Old Aug 09, 2014, 01:39 PM
Joined Aug 2014
Help!
frame electronics
hey guys
i have been flying quadcopters for just over 2 years now and thought it was time to try building one. I'm apparently woefully incapable of doing this however.
could i use these avionics:
http://www.hobbyking.com/hobbyking/s...ga328_PA_.html
http://www.hobbyking.com/hobbyking/s...r_mode_2_.html
http://www.hobbyking.com/hobbyking/s...0C%20Lipo%20Pa
with this frame:
http://www.hobbyking.com/hobbyking/s...opellers_.html
Thank you!
quadquadmaniac is offline Find More Posts by quadquadmaniac
Old Aug 10, 2014, 11:15 AM
United Kingdom, England, Warrington
Joined Jul 2013
Originally Posted by quadquadmaniac View Post
hey guys
with this frame:
Thank you!
Personally, I would not use any of those parts, you will end up in a mess!!!
Have you got a Tx already if you are already flying for 2 years?
Get a KK2.1 type of board to start with, much easier to use than the one you listed.
You will need to get a 6 channel Tx/Rx.
And the battery connectors don't match the battery..
cosmic2112 is online now Find More Posts by cosmic2112
Old Aug 11, 2014, 08:14 AM
Joined Aug 2014
thank you
see
this is why i didnt just get them
yeah i have a tx but i was unable to find a rx for it (it originally just connected to a sealed box within my quad)
can you suggest a list of parts that I could use (im trying to keep the price under about $150.
Thank you!
Old Aug 11, 2014, 08:24 AM
Joined Jul 2013
thank you
see
Thank you!
What make is the Tx then?
What size of quad do you want and what kind of flying do you like, (FPV, indoor hovering, outdoor acro, slow flying in garden, fast punchouts..etc)?
What skills/tools do you have i.e computer knowledge, soldering equipment, batteries etc
let me know and I'll try and help.
Old Aug 11, 2014, 08:33 AM
Joined Aug 2014
the tx is from a syma x1, i also have one from the hubsan x4 fpv but i didnt think that would be much help
i love fpv but don't think that i could get both a quad and an fpv system for $150, so i do most of my flying either indoor or small spaces.
i would very much enjoy a gps location hold but as thats not gonna happen with my budget lol
i do a lot of soldering and electronics work, and i can program in c and java (also arduino).
i would just like a platform that i can fly and can upgrade/modify/cannibalize for parts later as well.
Old Aug 11, 2014, 08:49 AM
Joined Jul 2013
Okay, well forst of all the most important thing is the Flight controller board, I suggest either a KK2.1.5
http://www.hobbyking.co.uk/hobbyking...mel_644PA.html
or an acro naze32
http://abusemark.com/store/index.php...uhql5b4j409hg3
have a look at those for now, you will need at least 6 channel Tx and Rx
maybe a Turnigy 9x and orange module and orange RX or an orange Tx Rx may be in your peice range.
Old Aug 11, 2014, 08:59 AM
Joined Aug 2014
so if i were to get
http://www.hobbyking.com/hobbyking/s...Firmware_.html
and
what quad frame and esc/motor would keep the price under $150?
Old Aug 11, 2014, 09:24 AM
Joined Jul 2013
so if i were to get
and
and some connectors...
http://www.hobbyking.co.uk/hobbyking...0pcs_set_.html
well, look here for some frames:-
http://www.armattanquads.com/
he does an unbreakable CF226 frame
or http://www.ecksstore.se/#!product/pr...bre-mini-230mm
these are the best there is, probably more than you need but have a look anyway just out of interest..
Old Aug 11, 2014, 09:55 AM
Joined Jul 2013
This may be worth a look, real cheap and made for the KK2 board:-
http://www.hobbyking.co.uk/hobbyking...otor_kit_.html
it takes a range of motors so you can experiment a bit...
I use afro 12amp esc's without any problem on my quads.
http://www.hobbyking.co.uk/hobbyking...Firmware_.html
Old Aug 11, 2014, 03:05 PM
United States, FL, Kissimmee
Joined Apr 2014
If you want a mini multirotor then what you linked in your first post is fine.
Do not listen to people telling you that you will be in a mess with parts you buy. You will not be "in a mess". All parts work the same with respect to building a quad. The mess comes from misinformation AND also not following directions.
Be very careful with a KK board because the board is pretty big to begin with and smaller frames are tough to set up. If you have no idea what you're doing when tuning PID's you will be frustrated. Trust me.
If you want something solid go with this: http://www.hobbyking.com/hobbyking/s...otor_arf_.html
Then get some RCX ZMR 1804 motors as spares once those motors crap out on you.
Get a Turnigy 9XR radio, its a basic radio and you can upgrade it and tweak it. Don't cheap out on an RX/TX combo unless you know what you're doing.
If you have an existing radio you might be able to run that instead!
upupupandaway is online now Find More Posts by upupupandaway
Old Aug 11, 2014, 09:45 PM
Tcraft's Avatar
North Texas
Joined Mar 2006
Take a look at the H quad I just built...easy to assemble, cheap and flies great!
http://www.rcgroups.com/forums/showthread.php?t=2220892
Ken
Tcraft is online now Find More Posts by Tcraft
Old Aug 12, 2014, 08:34 AM
Joined Aug 2014
also: is there a cheaper tx that's 6ch instead of 9ch?
and if someone has a recommendation for another one of those arf kits
Old Aug 12, 2014, 08:45 AM
Joined Aug 2014
could I use something like
http://www.hobbyking.com/hobbyking/s...?strSearch=6ch
Old Aug 12, 2014, 09:30 AM
Team WarpSquad
United States, PA, Doylestown
Joined Jan 2014
That is the radio I have been using (just under the FlySky brand).
I have had no trouble with it and now have four receiver's on different quads.
You do need the USB cable (does not seem to be included by HK's description) for that radio and a computer (Windows) to do any setup in the TX. However, for multi-rotors this really only needs to be done once. Set to Acro (Airplane) mode, Setup all sticks for Exactly 1500 when centered and then max the gains to get close the the 1000-2000 end point values (This can cause issues since I could not get the proper end point values. I run MW FC's so needed to adjust values in the MW code).
I have thought of getting one of those fancy FrSky radios but this just works fine.
waltr is online now Find More Posts by waltr
Sold 600 GT Frame / Canopy going for cheap! $110 in the US (no electronics) tdab Aircraft - Electric - Helis (FS/W) 6 Mar 30, 2014 04:08 PM
For Sale One frame of American mantis no flight, other missing parts with electronic $250 jcervantes11 Aircraft - Fuel - Helis (FS/W) 1 Jan 21, 2014 04:25 PM
Sold F550 frame and electronics 210.00 Tfmcnellist Aircraft - Electric - Multirotor (FS/W) 2 Jan 03, 2014 02:00 PM
Sold Uap1 Quad Frame with electronics + Spider Frame Kit + GoPro mount airbagit13 FPV Equipment (FS/W) 3 Aug 14, 2012 09:55 AM
Sold Uap1 Quad Frame with electronics + Spider Frame Kit + GoPro mount airbagit13 Aircraft - Electric - Multirotor (FS/W) 0 Aug 13, 2012 01:57 PM
