Old Oct 17, 2003, 10:41 AM
amit is offline
Find More Posts by amit
Joined Oct 2003
Dymond super Charger or FMA Supernova
hi
i am looking to charge my gp 3300 cells. I couldnt get a hold of fma. I noticed the supernova can only handle cells up to 3000 mAH, vs Dymond that can handle up to 5000 mAH.
Anyone have any thoughts which is better charger?
thanks
amit
amit is offline Find More Posts by amit
Old Oct 17, 2003, 10:52 AM
cnims is online now
Find More Posts by cnims
cnims's Avatar
United States, TX, Coppell
Joined Dec 1996
I have the Dymond and I'm happy with it. It's about $40 cheaper as well. Note that some people have had some issues with the buttons freezing up on the Dymond, but this seems to be easily fixed with contact cleaner. I believe that both charges will charge at up to 5 amps.
cnims is online now Find More Posts by cnims
Old Oct 17, 2003, 11:06 AM
KnimRod is offline
Find More Posts by KnimRod
Gravity Tester
KnimRod's Avatar
Central Michigan
Joined May 2003
The Supernova works great with the GP3300s.
KnimRod is offline Find More Posts by KnimRod
Old Oct 17, 2003, 11:29 AM
thangd is offline
Find More Posts by thangd
Sparks, Nevada, United States
Joined Mar 2003
I am using both. They both can charge up to 5000 mAH depends on how many cells you have in your pack. I am in favor of the Dymond, because of the easy menu (IMHO), but the black color of the case will get hot in the sun during the summer.
Thang
thangd is offline Find More Posts by thangd
Old Oct 17, 2003, 02:53 PM
amit is offline
Joined Oct 2003
i would plan on charging gp 3300 cells, 12 at most in a pack.
so both dymond and supernova could do both safely?
Old Oct 17, 2003, 04:59 PM
seanm is offline
Find More Posts by seanm
Joined Sep 2002
I have had BOTH and the SuperNova did better on the 2600's I have. The Turbo would false peak... Sold the Turbo. YMMV.
Sean
seanm is offline Find More Posts by seanm
Old Oct 17, 2003, 07:19 PM
amit is offline
Joined Oct 2003
any problems charging the gp 3300 with supernova?
Old Oct 17, 2003, 07:26 PM
seanm is offline
Joined Sep 2002
I have some 8 cell 3300's and they charge fine on the SuperNova.
Sean
Old Oct 17, 2003, 08:01 PM
amit is offline
Joined Oct 2003
On the supernova, I thought it only comes with 10 preset charging parameter. DO u have to change the settings to charge the gp 3300 ?
Also, hows the cycling on the supernova. I would like to cycle some gp 3300 before using them.
thanks
this is truly a great site with lots of friendly help
Old Oct 17, 2003, 08:19 PM
seanm is offline
Joined Sep 2002
The supernova comes with presets but they are all changable and they stay untill you reset the device (same on the Surbo). I found the Supernova a little harder to program then the SupeTurbo, but once you "get" it it is fine. One thing that bothers me about the SuperNova is that a discharge is always followed by a charge... so if you want to empty batteries to store them you need to be right there when it is done dumping. The up side is it handles bigger packs better in my opinion. My Zagi packs did great on the Turbo, but when I got some larger packs for bigger olknes they would false peak sometimes... No false peaks on the SNova. Again, I sold the Turbo and kept the Nova. I now use the Nova and a Orbit Pro.
S
Old Oct 17, 2003, 11:37 PM
amit is offline
Joined Oct 2003
thanks so much seanM. I will go with supernova! I liked it in 1st place but wasnt sure it was able to handle gp 3300's. thanks again
a
Old Oct 18, 2003, 08:31 AM
seanm is offline
Joined Sep 2002
Please remember, they do have button problems sometimes... but so does the Turbo!!
Sean
5x used Dymond Super Charger FOR SALE CHEAP!! SoulShell Aircraft - Electric - Airplanes (FS/W) 0 Jul 11, 2002 11:51 PM
5x used Dymond Super Charger FOR SALE CHEAP!! SoulShell Aircraft - Fuel - Airplanes (FS/W) 0 Jul 11, 2002 11:50 PM
Dymond Super Charger ???? fly4fun Parkflyers 2 Jul 09, 2002 04:51 PM
Dymond Super Charger DumbThum Power Systems 2 Feb 05, 2002 01:48 PM
Dymond or FMA Supernova? papichulo Power Systems 2 Jul 10, 2001 07:18 PM
