Old Apr 13, 2015, 09:28 AM
fmhans is offline
Find More Posts by fmhans
Westbrook Maine
Joined Apr 2003
Help needed Dizzy Space
I haven't messed around with a delta in years, and have a problem. My elevator function is acting like my rudder and my rudder is acting like my elevator. I am using an older dx7
Any suggestions would be welcome.
Fritz
fmhans is offline Find More Posts by fmhans
Old Apr 13, 2015, 11:28 AM
Petefoss is offline
Find More Posts by Petefoss
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
Is that a 3 channel brick? By rudder do you mean aileron? For a three channel brick both servos are on the right stick. Clarify that and then we can talk about mixes.
Are you already using an elevon mix?
Petefoss is offline Find More Posts by Petefoss
Old Apr 13, 2015, 04:08 PM
fmhans is offline
Westbrook Maine
Joined Apr 2003
Thanks Peter. Yes I meant aileron.
I am using elevon mix,
If I reverse Chanel 2 or 3 I can get the elevator and rudder working, but not both working in the proper direction at the same time.
Old Apr 13, 2015, 04:40 PM
Petefoss is offline
Petefoss's Avatar
Joined Aug 1999
One option is to turn off the elevon mixing. That will leave you with one elevon on the aileron channel and one on the elevator. Set the reversing so they are correct. Then mix aileron to elevator on a mix and elevator to aileron on a separate mix. Only weird behavior is the trims will only adjust one servo so you have to use both trims to make a simple adjustment.
If that doesn't work let me know and I'll test on one of my planes to figure it out.
Pete
Old Apr 13, 2015, 07:11 PM
fmhans is offline
Westbrook Maine
Joined Apr 2003
Thanks Peter!
I have spent too much time away from flying to think outside of what is written inside the manual.
I found this model already cut out and packed with a nice store of Durobatics foam. I doubt that I would have built it if It wasn't already cut, hopefully it will perform as well or better than the original areoace version.
Fritz
Old Apr 13, 2015, 08:57 PM
I R Irv is offline
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
If that's a 3CH brick you might need to set the TX to V-tail.
I R Irv is offline Find More Posts by I R Irv
Old Apr 14, 2015, 05:34 AM
Petefoss is offline
Petefoss's Avatar
Joined Aug 1999
Three channel bricks have aileron and elevator on the brick. Its the 6 channel brick that has rudder and elevator onboard and would use vtail.
Old Apr 14, 2015, 04:51 PM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
sometimes having the brick inverted works out too
derk is offline Find More Posts by derk
Old Apr 14, 2015, 09:05 PM
I R Irv is offline
I R Irv's Avatar
Joined Nov 2008
Not my fault, it's my damn Dyslexia.
Old Apr 15, 2015, 08:41 AM
dcwwcp is online now
Find More Posts by dcwwcp
dcwwcp's Avatar
Joined Sep 2008
I have that exact set up on an ember I made in to a V-tail. you should be able to take a clean channel, rebind to it, then select elevon mix and in the reversing, reverse what would be the left elevon I believe.
Well wait a minute, I have a DX8. So that might be different?
with the brick and control rods on top it seems the elevator servo needs reversing.....
dcwwcp is online now Find More Posts by dcwwcp
Old Apr 15, 2015, 06:22 PM
mcross is offline
Find More Posts by mcross
It's a spiderweb of knit lines
Souderton Pa. USA
Joined Mar 2002
I don't know about the DX8 but here's what works for the DX6i and 7.
http://www.rcgroups.com/forums/showt...ght=elevon+dx7
mcross is offline Find More Posts by mcross
Discussion Hex Rotation Problem...Getting Dizzy...Help! Kokobop1 Scratchbuilt Multirotors 14 May 10, 2014 10:59 PM
Sold ----need space please help--- MIKEYOUR Aircraft - Electric - Airplanes (FS/W) 0 Sep 10, 2013 01:19 PM
Video Dizzy Space RacerX208 Electric Plane Talk 1 Apr 15, 2007 12:55 PM
Getting dizzy! BR needs Help!!!!! Bookstar75 BladeRunner Heli 2 Mar 07, 2005 07:47 PM
