Old Aug 07, 2015, 02:44 PM
Hover or die is offline
Find More Posts by Hover or die
it wasn't me flying that plane
Hover or die's Avatar
United States, NC, Wilmington
Joined Mar 2011
Amp draw of Efilte DF 180 fan/motor combo
Can any of you guys tell me the amp draw at WOT on this fan motor combo?
Tryin to get the info on the amp draw on 2 and 3 cells..
I was able to sand out enough of the foam from the little foam viperjets to get this fan mounted with a thrust tube installed..
I have some different amp ESC's ordered (8/12 and 20 amp) but have a stripped down 30 in there right now..
Going to try to fly it sometime this weekend..
2 linear servos on the ailerons and a micro servo on the elevator..
Any info I can get on the wide open throttle amp draw would be greatly appreciated..
Thanks and take care..........................................Chri s
Hover or die is offline Find More Posts by Hover or die
Old Aug 07, 2015, 02:54 PM
mcross is offline
Find More Posts by mcross
For Sale-everything over 250 g
Souderton Pa. USA
Joined Mar 2002
The Mig/Habu fan unit mounted on a scale I got 52 grams static thrust at 3.0 amps on a 2s Thunder Power 325 65c. That was with a Phoenix 10 esc and a clamp on ammeter. Fan unit weights 13 grams.
mcross is offline Find More Posts by mcross
Old Aug 07, 2015, 03:51 PM
Joined Mar 2011
mcross,
Thanks for that valuble info!!
Well im guessing the 12 amp ESC i have on the way will be fine for 2 cells..
I have some of thosse 65c thunder power 325 mah batteries in 2 and 3 cells and are the exact battery I plan to use with the little viperjet..
I also have some of the 200 mah eflite batteries but they are only like 25c..
A lot lighter though..
If anyone has the exact amp draws on 2 and 3 cells please post up................Thanks ...................Chris
Old Aug 07, 2015, 04:32 PM
mcross is offline
Souderton Pa. USA
Joined Mar 2002
Sorry, forgot the amp draw, it was 3.0 amps.
Old Aug 07, 2015, 09:03 PM
Joined Mar 2011
Thank you mcross!!!
Very nice of you to post that up...
Well it would seem I can probably get away with the 8 amp ESC even for the 3 cell battery.....
Heres a few pics of the old beat up airframe im experimenting with...
Old Aug 08, 2015, 04:27 AM
Jaguar 20040 is online now
Find More Posts by Jaguar 20040
Germany
Joined Jul 2006
you said earlier that you were using a clamp on am meter. Can you give me a link where to find such an ammeter for low currents?
Thanks and regards,
Jaguar 20040 is online now Find More Posts by Jaguar 20040
Old Aug 08, 2015, 06:37 AM
mcross is offline
Souderton Pa. USA
Joined Mar 2002
http://www.transcat.com/aemc-instrum...FceQHwod6UAEHA
Old Aug 09, 2015, 03:14 AM
Germany
Joined Jul 2006
Really necessary to spent some 200 Dollars. So much difference in accuracy in comparison to a low budget unit?
Regards,
Old Aug 10, 2015, 06:45 AM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Was my info via PM not enough Chris?
NitroCharged is offline Find More Posts by NitroCharged
Old Aug 10, 2015, 02:07 PM
Joined Mar 2011
Dave
I started the thread before I got a response from you..
I really appreciate you responding to my PM though..
Im just getting back to building and flying after taking some time away to deal with family..
Ordering some foam ,glass and electronics to start building again..
Miss it big time.................
Thanks and take care......................................Chris
Old Aug 10, 2015, 05:22 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
I hear ya, Chris. It's been a slow climb back into the hobby this end too after many family issues.
Old Aug 17, 2015, 06:31 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
  • Motor/battery-current is proportional to voltage squared and proportional to Kv cubed! Way more than one would expect. (Worst case, ignoring voltage losses/sag due to the higher current ).
    Whether motor can handle those current- and powerlevels is a different story.
  • Simple instructive table giving the extra current when you add one extra cell to a pack
    (a.k.a. "why did my motor and/or controller and/or battery go up in smoke ???")
  • The Kv constant is not a rating, not a figure of merit, in that higher or lower is better, it's just a characteristic. More windings will give lower Kv, less windings will give higher Kv, that's all there is to it. No big deal, anyone can do that. Rewinding a motor with more (thicker) copper will give you a more efficient (Pout/Pin), more powerful and cooler running motor.
  • A motor's Kv constant says nothing about ... max.current and max. power a motor can handle, it is no indiction for efficiency, rpm, quality, torque, propsize etc.
  • Motors have just one Kv, not e.g. 2200Kv's.The motor Kv constant is physical quantity (length, weight, time, current, ...) measured/expressed in rpm/volt. It is not a physical unit (meter, kg, s, ampère, ... ).
Vriendelijke groeten Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Sold NIB Sapac T 45 Goshawk Comp ARF - Motor & Fan $150 Shipped Free rjronrj Aircraft - Electric - Jets (FS/W) 5 Aug 06, 2015 08:06 PM
For Sale For Sale: E-Flite F-16 400 DF ARF w/Motor & Fan Unit brandonmoon Aircraft - Electric - Jets (FS/W) 3 Oct 17, 2013 03:38 PM
For Sale (2) Himax 101mm 6 Cell Fan & Motor Combo $180 Both Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 0 Sep 03, 2011 07:59 AM
For Sale (2) Himax 101mm 6 Cell Fan & Motor Combo $180 Both Shipped FlyBoyTha1 Aircraft - Electric - Power Systems (FS/W) 0 Sep 03, 2011 07:56 AM
Discussion Where can I find amp draw and thrust figures for the XF/LSJS fan combo on 4 cells? Speedfreak Foamy EDFs 0 Nov 03, 2007 04:39 PM
