Old Mar 30, 2015, 02:51 PM
Beatfreak is online now
Find More Posts by Beatfreak
United Kingdom, England, Leighton Buzzard
Joined Mar 2015
F5b setup
Hi all,
Firstly thanks to all for the much need info for an f5b newbie. Excellent forum.
I'm just building my first f5b machine and have sourced a tacon 3650 and kpg25 5:1 box for my hawk but I'm struggling to get an esc. Do HK still stock the hk200a esc? Been looking for a while but haven't seen any so I've ordered a red brick 200a instead. Will this do the job or should I be on the look out for something else?
Beatfreak is online now Find More Posts by Beatfreak
Old Mar 31, 2015, 01:28 PM
sundaypilot is offline
Find More Posts by sundaypilot
sundaypilot's Avatar
Maarheeze Netherlands
Joined Jun 2004
Out of the box the redbrick will probably hold 200A for short bursts up to 5s. And use max. about 1500mAh per flight. Make sure you have cooling holes in the fuselage and take at least 30min. between the flights. I don't know how much amps your motor can handle?
sundaypilot is offline Find More Posts by sundaypilot
Old Mar 31, 2015, 04:20 PM
Joined Mar 2015
Same as this one
http://www.rcgroups.com/forums/showt...r#post20824541
Old Apr 01, 2015, 01:00 PM
Joined Jun 2004
well, 193A seems to work,
Old Apr 02, 2015, 01:09 AM
Gerben is offline
Find More Posts by Gerben
Joined Dec 2004
The REdbrick/HK200 seems to hold-up at 250-260A.
Startup in standard form can be a little rough, but should be manageable at 3-4S. As long es speeds are not extremely high the brake works ok too.
Ideally flash the controller with George's F5B firmware, which is perfect for hotliner application of the Redbrick/HK200.
Gerben
Gerben is offline Find More Posts by Gerben
Old Apr 02, 2015, 01:10 AM
Gerben is offline
Joined Dec 2004
Not too forget: programming should be done at 2-3S, a higher celcount may overheat the controller during programming, strange but true.
Gerben
Old Apr 02, 2015, 07:48 AM
Joined Mar 2015
thanks for the info, any particular firmware version? I see there are various types with slower/faster ramp etc. Assume I'm better off with a switch than throttle control? (which scares the **** out of me by the way!) Probably going to work my way up from 3s to 5s as my confidence grows
Old Apr 02, 2015, 12:10 PM
Gerben is offline
Joined Dec 2004
At sub 3kw levels the short-ramp seems to work best.
At switch is most used. Don't worry about it, full throttle and a decent toss and you're up and away.
Old Apr 02, 2015, 01:02 PM
Joined Mar 2015
thanks gerben, just need to order the cable and USBasp and get reading...
Old Apr 03, 2015, 04:19 AM
Alan Flockhart is offline
Find More Posts by Alan Flockhart
Cambridge
Joined Sep 2005
Hi Beatfreak, Looks like you aren't too far from a number of the F5B flyers in the UK. Luton, Oxford, Cambs. We may even be having a practice event this weekend (weather permitting) near Huntingdon if you are interested in dropping by to have a chat about setup of the plane.
Drop us a PM if you are
ALan
Alan Flockhart is offline Find More Posts by Alan Flockhart
Old Apr 03, 2015, 05:00 AM
Joined Mar 2015
family commitments this weekend unfortunately but hopefully get to fly something tomorrow! Thanks for the invite.
I've ordered the kit required to flash my esc and dl'd the software etc. Just need to identify the type, assuming type 3 from the layout but can't see any pics of similar, processor says atmega8a au 1415
Old Apr 03, 2015, 06:20 AM
dickw is online now
Find More Posts by dickw
Grow old disgracefully!
dickw's Avatar
Luton, UK
Joined May 2006
Hi Beatfreak
You are only a few miles away from me, so if you want to get together for those initial flights, and help with the launches that should be easy for us to arrange.
I have sent you a pm with my contact details.
Dick
dickw is online now Find More Posts by dickw
Old Apr 03, 2015, 07:09 AM
Joined Mar 2015
thanks dick
not sure my soldering skills are up to adding more caps... can't even see where I'd solder them...
Old Apr 03, 2015, 09:29 AM
Gerben is offline
Joined Dec 2004
You can solder the caps to those two solder-blobs on the top edges of the circuit board, next to the two capacitors (visible in the righthand pic). Be sure to get some good low-esr caps (Rubycon ZL/ZLH/ZLK of Panasonic FM), about 330-500uF, 25V.
Probably need at least a 60W soldering iron.
Maybe Dick can help you out?
Gerben
Old Apr 03, 2015, 09:33 AM
dickw is online now
dickw's Avatar
Luton, UK
Joined May 2006
I can probably help you out with that as well, I have some suitable caps. Check your " private messages" and get in touch.
Dick
Wanted F5B setup GertF Aircraft - Electric - Power Systems (FS/W) 1 Feb 24, 2015 12:22 PM
Question Avionik F5B-7-2001 power setup ptxman High Performance 1 Aug 17, 2014 01:07 AM
Sold RW4b F5B (Raketenwurm) Hotliner F5B Ghog Aircraft - Sailplanes (FS/W) 2 Feb 26, 2014 06:11 PM
Sold 10S F5B Neumotor setup: 1512 2.5d + ice2 160hv la528it Aircraft - Sailplanes (FS/W) 1 Nov 25, 2013 06:40 PM
For Sale F5B power setup NEU1506 zapi2 Aircraft - Electric - Power Systems (FS/W) 7 Oct 29, 2013 10:49 AM
