Old Apr 21, 2015, 03:07 PM
BobRCnut is online now
Find More Posts by BobRCnut
AMA 754
BobRCnut's Avatar
Phoenix area
Joined Apr 2004
USB to serial converters...?
... Is there such as thing as a 'universal' USB to serial converter? I have a number of RC-related devices which offer (as an option) firmware upgrades, programming or setup via USB and related software. For example, ESCs (Castle USB link), Quark gyros, MicroBeast 3-axis helicopter gyros, Xaircraft multirotor controllers, FyeTech products, etc.... Can a single adapter handle a variety of devices, or are they each brand-specific? All the ones in question have a USB connector on one end and a standard 3-wire servo connection on the other, but are there differences in protocol, or other factors? (My electronics knowledge started disappearing when vacuum tubes fell from favor...)
BobRCnut is online now Find More Posts by BobRCnut
Old Apr 24, 2015, 01:31 PM
FlyHighSelllow is online now
Find More Posts by FlyHighSelllow
Champagne Supernova
FlyHighSelllow's Avatar
United States, FL, Orlando
Joined Jul 2010
Kinda confused as you mentioned USB on one end and 3 wire servo on the other because this is a USB to serial adapter.
FlyHighSelllow is online now Find More Posts by FlyHighSelllow
Old Apr 24, 2015, 02:04 PM
AMA 754
BobRCnut's Avatar
Phoenix area
Joined Apr 2004
Sorry for the confusion. I'll try to clarify with an example:
The Microbeast 3-axis stabilizer for helicopters can be programmed from a PC.. but only if you have the USB adapter shown at the top of this page:
http://www.beastx.com/eng/products_accessories.php
Other devices Castle ESCs, etc.) offer the same optional USB cable and a converter or adapter (that goes between the USB cable and the device). That adapter usually has a micro- or mini-USB input and a servo connection for output. I'm guessing that the adapter's purpose is to convert USB-level signals into something acceptable to the ESC, but what else does it do, if anything?
They all seem to require the same SiLabs CP210x driver on the PC side... so what happens if I try to (for example) use a Hyperion ESC programming cable/adapter to connect a MicroBeast controller to the PC? Would it work, or do I really need the same-brand adapter for every PC-programmable device?
Old Apr 24, 2015, 02:17 PM
Champagne Supernova
Joined Jul 2010
Yeh those are most likely brand specific although some may work. Hit or miss most likely miss
Old Apr 26, 2015, 12:25 PM
AMA 754
BobRCnut's Avatar
Phoenix area
Joined Apr 2004
USB to Serial ... Answered (sorta)
I did some testing this weekend and determined that, in some cases, these adapters are compatible.
My original question was posed because I had a MicroBeast 3-axis heli gyro that needed a firmware update, and the BeastX-brand USB adapter was not locally available. I already had on hand a number of adapters from Hyperion, Castle, Xaircraft, and others.
I already had the required USB driver installed, so I fired up the BeastX software and connected the MicroBeast to the PC using a Hyperion USB cable and adapter that is normally used to program Hyperion digital servos. The software and driver did in fact recognize, and communicate with, the MicroBeast, and was able to capture and properly display the device's serial number and existing firmware level.
I then downloaded the required firmware update file and was able to install it
with no errors.
Discussion Alternative to FTDI serial/usb cable Deserteagle83 FPV Equipment 2 Feb 21, 2015 10:09 PM
Help! FT232RL USB to Serial Driver Install macjax Multirotor Electronics 0 Oct 03, 2014 12:08 AM
For Sale Serial to USB Converter/Adapter tnavressdog Non R/C Items (FS/W) 2 Dec 09, 2006 12:49 PM
Help! USB "Softdog" question & Serial-USB adapter? Perrycopter Simulators 11 Oct 10, 2006 08:52 AM
Need help with TX serial cable to Belkin serial to USB converter. ggood Simulators 4 Sep 23, 2006 10:58 PM
