try this on my sorcerer,could I bring the cell count down to 4-6s,and what would be the ramifications if I did so, and would this motor also be a viable choice for one of the scarabs? Any opinions or info would be welcome since I am in the beginning stages of learning about the FE arena-----Thanx!
Roadkilld is offline Find More Posts by Roadkilld
Old Mar 15, 2016, 07:54 PM
AirDOGGe is online now
Find More Posts by AirDOGGe
Just Plane Nutts
AirDOGGe's Avatar
United States, CA, Mountain View
Joined Dec 2011
Motor specs to start from:
Description:
Model: B50 9XL
Powerange: max. 1700W (15 sec.)
Idle Current @ 8,4V: 2,22A
Resistance (Ri): 0,0098 Ohm
RPM/Volt (kv): 1753 U/min-1
Weight: 340g
Diameter: 35.8 mm
Length: 74 mm
Poles: 2-Pole Inrunner
Recommended ESC: 48A to 90A Brushless
Recommended timing: 0 - 5
Shaft Diameter: 5 mm
AirDOGGe is online now Find More Posts by AirDOGGe
Old Mar 17, 2016, 07:03 AM
Joined Mar 2016
Thanx for the info,I am surprised that nobody else had anything to add......
Old Mar 17, 2016, 02:23 PM
785boats is offline
Find More Posts by 785boats
RELAX. You'll live longer
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
I think you will find that the 3674 motor is underpowered for the 37" Sorcerer & definitely for the 55" Scarabs.
At 1700w max it means a continuous rating of around 1000-1200w. The prop size required to drive the boat might be too big for the motor to spin comfortably on 6s at 38,900 rpm
On 4s (25,900 rpm) you might get away with a 445 prop being big enough to drive the boat but the amp draw might be up there. You can only try.
The 55" scarabs are going to need a 8s - 10s setup as a minimum. A 12s setup would be the most efficient for hulls that big.
All depends on your speed & run time desires.
785boats is offline Find More Posts by 785boats
Old Mar 23, 2016, 04:44 PM
Joined Mar 2016
Exactly what is meant by a 8s-10s setup? Are you saying that using 8s-10s with this motor , or a whole different powertrain altogether- just a little confused,because I originally thought that this motor had alot to offer,if you had to compare it to a glow motor,what size would you consider it to be? Converting to electric is still quite confusing,when the only experience that I have is with glo engines,so I'm still stuck in thinking in those terms-sorry.
Old Mar 24, 2016, 12:00 AM
785boats is offline
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
Hi Roadkilld.
When I mentioned a 10s-12s for the 55" Scarabs, I was meaning a different driveline on those voltages.
Maybe a Castle 2028 780kv on 10s or similar kv rating 56 series motor.
On 12s maybe a 56 series motor of around 550-650kv.
ESC would be a 240A HV Castle or Swordfish. It all gets a bit expensive for boats that big.
There are other motors & ESC's out there but these are middle of the road budget items
http://www.ebay.com/itm/Castle-Creat...-/301304585797
http://www.offshoreelectrics.com/pro...p?prod=tp-5670
http://www.offshoreelectrics.com/pro...ef-HBC0240L-CW
The 3674 motor would possibly be equal to a .15 or .20 glow motor. I'm not sure.
All I can say from personal experience is that we use that size motor in 26-32" boats that would usually run a .21-.35 glow motor, if that helps.
I don't have much experience with glow motors so hopefully someone else can put forward some comparisons. Especially for the bigger Scarab hulls.
Old Mar 24, 2016, 07:52 AM
Joined Mar 2016
Thank you so very much,now I have a little better understanding of this motor,and its limitations!
Sold NIB Hacker B50-9XL 5.2:1 / Trade for glow/ Futaba 2.4 ton2di Aircraft - Electric - Power Systems (FS/W) 1 Oct 31, 2014 07:12 PM
Wanted Hacker B50 9XL or Hacker C50 9L or Neu 1415 miyage007 Aircraft - Electric - Power Systems (FS/W) 0 Jul 28, 2013 08:33 PM
Wtb Hacker B50 9xl W/ 6.7 Gearbox RicVaughn Aircraft - Sailplanes (FS/W) 0 May 14, 2004 10:48 PM
FS: Hacker B50 9XL 6.7:1 W/ESC, TP Li-Poly's, Schulze 636 Jay27 Aircraft - Electric - Airplanes (FS/W) 3 Oct 24, 2003 05:21 PM
WTD Hacker B50 9xl and controller Steve H. Aircraft - Electric - Airplanes (FS/W) 0 Feb 10, 2003 12:02 PM
